Seriously, I don’t know why you are doing that.
The following is (more or less) taken straight from the integration documents and assuming you have an automation section set up anyway, does it in 17 lines of two automations, no scripts required : -
automation:
- alias: bath_fan_on
- platform: state
entity_id: light.bath_room_ceiling_light
to: 'on'
- service: light.turn_on
entity_id: light.bath_room_fan
- alias: bath_fan_off
- platform: state
to: 'off'
for: '00:01:00'
- service: light.turn_off
Looking at your code, it seems to be GUI coded (which is fine) but pads it out somewhat.
It is also considered ‘strange’ to mark your own post as the solution (unless you did all the work) but to ‘mark the post that helped you the most’ achieve your desired result. (probably Dave’s ??? )
Also, not sure why your fan switch is listed under the light domain ? (you can change that if you want)
Hi Mutt,
this is not fan switch, because is zigbee relay connected to philips hue. And homeassistant is integrated with philips hue. This is the possible reason why is my fan relay propagated as a light.
Regarding the flag “Solution.” I sorry for that. I marked post as a solution because I use post from PetrolHead as inspiration and made my own and simplify solution how to do solve my issue.
And for your question about why i cant use two simple automation. The answer is, because in situation:
Turn lights on
Turn fan on
Then I leave from bathroom and turn off my lights
automation turns off my fan after x minutes
All this is ok with one automation, but if happens that, the lights are turned on during the countdown of automation, this countdown is not stopped. It continues to run it. Its not what I wanted. I want to stop countdown when the lights are on again.
Understood on the light.
In that case it’s nice to recognise @PetrolHead 's contribution
Edit: the posts PetrolHead linked to, are very old (Nov 2017) and the state (and numeric) trigger platforms have since been extended to include ‘for’ statements. Hence the scripts are no longer required.
