I am trying setup an automation to turn on a fan in my greenhouse. I have 2 sensors: sensor.greenhouse_inside_temperature and sensor.outside_temperature. I would like to turn on the fan if all of the following requirements are met:
- Fan isn’t already turned on
- Greenhouse temp is over 80 degrees F
- Inside temp of the greenhouse is > 5 degrees hotter than outside the greenhouse.
I am new to HA so I’m not sure how to setup bullet point 3. Do I use a condition template? script?
Here is what I have so far:
- alias: Turn fan on when greenhouse is too hot
- platform: numeric_state
entity_id: sensor.greenhouse_inside_temperature
above: 80
- condition: state
entity_id: switch.greenhouse_fan
state: 'off'
-condition: template
value_template: '{{ sensor.greenhouse_inside_temperature > sensor.greenhouse_outside_temperate + 5}}'
service: homeassistant.turn_on
Thanks is advance!
The condition part seems off, I think should be something like
condition: and
conditions:
- condition: state
state: 'off'
- condition: template
Not sure about the template condition cause I’m not using it, looks good though
I still can’t seem to make this work. Am I supposed to call the sensors like I am in the “value_template” section? In others examples, I see some people using ‘state.attribute’. I just can’t seem to find any documentation around using sensor data in the value_template section.
Here is what I currently have:
above: 80
condition: and
conditions:
- condition: state
state: 'off'
Just to help isolate this, if I remove the 2 lines of code for the condition template and value_template, the automation executes fine and the fan is turned on when the temp is > 80. So something is wrong with the condition template.
Perhaps changing:
To:
sensor.greenhouse_inside_temperature.state (Assuming it has a state)
Also you may have to convert them to float, but possibly not.
float(sensor.greenhouse_inside_temperature.state)
I meant to come back and update this, but yes, I had to do exactly that. This is what my code looked like:
value_template: "{{ states.sensor.greenhouse_inside_temperature.state | float - states.sensor.outside_temperature.state | float > 5 }}"
Hope this helps anyone in the future.
It is possible to get values from the variables and then use it to set passwords?
I mean, it is possible to get a code from “input_text component” and then use it to set http password or alarm code in the “manual alarm component”?
