Yes, I agree with you. Or put differently: you’re right
Will try tonight when I get back to my HA setups.
Theoretically both should work. I think…
Has the OP reported back yet?
Not yet
I’ll check your code when I get back home.
@123
The names of the sources are exactly the same as in the automation.
This is what I did:
The TV is on other source not listed in the automation, and the lights are off.
I’ve change the source to Netflix with the TV remote and the automation didn’t triggered.
Than I changed it to Plex, the automation was triggered and the lights are on at 30%.
I’ve turned off the lights and tried again.
The automation didn’t triggered anymore while changing the sources.
OK, it’s not behaving like one would expect the template trigger to work.
As an experiment, replace my single template trigger with your original three template triggers (leave the condition as it is now). Let’s see if that fixes it.
value_template: "{{ is_state_attr('media_player.living_room_tv', 'source',
'Netflix') }}"
'PS4') }}"
'Plex') }}"
If that doesn’t work properly, try Marius’ suggestion where it triggers on any change in the media_player’s state and then uses the condition to check if it’s the state-changes we want.
Theoretically, all three version should work equally well. If some work better than others then there’s a lesson to be learned here about which techniques are preferable.
I’ve tested this:
automation:
- alias: Spotify test 1
platform: template
value_template: >
{% set src = state_attr('media_player.spotify', 'source') %}
{{ src in ['Hall','Office','Woonkamer Speaker','Master bedroom Speaker',
'Chromecast Auditorium','HvB MacBook Air'] }}
condition: []
service: notify.notify
data_template:
title: Spotify trigger template
message: >
Spotify changed from {{trigger.from_state.attributes.source}} to {{trigger.to_state.attributes.source}}
- alias: Spotify test 2
platform: state
entity_id: media_player.spotify
condition:
condition: template
value_template: >
data_template:
title: Spotify condition template
message: >
both work:-)
I’ll post a screenshot from my iPhone , which displays a from_source (Telefoon) not listed here. It won’t trigger when the to_source is not listed.
Note: upon restart only the condition template automation fires.
update
It also keeps firing even without changing sources, indicating it triggers on other state/attribute changes…
this leads to a quick conclusion the trigger template automation is preferable
Thanks for testing it! That’s encouraging news. Not sure why the same template design didn’t work for Delicon.
It’s quite possible that the media player he is using doesn’t update immediately. I have a few media players that only update on 30 second mark (or so) which leads to delays and odd behavior if you aren’t patient.
EDIT: The media players that I have that act like this are the custom_component alexa media players. HA polls the Echo for changes. The Echo doesn’t report to HA, if that makes sense.
Hey, I’ve tried this and it’s working almost every time,
but only when the source is changing from source-not-in-the-list to source-in-the-list.
When I’m changing only the sources in the list nothing happens.
platform: template
value_template: >
{% set src = state_attr('media_player.living_room_tv', 'source') %}
{{ src in ['Netflix','PS4','Plex'] }}
EDIT: this is working every time, but…
If I turn off the lights when I’m watching Netflix and just change the volume/play/pause, the light will turn on to 30%.
- entity_id: media_player.living_room_tv
platform: state
condition:
- condition: template
value_template: >
- condition: state
entity_id: sun.sun
state: below_horizon
I just confirmed your results.
For the experiment, I used the following input_select
input_select:
options:
- 'off'
- item1
- item2
- item3
- item4
- item5
initial: 'off'
to trigger to this automation:
- alias: 'state changing test'
platform: template
value_template: >
{% set src = states('input_select.items') %}
{{ src in ['item1', 'item2', 'item3', 'item4'] }}
- service: system_log.write
data_template:
level: warning
message: "From: {{trigger.from_state.state}} To: {{trigger.to_state.state}}"
You’ll notice the template’s list does not contain off
and item5
off
to item1
, the automation was triggered.item1
to item2
, it did not trigger the automation.item5
and then to item1
, the automation was triggered.Like you discovered, changing between any of the states shown in the list will not trigger the automation. It will only trigger if the previous state was not in the list.
That does not work the way I expected! I learned something new today.
I believe this is not what I experience, if I read you correctly? Are you saying the automation only triggers on a source not listed?
Wonder how that is possible, since I see it trigger on all changes. It is however the thought that made me place my initial thoughts here: Automation with multiple triggers not working - #19 by Mariusthvdb
Please note that I referenced the not-listed-source as an exception after my testing automations, but there that makes perfect sense. Automation with multiple triggers not working - #24 by Mariusthvdb
I’m saying in order to trigger, it has to change from an unlisted source to a listed source.
In my experiment it failed to trigger when it changed from a listed source to another listed source
Given the following:
['off', 'item1', 'item2', 'item3', 'item4', 'item5']
Changing from:
off
to item1
→ triggeritem1
to item2
→ no triggeritem2
to item3
→ no triggeritem3
to item5
→ no triggeritem5
to item1
→ triggerThis is the behavior you predicted when you said:
yes, thats what I feared, but didnt establish in my testing. Cant replicate right now, since my googlehomes act up, so will have to get back on that later.
However, since the condition template automation worked fine too, with a few considerations, I suggest using that after all. Adding this generic safeguard condition, to prevent it firing on non state changes, attribute changes when in the same state etc etc.
value_template: >
{{ trigger.to_state.state is not none and
trigger.from_state.state is not none and
trigger.to_state.state != trigger.from_state.state }}
