Hey Community
I wanted to make an automation that mirrors thr state of a phillips hue bulb I have to a WeMo power socket. It works fine if I turn the hue lamp on/off with the app or alexa voice command.
But here is the problem, the hue bulb is still on a physical switch and if I turn the bulb off manually the state of the lamp switches to off in hassio but the automation trigger (if bulb changes state from “ON” to anything (left it blank)) doesnt trigger and the wemo socket is still active. Is there anyway I can fix this?
Thank you
