Automation with time
no problem.
just be aware that you need to add at least an "alias: " to that for it to work.
also if anything happens in that 8 hours the second part of the automation won’t be triggered as the delay will be cancelled…
You can still group it into one automation if you like with something like this:
- alias: Turn light on and off at preset times
    - platform: time
      at: '21:00:00'
    - platform: time
      at: '05:00:00'
    - service_template: >
        {% if now().hour == 21 %}
          light.turn_on
          light.turn_off
      entity_id: light.my_light
Another typical enhancement is to deal with HA restarts. (Otherwise, if HA is not running at one of these times, the light won’t be changed.) So something like this:
    - platform: time
      at: '21:00:00'
    - platform: time
      at: '05:00:00'
    - platform: homeassistant
      event: start
        {% set n = now() %}
        {% if n.hour >= 21 or n.hour < 5 %}
          light.turn_on
          light.turn_off
This works great. how do you put Monday, Tuesday, Wednesday, Thursday, Friday
The following automation turns on the light at 21:00 and turns it off at 5:00 only on Monday to Friday (ISO Weekdays 1 through 5). Also handles the situation where Home Assistant might be turned off at the scheduled start and/or stop times and is restarted later.
- alias: Scheduled Light
    - platform: time
      at:
        - '21:00:00'
        - '05:00:00'
      event: start
  condition: "{{ 1 <= now().isoweekday() <= 5 }}"
    - service: "light.turn_{{ 'on' if now().hour >= 21 or now().hour < 5 else 'off' }}"
        entity_id: light.whatever
This is what I did and It works. Thank you
- id: '000000000000000000'
  alias: Turn Off Light/fan at 6:30
  - platform: time
    at: 06:30:00
  - condition: time
    weekday:
    - mon
    - wed
    - fri
  - service: switch.turn_off
    data: {}
      entity_id:
      - switch.my_fan
      - switch.my_light
  initial_state: true
Please format your code with the </> button. See point 11 here.
You don’t need the after: and before: lines in the condition.
As shown above, it can be done with a single automation that’s shorter than the example you posted that only turns the lights off. Plus it can handle missed events such as when Home Assistant might be offline at 06:30. The example you posted will fail to turn off the lights if Home Assistant is offline at the scheduled time and won’t turn them off after it is running again.
You might be interested in this topic:
@123 , Thanks for this code, is it possible to add minutes to the time? e.g
  • platform: time
    at:
    - ‘21:10:00’
    - ‘05:30:00’
Yes. The documentation includes an example of a Time Trigger containing hours and minutes.
@123 , thanks for your quick reply, I have read the documentation already .
I am using 2 different automations, 1 to off a light and another to on it at a certain time but I like your version which merged on and off together in one automation, it also include days condition.
e.g
    - platform: time
      at:
        - '21:30:00'
        - '05:30:00'
      event: start
    - service: "light.turn_{{ 'on' if now().hour >= 21:30 or now().hour < 5.30 else 'off' }}"
The following template is incorrect and will not work the way you want.
now().hour produces an integer value (a whole number between 0 and 23). It cannot be compared to 21:30 (the comparison will always evaluate to false).
now().hour can be compared to a floating-point number like 5.3 but that value is not equivalent to the time 5:30.
I suggest the following which compares time represented as a tuple. In this case, the tuple contains two items where the first represents the hour and the second is minutes. So the time string 21:30 is represented as the time tuple (21,30).
    - variables:
        t: "({{ now().hour }},{{ now().minute  }})"
    - service: "light.turn_{{ 'on' if t >= (21,30) or t < (5,30) else 'off' }}"
Thanks so much, just what I wanted.
Regards
Also if you want to trigger every (for example) 20 minutes instead of at a specific time (useful if your conditions are complicated):
  - platform: time_pattern
    alias: check every 20 minutes
    minutes: "/20"
(edit: thanks to Taras - updated the original post to make sure it is correct)
Your example triggers at 20 minutes after the hour, every hour.
00:20
01:20
02:20
03:20
etc
If you use /20 it will trigger for any minute in an hour that is evenly divisible by 20.
00:00
00:20
00:40
01:00
01:20
01:40
02:00
02:20
02:40
03:00
etc
thanks for that correction - you’re right it should be:
    minutes: "/20"
You’ve helped me before in another post @123. Just came here to say… you are NEXT LEVEL GOAT!! :index_pointing_at_the_viewer: :clap: :clap: :clap: :clap:
I need an advice with my automation. I have a script which I want to run twice a month (1st and 15th of each month), but but for both days on different time (i.e. 1st day run at 9:00am, 15th day run at 12:30).
here is my code:
  - id: '1712514481790'
    alias: ATM_QNAPOFF
    description: ''
    - platform: time
      at: 09:00:00
    - platform: time
      at: 12:30:00
      - condition: template
        value_template: >-
          {{ ( now().day == 1 and now().hour == 12) or ( now().day == 15 and now().hour == 9) }}
    - service: script.qnap_off
      data: {}
    - service: notify.whatsapp_maros
        message: 'QNAP device is shutting down'
    mode: restart
The automation wont start. It looks that there is an issue with second time trigger but I can’t figure out…can somone help?
try quoting your time
    - platform: time
      at: '12:30:00'
and your hours are switched between your post and automation :slight_smile:
You can specify multiple times in the trigger:
  - platform: time
    at:
      - "09:00"
      - "12:30"
  - "{{ (now().day,now().hour) in ((1,9),(15,12)) }}"
    data: {}
mode: restart
Also shortened the condition including the use of shorthand notation.
