Hey!
Install the app in your daughters phone, then use a different name for the sensor. E.g. input_datetime.next_alarm_daughter
. You will find it under connection settings.
Sorry but need to askâŠ
I have a sensor at sensors.yaml:
- platform: time_date
display_options:- âdate_timeâ
Then I have at configuration.yaml:
input_datetime:
next_alarm:
name: Next scheduled alarm
has_date: true
has_time: true
I installed Hassalarm to my daughter phone with entity_ID: input_datetime.next_alarm_daughter but cannot find that entity anywhere⊠Do I have to add something somewhere else?
Hey!
Yes, you need to add input_datetime.next_alarm_daughter
as well in your configuration.yaml
input_datetime:
next_alarm:
has_date: true
has_time: true
next_alarm_daughter:
name: Next scheduled alarm for daughter
has_date: true
has_time: true
Hi!
Sorry my stupid question⊠Thx 4 your answerâŠ!!
Hi!
Got it working but there is one thing i donât understand.
From my phone hassalarm creates entity next alarm time correctly but from my daughter phone there is -5 min difference. So if alarm time is 14.00 -> entity time is 13.55 and so onâŠ
Do you have any idea why like this? (I can live with that but Iâm just a curious and also if there is a bugâŠ)
Hey!
Yes, this is a bug with the Samsung alarm app: https://github.com/Johboh/hassalarm/issues/11
Solution is to use Google alarm clock app instead.
Thx for the information! Any case when youâre not so sure⊠Youâre doubting yourself and own faults
And⊠Anybody got an idea how to add entity next alarm time minus 5 minutes to the node red? I have otherwise working wakeup light but donât know how to do thisâŠ
Fantastic work! Works like a charm and spared me a ton of work. Thanks a lot!
This functionality is in the home assistant app also.
No need for an extra app anymore.
But if you donât want the companion app due to privacy then this is a good alternative
nice one bro
there more than one skin a cat
I did it
by creating a new sensor
minutes_next_alarm_stephan:
friendly_name: "Minutes until Next Alarm Stephan"
unit_of_measurement: "m"
value_template: >-
{% set dummy = states("sensor.time") %}
{{((states('sensor.sm_g986b_next_alarm')|as_timestamp|int - now()|as_timestamp|int)/60)|int}}
availability_template: "{{ not is_state('sensor.sm_g986b_next_alarm','unavailable') }}"
attribute_templates:
time: "{{ state_attr('sensor.sm_g986b_next_alarm','Local Time') }}"
now I can just use that in a trigger.
- platform: numeric_state
entity_id: sensor.minutes_next_alarm_stephan
below: "2"
Oh, did not know that. How do I see that?
Install the home assistant app, click on app configuration and then manage sensors â next alarm (or something like it).
