Automations in release 0.113
according to Thomas, this would have to be possible:
You can also merge an anchor if you want to add more entries to the dict:
base: &base
  a: 1
  b: 2
extended version:
  <<: *base
  c: 3
That’s a dictionary, not a list. Yes, it’s supported for those, but not for lists, as far as I can tell.
After upgrading to 0.113 I have changed the following automations
- alias: Lamp toilet aan bij beweging geconstateerd door bewegingssensor
    - platform: state
      entity_id: binary_sensor.bewegingsensor_toilet
      to: 'on'
    - service: switch.turn_on
      entity_id: switch.shelly_toilet
- alias: Lamp toilet uit bij geen beweging meer
    - platform: state
      to: 'off'
      for:
        minutes: 5
    - service: switch.turn_off
to
- alias: Lamp toilet aan en uit bij beweging geconstateerd door bewegingssensor
    - platform: state
    - choose:
      - conditions:
        - condition: state
          state: 'on'
        sequence:
      - conditions:
        - condition: state
          state: 'off'
          for:
            minutes: 5
        sequence:
But then the light doesn’t go off anymore.
Am I missing something here or does the for part not work for this?
I am on 113.1 btw as I saw some issues with TTS with 113.2.
The for part in a state condition does not mean exactly the same thing as it does in a state trigger. In the trigger it actually waits for the entity to be in the specified state for that amount of time. But in a condition it only cares if the entity has been in that state for that amount of time. So you’re triggering when the sensor goes off, but then checking if it has been off for 5 minutes, which, of course, it has not been.
This is another case where a service_template would be much easier, but the real issue is you’re no longer waiting for the sensor to be off for 5 minutes before doing something.
If you really want to use chose over service_template, then here’s what I would suggest:
    - platform: state
      to:
        - 'on'
        - 'off'
  mode: restart
    - choose:
      - conditions:
        - condition: state
          state: 'on'
        sequence:
      default:
        - delay: "00:05"
Thanks for your explanation and example! That makes sense indeed.
The service_template version would look like this then?
    - platform: state
      to: 'on'
    - platform: state
      to: 'off'
      for:
        minutes: 5
    - service_template: "switch.turn_{{ trigger.to_state.state }}"
