It looks like its going to break again since its accessing the database from the event loop which effectively blocks Home Assistant from doing anything (accepting connections, running automations, updating integrations, etc) until the database call finishes. Doing this will raise an exception in 2022.6.
I’ve added some notes to that issue on how to fix it.
- platform: average
name: outdoor rain info cycle # dati relativi alla pioggia nel ciclo impostato (average, min, max)
start: "{{ (as_timestamp( now()) - (states('input_number.ciclo_irrigazione')| float *86400))}}"
end: "{{now()}}"
entities:
- sensor.total_rain_rate
the input_number.ciclo_irrigazione is a value that I set through a slider.
When I change the input number value the update of the average sensor it’s not instant, I’ve to wait up to 20secs
Is there a way to recalculate the average sensor instantly when input_number.ciclo_irrigazione is set to a new value ?
I tried to put a tap action/hold action on the slider and call an homeassistant.update_entity service targeting the average sensor but nothing happens
Is it possible to calculate the average with ha-average (GitHub - Limych/ha-average: Average Sensor for Home Assistant) not timebased? So techincally just the mean value. I am trying to calculate my average weight on a weekly basis, so it doesn’t matter how long the state is the value just the changes matter.
Does the recorder “keep_days” setting have to be larger than the number of days I want the average to be calculated for? I want to calculate the monthly energy cost average. I currently have “keep_days” set to 7. Does this integration operate independently of this setting?
They are not the same they are both correct but you are measuring 2 different averages. The first one is likely giving the same result as the statistics integration
i have an energy sensor counting my house load consumption
how do i utilize this average to get a last 7 days average sensor ?
which source entity should i use for this ? the original one ? or a utility meter one ?
I just installed the sensore. I would like to create a sensor to average the night temperature, ie. from sunset to sunrise each day. So the start and end time should change based on, for example, sun entity. Is it possible to do that? Or have I just use “fixed” start and end time?
Due to this integration is abandoned, I’ve finally replaced it with the built in solutions. Problems to solve:
filter sensor goes unavailable as soon as the original sensor goes unavailable, even if it is a long duration average
filter is unavailable at startup
generic_thermostat will never switch off if the temperature sensor is unavailable
After several failed experiments I’ve ended up with 2 sensors:
a plain filter, that is good for graphs
a template wrapper around the filter that can be used for the thermostat, this goes to a high enough temperature to turn off the thermostat if the sensor is unavailable for a specified time
sensors:
# - platform: average
# name: 'Living room Temperature Average'
# entities:
# - sensor.living_room_temperature
# duration:
# minutes: 1
# precision: 1
# process_undef_as: 25.0
- platform: filter
name: "Living room Temperature Average"
entity_id: sensor.living_room_temperature
filters:
- filter: time_simple_moving_average
window_size: "00:01"
precision: 1
template:
- trigger:
- platform: state
entity_id: sensor.living_room_temperature_average
to: # empty = any state change, no attribute change
- platform: state
to: "unavailable"
for:
minutes: 1
- name: "Living room temperature average for heater"
state: '{{ states("sensor.living_room_temperature_average") if trigger.id != "unavailable" else "25.0" }}'
unit_of_measurement: '°C'
device_class: temperature
availability: '{{ states("sensor.living_room_temperature_average") is not match("un\w*") }}'
I also have a sensor setup using the built in sensor grouping set to arithmetic mean, as apposed to median. My group sensor had a slightly different number than this plugins result, so I could only assume it didn’t use straight arithmetic mean, or else it would match closer.
However after having them setup overnight it seem to have equaled out. So no problem after all.
I’m still curious about safety for sensors that drop. Seems to handle it from my testing, unlike the built in helper, but it’s only been a day so far.
Hi your proposal to replace this integration with the ‘filter’ is interesting, I have not seen it before, and myself I migrated to the ‘statistics’ integration (as probably many others).
However I have found out that there is a significant bug in the ‘statistics’ sensors that occur at each restart of HA, where the value can go wayyy off charts for a few minutes (looks like a bad variable initialisation or alike), which is making any automation linked to the sensor do wrong things.
I was wondering if the ‘filter’ sensors were capable to filter values over a 24h window? As I read in the warning of this integration, it may seem it is more made for near-real-time filtering, right?
At this moment I’m doing something relatively similar to your setup, I’m doing a first average with ‘statistics’ then a filter with a template sensor… not too nice.
It’s a shame because I have never had any trouble with this average sensor ever before.
I think it is abandoned unfortunately. The commit that was fixing the deprecation introduced by HA 2023.4 was prepared months ago but never pushed to publication.
Many people have been waiting until the last moment to see if this integration would be updated in time, and the answer is no…
Now I’ll put my effort on the bug fix of the statistics integration instead.
I have no experience with statistics, though for long time averages (like 24h) filter seems to be a bad choice, because filter doesn’t use recorder after restart to read past sensor values. Maybe another wrapper template sensor that hides the statistics sensor’s value after restart for a few minutes? Returning unavailable for a few minutes? This is only plain guesswork from me.
