I finally got this working too @Lapatoc’s method; docker running with --host, the port mapped, and adding the traefik provider manually.
Make sure to also add [file]
to traefik.toml, to enable the non-docker traefik provider.
The log doesn’t seem to load in developer tools -> info -> log
. Does that work for anyone that is running with net=host
and static backend configuration?
It works if I directly access it via IP
Could you please share your complete config? Do you have a docker-compose.yml and a traefik.toml right?
Thanks!
I use Ansible instead of docker-compose, which is fairly similar in terms of syntax (both YAML), but not the same.
You can probably figure out how your docker-compose.yml would look like, by looking at my Ansible config though:
- name: "Create Home Assistant container"
docker_container:
image: homeassistant/home-assistant
privileged: yes
volumes:
- /opt/homeassistant/config:/config
ports:
- "8123:8123"
network_mode: host
restart_policy: always
restart: yes
state: started
labels:
traefik.enable: "false"
My traefik.toml looks like this:
debug = false
logLevel = "INFO"
defaultEntryPoints = ["http", "https"]
[api]
# traefik dashboard
entryPoint = "traefik"
dashboard = true
[entryPoints]
[entryPoints.traefik]
address = ":8080"
[entryPoints.http]
address = ":80"
# forward all HTTP traffic to HTTPS
[entryPoints.http.redirect]
entryPoint = "https"
[entryPoints.https]
address = ":443"
[entryPoints.https.tls]
# watch Docker, when new containers are created with label create mapping.
[docker]
endpoint = "unix:///var/run/docker.sock"
domain = "<your domain>"
watch = true
[file]
[frontends]
[frontends.frontend-home-assistant]
backend = "backend-home-assistant"
[frontends.frontend-home-assistant.routes.test_1]
rule = "Host: home.<your-domain>"
[backends]
[backends.backend-home-assistant]
[backends.backend-home-assistant.servers.server1]
url = "http://<your HA IP>:8123"
[acme]
email = "<your email>"
storage = "acme.json"
caServer = "https://acme-v02.api.letsencrypt.org/directory"
[acme.dnsChallenge]
provider = "transip"
[[acme.domains]]
# note: wild cards like the one below only work with DNS challenge
main = "*.your-domain.com"
Note, I’m using a DNS challenge for LetsEncrypt, you should probably replace that for a HTTP challenge, unless there’s a reason for you to use a DNS challenge. See Traefik examples.
Thank you so much for the tidbit about the [file] parameter! I have been going mad over the past 2 days wondering why I could not get Traefik to read the config from my toml file! This was the ticket.
Has anyone managed to get this working with the iOS App? I get numerous authentication errors and cannot enable notifications. I did find some extra Traefik parameters on www.smarthomebeginner.com however not having much luck with these nor the default configurations above.
I’ll try and break it down:
version: "3.6"
services:
hass:
container_name: 'hass'
image: 'homeassistant/home-assistant:latest'
restart: 'unless-stopped'
ports:
- 8123:8123
volumes:
- /etc/localtime:/etc/localtime:ro
- ./volumes/home-assistant:/config
- /dev/ttyACM0:/dev/ttyACM0
environment:
- TZ=Europe/London
privileged: true
networks:
macvlan:
ipv4_address: 192.168.1.22
traefik_proxy:
default:
labels:
- "traefik.enable=true"
- "traefik.frontend.rule=Host:hass.xxx.com"
- "traefik.port=8123"
- "traefik.docker.network=traefik_proxy"
- "traefik.frontend.headers.SSLRedirect=true"
- "traefik.frontend.headers.STSSeconds=315360000"
- "traefik.frontend.headers.browserXSSFilter=true"
- "traefik.frontend.headers.contentTypeNosniff=true"
- "traefik.frontend.headers.forceSTSHeader=true"
- "traefik.frontend.headers.SSLHost=xxx.com"
- "traefik.frontend.headers.STSIncludeSubdomains=true"
- "traefik.frontend.headers.STSPreload=true"
- "traefik.frontend.headers.frameDeny=true"
here are the networks:
networks:
traefik_proxy:
external:
macvlan:
external: true
default:
driver: bridge
here is one of the other containers:
node-red:
container_name: 'node-red'
depends_on:
- hass
image: 'nodered/node-red-docker:v8'
hostname: 'node-red.xxx.com'
user: 'root'
ports:
- 1880:1880
volumes:
- ./volumes/node-red:/data
networks:
- traefik_proxy
- default
labels:
- "traefik.backend=node-red"
- "traefik.frontend.rule=Host:node-red.xxx.com"
- "traefik.port=1880"
Here is the mtacvlan setup from my ubuntu docker host. It creates me a /28 network range I can use for docker containers on my local network:
docker network create -d macvlan --subnet=192.168.1.0/24 --ip-range=192.168.1.16/28 --gateway=192.168.1.1 -o parent=ens33 macvlan
And here is the traefik:
version: '2'
services:
traefik:
image: traefik:latest
restart: always
domainname: xxx.com
dns: 8.8.8.8
ports:
- 80:80
- 443:443
# - 7070:8080
networks:
- default
- traefik_proxy
environment:
- [email protected]
- CLOUDFLARE_API_KEY=xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx
labels:
- "traefik.backend=traefik"
- "traefik.frontend.rule=Host:traefik.xxxx.com"
# - "traefik.frontend.rule=Host:${DOMAINNAME}; PathPrefixStrip: /traefik"
- "traefik.frontend.auth.basic.users=yyyyyy:$$xxxxxxxxxxxxxxxxxxxxx"
- "traefik.port=8080"
- "traefik.frontend.headers.SSLHost=xxx,com"
volumes:
- /var/run/docker.sock:/var/run/docker.sock
- ./volumes/traefik:/etc/traefik
- ./volumes/shared:/shared
container_name: traefik
networks:
traefik_proxy:
external:
default:
driver: bridge
The big challenge with mtacvlan is that the container cannot talk to the host on the mtacvlan network. I have got around this by using the traffic_proxy network to hook the hass front end into traefik, using the default network to allow the hass containers including db (not shown), influxdb (not shown) etc… to talk to each other .
I might try and simplify this by running every container in the mtacvlan network. The /28 gives me 16 usable addresses on the LAN for containers, I could increase this with a /27 or event a /26.
Not sure I have explained this entirely well.
Thanks for the fast reply
When I do the changes and validated the config with docker-compose config, I get the following error: services.homeassistant.networks contains {"macvlan": {"ipv4_address": "192.168.0.200"}}, which is an invalid type, it should be a string
Config: https://pastebin.com/CtZ0ieB3
I removed the ‘ipv4_address’ line and managed to get it started, though HA isn’t able to connect to any thing.
How did you define the mtacvlan network.
Adrian
I used the following command:
docker network create -d macvlan --subnet=192.168.0.0/24 --ip-range=192.168.0.200/29 --gateway=192.168.0.1 -o parent=eth0 macvlan
I’m unable to ping to the ip of the docker server. The rest same to work as intended.
In order to make the port available on the macvlan IP I followed this guide: https://docs.docker.com/v17.09/engine/userguide/networking/get-started-macvlan/#macvlan-bridge-mode-example-usage
There is a requirement for mtacvlan to have your adapter in promiscuous mode. How to do that will depend on your setup
Did you find a solution to this, particularly a way to use bluetooth inside a container without host networking? I run my containers with macvlan networking, so using host networking isn’t an option for me.
Thanks! Nice trick to get this to work.
Did you manage to get this working with the iOS app ? I’m getting a homeassistant | 2019-09-17 18:48:27 WARNING (MainThread) [homeassistant.components.http.ban] Login attempt or request with invalid authentication from 172.18.0.2
Even though Traefik (172.18.0.2) is in trusted proxies
Most of the replies in this thread are about traefik v1.x, here is my config for v2.1 in case anyone finds it useful.
Home assistant still uses network_mode: host and runs on port 8123 but traefik accesses it by its local IP address.
docker-compose.yml
version: "3"
# This network is not required for home-assistant but for other docker containers
networks:
proxy:
external: true
services:
reverse-proxy:
image: traefik:v2.1
networks:
- proxy
ports:
- "80:80"
volumes:
# So that Traefik can listen to the Docker events
# Traefik config files
- ./traefik.toml:/etc/traefik/traefik.toml
- ./dynamic_conf.toml:/etc/traefik/dynamic_conf.toml
traefik.toml
[providers.file]
filename = "/etc/traefik/dynamic_conf.toml"
dynamic_conf.toml
[http]
[http.routers]
[http.routers.home-assistant]
service = "home-assistant"
rule = "PrefixPath(`/`)"
[http.services]
[http.services.home-assistant.loadBalancer]
[[http.services.home-assistant.loadBalancer.servers]]
url = "http://IP_ADDRESS:8123/"
If all went well you should be able to access home assistant at http://IP_ADDRESS:80
. Tweak the rule in dynamic_conf.toml to your preferred forwarding setting. Refer to traefik’s docs for a list of available matchers.
That can be solved with adding this to your traefik service in the compose file:
extra_hosts:
- "host.docker.internal:host-gateway"
That way you can keep the HA in host mode because it enables you to communicate with the Docker Host. Then you can just create a network for your other containers (including traefik).
Thanks for this. The extra_hosts
addition works brilliantly. I was running into issues with integrations (konnected, ubiquiti etc) when attempting to run HA out of hosts mode yet wanted to use traefik to handle web facing access.
