Hello Users,
where can i get a backup from https://demo.home-assistant.io/ ?
I want to use the demo on my own installation.
Greets
henrya
Hello Users,
Greets
henrya
Hello, how can i get and use the home-assistant setup backup in my own Home-Assistant OS install?
My system
Home Assistant 2023.3.6
Supervisor 2023.03.3
Operating System 9.5
Frontend 20230309.1 - latest
Home Assistant OS install
Where is my configuration.yaml
File?
Folder Terminal & SSH Current version: 9.6.1
/config/configuration.yaml
But i don’t find the file with ssh login
# ls -la
total 8
drwxr-xr-x 14 root root 247 Jan 24 18:28 .
drwxr-xr-x 14 root root 247 Jan 24 18:28 ..
lrwxrwxrwx 1 root root 7 Jan 24 18:07 bin -> usr/bin
drwxr-xr-x 16 root root 3260 Apr 2 09:27 dev
drwxr-xr-x 28 root root 1003 Jan 24 18:28 etc
drwxr-xr-x 2 root root 3 Jan 24 18:07 home
lrwxrwxrwx 1 root root 7 Jan 24 18:07 lib -> usr/lib
lrwxrwxrwx 1 root root 3 Jan 24 18:07 lib64 -> lib
drwxr-xr-x 6 root root 68 Jul 14 2021 mnt
dr-xr-xr-x 253 root root 0 Apr 2 09:27 proc
drwx------ 4 root root 42 Jul 14 2021 root
drwxr-xr-x 21 root root 540 Apr 2 09:28 run
lrwxrwxrwx 1 root root 8 Jan 24 18:07 sbin -> usr/sbin
drwxr-xr-x 5 root root 65 Jan 24 18:25 share
dr-xr-xr-x 12 root root 0 Apr 2 09:27 sys
drwxrwxrwt 10 root root 4096 Apr 2 10:27 tmp
drwxr-xr-x 7 root root 126 Jan 24 18:28 usr
drwxr-xr-x 9 root root 4096 Apr 2 09:27 var
i don’t the find configuration.yaml File, if i connect with
ssh -i ~/.ssh/id_rsa [email protected] -p 22222
Where is the “configuration.yaml” file?
Greets
henrya
Why are you using the for developers only debugging access?
You should be using one of the SSH add-ons, which will make it easy to access those files.
Because i’m learning HAOS, i don’t understand the for developers only debugging access.
How can in find the “configuration.yaml” in the for developers only debugging access.?
Well… you don’t
You install one of the add-ons I linked to above.
