BCHydro/Powerley now offer two device options ( “Powerlync Hub” for $75 or the “Energy Bridge Hub” for $179). Has anyone tried if both devices work the same (in terms of the mqtt access/data)?
Can you help me with how you are doing this please. Are you using the Energy Bridge Hub? How are you transmitting data from Hydro to MQTT?
Assuming you know the address of the bridge, uses port 2883
wait so it is possible to use the new hubs to read data thru HA?
Are you saying I just need to replace “address xxx.xxx.xxx.xxx:2883” with the IP address of the Energy Bridge on my network, and it will automagically start transmitting data over MQTT with your YAML config?
Going to recap my config here in one post as there are a lot of conversational details spread throughout this topic.
I have the “Energy Bridge (HydroHome Hub)” device I have no idea if any of the newer devices work the same way.
In my network / router config I have given the Energy Bridge a IP reservation so its IP stays the same.
The first part is to to change the config of your mosquitto mqtt server so that IT connects to the mqtt service on the hydro hub. If you are running HASOS you will have to figure out how to do that, if you are running it as a separate docker just edit the mosquitto.conf file and add the following at the end
192.168.1.50 is the IP of my Energy Bridge so mosquitto MQTT is connecting to it.
##### Connect to BCHydro Energy Bridge
connection bchydroenergybridge
address 192.168.1.50:2883
clientid mosquitto-ha
try_private false
start_type automatic
topic # both 0
Restart the MQTT service after editing the config… If you use an MQTT client (go look that up) you can monitor the MQTT server and see if it now has the extra MQTT Topics “event/metering/summation/minute” or “event/metering/instantaneous_demand”
- IN the home assistant config I created the following two MQTT sensors.
- name: "BCHydro Grid Consumption"
unique_id: energy_bridge_summation_minute_kwh
state_topic: "event/metering/summation/minute"
icon: mdi:transmission-tower
unit_of_measurement: 'kWh'
# the Energy Bridge returns "Watt-minutes" (Wmin) every minute; convert it to kilowatt-hours
value_template: "{{ value_json.value | float / 60000 }}"
# the "time" in the message is a Unix-like timestamp (in milliseconds) of the start of the last reading
last_reset_value_template: "{{ now().fromtimestamp(value_json.time / 1000).replace(tzinfo=now().tzinfo) }}"
device_class: energy
state_class: total
- name: "BCHydro Instantaneous Demand"
unique_id: energy_bridge_instantaneous_demand
state_topic: "event/metering/instantaneous_demand"
icon: mdi:transmission-tower-export
value_template: "{{ value_json.demand | int }}"
unit_of_measurement: 'W'
device_class: power
state_class: measurement
- Last part you should be able to go add the “BCHydro Grid Consumption” sensor to the energy dashboard in HA under Electricity grid.
I just got the $75 Hydro Powerlync plug working - no luck with mqtt/2883
It’s advertising HomeKit over MDNS and it listens on http port 80. The HomeKit logo and pairing info are covered up by stickers so probably not supported unofficially.
It works for live data with the app but it goes to the cloud. The plug itself shows power usage of what’s plugged in.
Does it only show power usage for the device that is plugged in, or does it enable live power readings for the whole house?
Just catching up with this thread which seems to span from 2019 to at least 2024. Anyway, the meter location can vary widely depending on when the building was built or retrofitted. I bought a bridge because our meters are in the hallway, between 2 and 3m away, so I thought I’d give it a shot.
Hey everyone! I followed this post over the last few months. A big thank you to everyone who contributed ideas to it!
If anyone is still interested getting data from BC Hydro the free way without hardware and relying solely on BC Hydro’s website, I created a Puppeteer script that you can find in my repository (along with a bash script to compile it to be used in configuration.yaml or rest.yaml).
BC Hydro updates consumption data daily so this may not have enough granularity to track specific device consumption but it does allow you to track your bill, projected total at the end of the billing period, daily consumption and more.
Looks a bit something like this:
Please feel free to raise an issue on the repository if updates are required.
Note: Running the script requires running the Browserless Home Assistant Add-On .
Please see walkthrough if you are having trouble setting it up.
So this hub will allow you to bridge the live consumption over MQTT into HA?
Unofficially and requires some additional setup to get the MQTT server to pull the data.
SOME risk that access to it might get closed at some time in the future.
Having said that the tracking and app they provide is rather good on its own.
Hello! thanks fo the guide, I got it all working, the only issue I have is, after 10-15 min, the hub switches from updating every 3 seconds to 30 seconds, if I open the BCHydro app, it goes back to 3 seconds and so on. I saw some seem to be sending an empty json to “_zigbee_metering/request/is_app_open” however that didnt solve it for me.
Anyone facing this issue?
I never really paid close attention to the Instant value in that detail, mine is updating every 30s currently and that is fine for me as I mostly use the Grid Consumption to do break downs of total use.
I HAVE had a problem with my hub happen TWICE in the last two months however where it stops sending any data / shows as disconnected or not paired with the meter… I have had to go through the reset and onboarding steps twice to resolve this.
Both times it stopped sometime in the middle of the night so I suspect ether the meter or the hub got an update that messed things up.
This page helped me add my bchydro powerly data into HA.
I only got HA 2 days ago, so i just copied the url of this page and plugged it into chatgpt.
I had it all sending live info which matched hydrohome app, with 30 seconds delay as another user mentioned.
I’ve spent a lot of time examining this long post and trying to get my new BC Hydro Energy Bridge connected to HA.
Having tried every way I could see to have MQTT show the data as sensors I’ve pretty well given up, which is why I’m making this post.
MQTT Explorer shows data is being broadcast, under "event>metering>summation.. However my MQTT installation doesn’t show the sensors even after I have followed all the steps to add the sensors into the config.yaml file. Or even into a mqtt.yaml file, which HA doesn’t seem to like at all.
I’ve found a post which mentions adding mqtt devices now requires the use of the HA UI via the + add MQTT device button. I’ve tried that but found since I’m a klutz at most mqtt details, I’ve not got the setup done well enough to connect perfectly. There is a connection reading the data but it’s not displaying the detailed power.
This brings me to my request.
Could someone guide me through what details are needed in the UI setup? I’m close to getting this to work but just missing the fine details of what is needed in each dialogue box of the setup.
I suspect all future users of the Hydrohome Energy Bridge will need to follow what I am slowly trying to learn.
Thanks!
Replying to myself!
Looking at the details of the suggested config.yaml addition for the sensors, i was able to pick apart the details for each setting in the dialogue boxes for the UI adding mqtt device.
I’ve now got both sensors reporting in MQTT!
From my rather long hours trying to get this all working I can advise doing as I did. Go through the MQTT add device rather than try to edit the config file. I suspect the details of the sensors are now ONLY kept somewhere other than the config and mqtt.yaml files. Others may be able to confirm or deny my suspicions.
