Hi @mathuieu,
What additional information can you gather?
On my side, I use a Shelly 1 PM micromodule to verify the production. This is the only thing that matter.
Hi @mathuieu,
Hi @malendure,
I connected my Homewizard energy socket to the solar panels powercord and from there i could see that the energy socket also measered solar panels production, so i created a new integration and added it to my energy dashboard. Also works great!
Wellll, this also does not help me, because the energy socket shows negative power because itâs returning power from the Beem panels. HA does not understand this⌠What to do next? Iâve tried the code again, but it gives me all these errors. It looks like there is a gap between versions of HA?
This is my version of HA:
Home Assistant 2023.9.1
Supervisor 2023.08.3
Operating System 10.5
Frontend-versie: 20230908.0 - latest
Thank you for all the work itâs been quite helpfull. Iâve had to change a line because it wasnât working with the secret.
Authorization: Bearer {{ states.sensor.beem_token.state }}
Dear Gurus, Thanks a lot for sharing your brilliant ideas - I learn a lot with this post - that I finally succeed to implement. Partially, in fact, since I have 2 Beem kits, and the text retrieved from the API holds 2 times the different variables:
âboxIdâ:13435,
ânameâ:null,
âlastAliveâ:â2024-03-27T09:18:24.489Zâ,
âlastProductionâ:â2024-03-27T09:17:00.000Zâ,
âserialNumberâ:â409151850C05â,
âtotalMonthâ:16405,
âwattHourâ:0,
âtotalDayâ:0,
âweatherâ:null
âboxIdâ:12945,
ânameâ:âPignonEstâ,
âlastAliveâ:â2024-03-27T09:19:49.626Zâ,
âlastProductionâ:â2024-03-27T09:19:00.000Zâ,
âserialNumberâ:â58BF2539F03Dâ,
âtotalMonthâ:15104,
âwattHourâ:0,
âtotalDayâ:0,
âweatherâ:null
I guess an array is the solution but I have not enough experience in HA.
Should the format for the sensor be the following:
`sensor:
- name: "beem"
json_attributes_path: "$[0,1]"
What will be the syntax for the state_attr, for example for wattHour:
`state: "{{ state_attr('sensor.beem','wattHour') | float/1000 }}"`
Best regards
Dear All,
Inspired from [RESTful - Home Assistant], I finally managed to read values from the 2 Beem Energy kits with the following configuration file using âbeem1â and âbeem2â sensors, instead of âbeemâ, as @malendure proposes:
# 'Beem Energy' Start
template:
- sensor:
- name: post_data
state: '{"month":{{now().strftime("%m").lstrip("0")}},"year":{{now().strftime("%Y")}}}'
- name: boxId1
device_class: energy
state_class: total_increasing
state: "{{ state_attr('sensor.beem1','boxId') | int }}"
icon: mdi:solar-power
- name: total_month1
unit_of_measurement: "kWh"
state: "{{ state_attr('sensor.beem1','totalMonth') | float/1000 }}"
- name: total_day1
state: "{{ state_attr('sensor.beem1','totalDay') | float/1000 }}"
- name: watt_hour1
unit_of_measurement: "Wh"
state: "{{ state_attr('sensor.beem1','wattHour') | float/1000 }}"
- name: boxId2
state: "{{ state_attr('sensor.beem2','boxId') | int }}"
- name: total_month2
state: "{{ state_attr('sensor.beem2','totalMonth') | float/1000 }}"
- name: total_day2
state: "{{ state_attr('sensor.beem2','totalDay') | float/1000 }}"
- name: watt_hour2
state: "{{ state_attr('sensor.beem2','wattHour') | float/1000 }}"
rest:
- resource_template: https://api-x.beem.energy/beemapp/box/summary
method: POST
headers:
Content-type: application/json
Authorization: !secret beem_token
payload: '{"month":3,"year":2024}'
scan_interval: 60
- name: "beem1"
json_attributes_path: "$[0]"
json_attributes:
- "boxId"
- "totalMonth"
- "wattHour"
- "totalDay"
value_template: 'OK'
- name: "beem2"
json_attributes_path: "$[1]"
json_attributes:
- "boxId"
- "totalMonth"
- "wattHour"
- "totalDay"
command_line:
- sensor:
command: 'token=$(curl https://api-x.beem.energy/beemapp/user/login -X POST -H "Content-Type: application/json" --data-raw "{\"email\":\"my_email\",\"password\":\"my_password\"}" | jq .accessToken) && token=${token//\"} && echo $token && sed -i "s/\(beem_token:\)\(.*\)/\1 Bearer $token/" /config/secrets.yaml'
scan_interval: 84600
shell_command:
beem1: sed -i "s/\({{cmd}}:\)\(.*\)/\1 '{{ states.sensor.post_data.state|to_json }}'/" /config/configuration.yaml
beem2: sed -i "s/\({{cmd}}:\)\(.*\)/\1 '{{ states.sensor.post_data.state|to_json }}'/" /config/configuration.yaml
# 'Beem Energy' End
Thanks a lot again for sharing your knowledge.
