Hi.
Long time Domoticz user here. But I want to check out if Home Assistant may be a good try for me.
My current setups is:
A ESXi server with a virtual Ubuntu server for Domoticz
An USB PCIe card assignet to the VM, witch have connected an UZB1 and RFXTRX443e¨
Also a Milight bridge on Wifi.
This is what I want to do:
Create a new VM
Install an OS and HA
Try it and test if it is somthing i want to contunue to use
If i do, i will migrate my hardware USB devices to it.
So, with OS is best for future easy maintenance? And how to install it?
I must say, even if I use Linux server I am really not a poweruser. so I deeply rely on step-by-step guides for the most part.
Tinkerer
(aka DubhAd on GitHub)
April 11, 2018, 8:36pm
2
Best is subjective - there is no “best”, there are just trade offs.
Based on what you’ve said, probably you’ll find Hass.io the simplest, since it’s self contained. You’d want to perform a base install of a Linux distro of your choice (Alpine Linux or Debian, or whatever suits you), then follow the advanced install guide .
Alternatively, install your Linux distro of choice, then follow the manual install guide for the Raspberry Pi.
Thanks, waiting the “20 minutes” now.
This is the commands I used, seems to work.
sudo apt-get update
sudo apt-get upgrade
sudo apt-get install docker.io
sudo apt-get install socat
sudo apt-get install jq
sudo apt-get install avahi-daemon
sudo su -
curl -sL https://raw.githubusercontent.com/home-assistant/hassio-build/master/install/hassio_install | bash -s
Tinkerer:
Alpine Linux
Unless something has changed in the last couple of months, hassio script won’t install on Alpine.
You don’t want docker.io . You want docker-ce
why? (and is it to late to install it now?)
Did a reinstall of the VM and installed with these commands, works:
sudo apt-get update
sudo apt-get update
sudo apt-get install apt-transport-https
sudo apt-get install ca-certificates
sudo apt-get install curl
sudo apt-get install software-properties-common
curl -fsSL https://download.docker.com/linux/ubuntu/gpg | sudo apt-key add -
sudo apt-key fingerprint 0EBFCD88
sudo add-apt-repository \
"deb [arch=amd64] https://download.docker.com/linux/ubuntu \
$(lsb_release -cs) \
stable"
sudo apt-get update
sudo apt-get install docker-ce
sudo docker run hello-world
sudo su -
now, how can I edit the configuration.yaml
