Hi.
So i have been using these flows on a few devices, Washing Machine , Tumble Dryer and even our Dehumidfier. Working really well. However my Mrs flagged something up on the Tumble dryer flow i am using. I have included the screenshots and the code below.
Basically when the tumble dryer is on there may be a time when she needs to open the door just to check the items in there. In order to do this on our Tumble dryer you have to press the stop button and then the door will open.
Now by pressing the stop button the flow thinks the dryer has finished and sends out an alert. I also have the tumble dryer turn off when its finished.
looking for suggestions on how to get around this. She needs to open the door for a minute or two and then close it and let it continue running with however much time was left.
[{"id":"d70babf0b4e7045c","type":"tab","label":"Tumble Dryer","disabled":false,"info":"","env":[]},{"id":"ebdeb25a504beb50","type":"group","z":"d70babf0b4e7045c","name":"(1) - Power Tumble Dryer Plug - ON","style":{"label":true},"nodes":["f1b4434958c4b1eb","c128054b5bf7dabb","c2bf45a675132751","f3303359a98f91c1","cd443263a621e49d","05a371a4e06d42c6","d91a2f64d62ddbb4","16ada49fda713724","08bbc8efbae28a97","19f87bcf152c08b2","3dfe49dd653d929b","8473923dfdccf62d"],"x":14,"y":19,"w":1692,"h":162},{"id":"3f03c686cde6d8c4","type":"group","z":"d70babf0b4e7045c","name":"(2) - Check if the tumble dryer is powered on or if a program is started","style":{"label":true},"nodes":["0a468116c2c8570f","5e8aacdffc98345c","5310e628b873fccd","b21b8eeebebd7cf6"],"x":14,"y":199,"w":852,"h":142},{"id":"9f27f87fbcfa4838","type":"group","z":"d70babf0b4e7045c","name":"(3) - Check if the tumble dryer is powered off or the program has finished","style":{"label":true},"nodes":["ef4c148392a71861","5a2ed2d3fdcc9ee1","7b65c6aaa76402e2","c8cba81fee5c8b7b","d860f4264f642734","d04b40f8cf816fc3"],"x":14,"y":359,"w":1142,"h":142},{"id":"dbc9af2f087c5d81","type":"group","z":"d70babf0b4e7045c","name":"(4) - Tumble Dryer is ready, send notifications","style":{"label":true},"nodes":["0354a679f4e86ac6","c79e15d147f8f098","f2fb06ac6e6ed09a","47933214991ea50b","2ba3fe63090fa71d","59b3d2339aa50c7f","d2e1a3ced2275ca6","6ddf513462eabbba","7412eed53af670b3","c3f4a9b6f2217074","02d9054696a19e2c","01df062007221902","8efb995d23eeecbe","4b417124ef74be30","3669d46796f84dfc","bff02d1a33725ce7"],"x":9,"y":519,"w":1277,"h":362},{"id":"c2fc039288c4e74c","type":"group","z":"d70babf0b4e7045c","name":"(5) - When tumble dryer door is opened and the washing program has runned, reset state to Idle","style":{"label":true},"nodes":["3b875ae0c12893ae","52a24d5723b07149","4a35e45ef108436f"],"x":14,"y":899,"w":732,"h":82},{"id":"a653e849e89b8b3a","type":"group","z":"d70babf0b4e7045c","name":"(6) - Pressed on stop button in the app of raising wash ready notifications?","style":{"label":true},"nodes":["b3560ffa00b4bba9","662eb4b7cdf1db91","8c1741eeee137d3d"],"x":14,"y":999,"w":752,"h":82},{"id":"4b417124ef74be30","type":"junction","z":"d70babf0b4e7045c","g":"dbc9af2f087c5d81","x":650,"y":760,"wires":[[]]},{"id":"f1b4434958c4b1eb","type":"server-state-changed","z":"d70babf0b4e7045c","g":"ebdeb25a504beb50","name":"Tumble Dryer Plug; ON","server":"7742f894.e9abc8","version":4,"exposeToHomeAssistant":false,"haConfig":[{"property":"name","value":""},{"property":"icon","value":""}],"entityidfilter":"input_boolean.tumble_dryer_bypass","entityidfiltertype":"exact","outputinitially":false,"state_type":"str","haltifstate":"on","halt_if_type":"str","halt_if_compare":"is","outputs":2,"output_only_on_state_change":true,"for":"0","forType":"num","forUnits":"minutes","ignorePrevStateNull":false,"ignorePrevStateUnknown":false,"ignorePrevStateUnavailable":false,"ignoreCurrentStateUnknown":false,"ignoreCurrentStateUnavailable":false,"outputProperties":[{"property":"payload","propertyType":"msg","value":"","valueType":"entityState"},{"property":"data","propertyType":"msg","value":"","valueType":"eventData"},{"property":"topic","propertyType":"msg","value":"","valueType":"triggerId"}],"x":140,"y":100,"wires":[["c128054b5bf7dabb"],["c2bf45a675132751"]]},{"id":"c128054b5bf7dabb","type":"api-call-service","z":"d70babf0b4e7045c","g":"ebdeb25a504beb50","name":"Tumble Dryer Plug: OFF","server":"7742f894.e9abc8","version":5,"debugenabled":false,"domain":"switch","service":"turn_on","areaId":[],"deviceId":[],"entityId":["switch.plug_laundry_tumble_dryer"],"data":"","dataType":"json","mergeContext":"","mustacheAltTags":false,"outputProperties":[],"queue":"none","x":430,"y":60,"wires":[["05a371a4e06d42c6"]]},{"id":"c2bf45a675132751","type":"api-call-service","z":"d70babf0b4e7045c","g":"ebdeb25a504beb50","name":"Tumble Dryer Plug: OFF","server":"7742f894.e9abc8","version":5,"debugenabled":false,"domain":"switch","service":"turn_off","areaId":[],"deviceId":[],"entityId":["switch.plug_laundry_tumble_dryer"],"data":"","dataType":"json","mergeContext":"","mustacheAltTags":false,"outputProperties":[],"queue":"none","x":430,"y":140,"wires":[["f3303359a98f91c1"]]},{"id":"f3303359a98f91c1","type":"api-render-template","z":"d70babf0b4e7045c","g":"ebdeb25a504beb50","name":"Anouncement","server":"7742f894.e9abc8","version":0,"template":"\n\"Tumble Dryer is now powered Off\"\n","resultsLocation":"payload","resultsLocationType":"msg","templateLocation":"template","templateLocationType":"msg","x":680,"y":140,"wires":[["16ada49fda713724"]]},{"id":"cd443263a621e49d","type":"api-call-service","z":"d70babf0b4e7045c","g":"ebdeb25a504beb50","name":"Alexa - Notification - Laundry","server":"7742f894.e9abc8","version":5,"debugenabled":false,"domain":"notify","service":"alexa_media_laundry","areaId":[],"deviceId":[],"entityId":[],"data":"","dataType":"json","mergeContext":"","mustacheAltTags":true,"outputProperties":[{"property":"payload","propertyType":"msg","value":"","valueType":"data"}],"queue":"none","output_location":"payload","output_location_type":"msg","x":1560,"y":100,"wires":[[]]},{"id":"05a371a4e06d42c6","type":"api-render-template","z":"d70babf0b4e7045c","g":"ebdeb25a504beb50","name":"Anouncement","server":"7742f894.e9abc8","version":0,"template":"\n\"Tumble Dryer is now powered On\"\n","resultsLocation":"payload","resultsLocationType":"msg","templateLocation":"template","templateLocationType":"msg","x":680,"y":60,"wires":[["d91a2f64d62ddbb4"]]},{"id":"d91a2f64d62ddbb4","type":"change","z":"d70babf0b4e7045c","g":"ebdeb25a504beb50","name":"Set Alexa Attributes","rules":[{"t":"set","p":"volume","pt":"flow","to":"0.2","tot":"str"},{"t":"set","p":"target","pt":"global","to":"media_player.office_echo_dot","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":880,"y":60,"wires":[["08bbc8efbae28a97"]]},{"id":"16ada49fda713724","type":"change","z":"d70babf0b4e7045c","g":"ebdeb25a504beb50","name":"Set Alexa Attributes","rules":[{"t":"set","p":"volume","pt":"flow","to":"0.2","tot":"str"},{"t":"set","p":"target","pt":"global","to":"media_player.office_echo_dot","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":880,"y":140,"wires":[["19f87bcf152c08b2"]]},{"id":"08bbc8efbae28a97","type":"function","z":"d70babf0b4e7045c","g":"ebdeb25a504beb50","name":"Create Alexa Alert","func":"\nvar target = global.get('target')\nvar message = msg.payload \n\nvar payload = \n{\n \"data\":\n {\n \"target\": `${target}`,\n \"message\": `${message}`\n }\n}\nmsg.payload = payload\nmsg.topic = `${target}`\nreturn msg","outputs":1,"noerr":0,"initialize":"","finalize":"","libs":[],"x":1090,"y":60,"wires":[["3dfe49dd653d929b"]]},{"id":"19f87bcf152c08b2","type":"function","z":"d70babf0b4e7045c","g":"ebdeb25a504beb50","name":"Create Alexa Alert","func":"\nvar target = global.get('target')\nvar message = msg.payload \n\nvar payload = \n{\n \"data\":\n {\n \"target\": `${target}`,\n \"message\": `${message}`\n }\n}\nmsg.payload = payload\nmsg.topic = `${target}`\nreturn msg","outputs":1,"noerr":0,"initialize":"","finalize":"","libs":[],"x":1090,"y":140,"wires":[["8473923dfdccf62d"]]},{"id":"3dfe49dd653d929b","type":"template","z":"d70babf0b4e7045c","g":"ebdeb25a504beb50","name":"Alexa device - Template","field":"payload","fieldType":"msg","format":"handlebars","syntax":"mustache","template":"{\n\"data\": \n {\n \"message\": \"{{ payload.data.message}}\",\n \"target\": \"{{ payload.data.target }}\",\n \"data\": {\n \"type\": \"tts\"\n }\n }\n} ","output":"json","x":1310,"y":60,"wires":[["cd443263a621e49d"]]},{"id":"8473923dfdccf62d","type":"template","z":"d70babf0b4e7045c","g":"ebdeb25a504beb50","name":"Alexa device - Template","field":"payload","fieldType":"msg","format":"handlebars","syntax":"mustache","template":"{\n\"data\": \n {\n \"message\": \"{{ payload.data.message}}\",\n \"target\": \"{{ payload.data.target }}\",\n \"data\": {\n \"type\": \"tts\"\n }\n }\n} ","output":"json","x":1310,"y":140,"wires":[["cd443263a621e49d"]]},{"id":"0a468116c2c8570f","type":"switch","z":"d70babf0b4e7045c","g":"3f03c686cde6d8c4","name":"Check power","property":"payload","propertyType":"msg","rules":[{"t":"gt","v":"1.0","vt":"num"},{"t":"gt","v":"10","vt":"num"}],"checkall":"true","repair":false,"outputs":2,"x":330,"y":260,"wires":[["5310e628b873fccd"],["b21b8eeebebd7cf6"]]},{"id":"5e8aacdffc98345c","type":"server-state-changed","z":"d70babf0b4e7045c","g":"3f03c686cde6d8c4","name":"Tumble Dryer Power","server":"7742f894.e9abc8","version":4,"exposeToHomeAssistant":false,"haConfig":[{"property":"name","value":""},{"property":"icon","value":""}],"entityidfilter":"sensor.plug_laundry_tumble_dryer_power","entityidfiltertype":"exact","outputinitially":true,"state_type":"num","haltifstate":"","halt_if_type":"str","halt_if_compare":"is","outputs":1,"output_only_on_state_change":true,"for":"0","forType":"num","forUnits":"minutes","ignorePrevStateNull":false,"ignorePrevStateUnknown":false,"ignorePrevStateUnavailable":false,"ignoreCurrentStateUnknown":false,"ignoreCurrentStateUnavailable":false,"outputProperties":[{"property":"payload","propertyType":"msg","value":"","valueType":"entityState"},{"property":"data","propertyType":"msg","value":"","valueType":"eventData"},{"property":"topic","propertyType":"msg","value":"","valueType":"triggerId"}],"x":130,"y":260,"wires":[["0a468116c2c8570f"]]},{"id":"5310e628b873fccd","type":"api-call-service","z":"d70babf0b4e7045c","g":"3f03c686cde6d8c4","name":"> 1 watt --> Set power state of Tumble Dryer to on","server":"7742f894.e9abc8","version":5,"debugenabled":false,"domain":"input_boolean","service":"turn_on","areaId":[],"deviceId":[],"entityId":["input_boolean.tumble_dryer_on"],"data":"","dataType":"json","mergeContext":"","mustacheAltTags":false,"outputProperties":[],"queue":"none","x":650,"y":240,"wires":[[]]},{"id":"b21b8eeebebd7cf6","type":"api-call-service","z":"d70babf0b4e7045c","g":"3f03c686cde6d8c4","name":"> 10 watt --> Set Tumble Dryer state running","server":"7742f894.e9abc8","version":5,"debugenabled":false,"domain":"input_select","service":"select_option","areaId":[],"deviceId":[],"entityId":["input_select.tumble_dryer_status"],"data":"{\"option\":\"Running\"}","dataType":"jsonata","mergeContext":"","mustacheAltTags":false,"outputProperties":[],"queue":"none","x":630,"y":300,"wires":[[]]},{"id":"ef4c148392a71861","type":"server-state-changed","z":"d70babf0b4e7045c","g":"9f27f87fbcfa4838","name":"Tumble Dryer Power <= 2 for 15 sec?","server":"7742f894.e9abc8","version":4,"exposeToHomeAssistant":false,"haConfig":[{"property":"name","value":""},{"property":"icon","value":""}],"entityidfilter":"sensor.plug_laundry_tumble_dryer_power","entityidfiltertype":"exact","outputinitially":true,"state_type":"num","haltifstate":"2","halt_if_type":"num","halt_if_compare":"lte","outputs":2,"output_only_on_state_change":true,"for":"15","forType":"num","forUnits":"seconds","ignorePrevStateNull":false,"ignorePrevStateUnknown":false,"ignorePrevStateUnavailable":false,"ignoreCurrentStateUnknown":false,"ignoreCurrentStateUnavailable":false,"outputProperties":[{"property":"payload","propertyType":"msg","value":"","valueType":"entityState"},{"property":"data","propertyType":"msg","value":"","valueType":"eventData"},{"property":"topic","propertyType":"msg","value":"","valueType":"triggerId"}],"x":190,"y":400,"wires":[["7b65c6aaa76402e2"],[]]},{"id":"5a2ed2d3fdcc9ee1","type":"server-state-changed","z":"d70babf0b4e7045c","g":"9f27f87fbcfa4838","name":"Tumble Dryer Power == 1 for 5 sec?","server":"7742f894.e9abc8","version":4,"exposeToHomeAssistant":false,"haConfig":[{"property":"name","value":""},{"property":"icon","value":""}],"entityidfilter":"sensor.plug_laundry_tumble_dryer_power","entityidfiltertype":"exact","outputinitially":true,"state_type":"num","haltifstate":"1","halt_if_type":"num","halt_if_compare":"lte","outputs":2,"output_only_on_state_change":false,"for":"5","forType":"num","forUnits":"seconds","ignorePrevStateNull":false,"ignorePrevStateUnknown":false,"ignorePrevStateUnavailable":false,"ignoreCurrentStateUnknown":false,"ignoreCurrentStateUnavailable":false,"outputProperties":[{"property":"payload","propertyType":"msg","value":"","valueType":"entityState"},{"property":"data","propertyType":"msg","value":"","valueType":"eventData"},{"property":"topic","propertyType":"msg","value":"","valueType":"triggerId"}],"x":180,"y":460,"wires":[["d04b40f8cf816fc3"],[]]},{"id":"7b65c6aaa76402e2","type":"api-current-state","z":"d70babf0b4e7045c","g":"9f27f87fbcfa4838","name":"Has the Tumble Dryer been running?","server":"7742f894.e9abc8","version":3,"outputs":2,"halt_if":"Running","halt_if_type":"str","halt_if_compare":"is","entity_id":"input_select.tumble_dryer_status","state_type":"str","blockInputOverrides":false,"outputProperties":[{"property":"payload","propertyType":"msg","value":"","valueType":"entityState"},{"property":"data","propertyType":"msg","value":"","valueType":"entity"}],"for":0,"forType":"num","forUnits":"minutes","x":530,"y":400,"wires":[["d860f4264f642734"],[]]},{"id":"c8cba81fee5c8b7b","type":"link out","z":"d70babf0b4e7045c","g":"9f27f87fbcfa4838","name":"Tumble Dryer ready notifications","mode":"link","links":["47933214991ea50b"],"x":1115,"y":400,"wires":[]},{"id":"d860f4264f642734","type":"api-call-service","z":"d70babf0b4e7045c","g":"9f27f87fbcfa4838","name":"Set state to Dry","server":"7742f894.e9abc8","version":5,"debugenabled":false,"domain":"input_select","service":"select_option","areaId":[],"deviceId":[],"entityId":["input_select.tumble_dryer_status"],"data":"{\"option\":\"Dry\"}","dataType":"json","mergeContext":"","mustacheAltTags":false,"outputProperties":[],"queue":"none","x":880,"y":400,"wires":[["c8cba81fee5c8b7b"]]},{"id":"d04b40f8cf816fc3","type":"api-call-service","z":"d70babf0b4e7045c","g":"9f27f87fbcfa4838","name":"Set power state of Tumble Dryer to off","server":"7742f894.e9abc8","version":5,"debugenabled":false,"domain":"input_boolean","service":"turn_off","areaId":[],"deviceId":[],"entityId":["input_boolean.tumble_dryer_on"],"data":"","dataType":"json","mergeContext":"","mustacheAltTags":false,"outputProperties":[],"queue":"none","x":530,"y":460,"wires":[["7b65c6aaa76402e2"]]},{"id":"0354a679f4e86ac6","type":"delay","z":"d70babf0b4e7045c","g":"dbc9af2f087c5d81","name":"","pauseType":"rate","timeout":"5","timeoutUnits":"seconds","rate":"1","nbRateUnits":"30","rateUnits":"minute","randomFirst":"1","randomLast":"5","randomUnits":"seconds","drop":true,"allowrate":false,"outputs":1,"x":240,"y":600,"wires":[["2ba3fe63090fa71d"]]},{"id":"c79e15d147f8f098","type":"api-current-state","z":"d70babf0b4e7045c","g":"dbc9af2f087c5d81","name":"Is state Dry?","server":"7742f894.e9abc8","version":3,"outputs":2,"halt_if":"Dry","halt_if_type":"str","halt_if_compare":"is","entity_id":"input_select.tumble_dryer_status","state_type":"str","blockInputOverrides":false,"outputProperties":[{"property":"payload","propertyType":"msg","value":"","valueType":"entityState"},{"property":"data","propertyType":"msg","value":"","valueType":"entity"}],"for":0,"forType":"num","forUnits":"minutes","x":630,"y":600,"wires":[["3669d46796f84dfc","8efb995d23eeecbe"],["f2fb06ac6e6ed09a"]]},{"id":"f2fb06ac6e6ed09a","type":"change","z":"d70babf0b4e7045c","g":"dbc9af2f087c5d81","name":"Stop","rules":[{"t":"set","p":"payload","pt":"msg","to":"stop","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":500,"y":680,"wires":[["2ba3fe63090fa71d"]]},{"id":"47933214991ea50b","type":"link in","z":"d70babf0b4e7045c","g":"dbc9af2f087c5d81","name":"","links":["c8cba81fee5c8b7b"],"x":50,"y":600,"wires":[["0354a679f4e86ac6"]]},{"id":"2ba3fe63090fa71d","type":"looptimer","z":"d70babf0b4e7045c","g":"dbc9af2f087c5d81","duration":"30","units":"Minute","maxloops":"5","maxtimeout":"1","maxtimeoutunits":"Hour","name":"","x":440,"y":600,"wires":[["c79e15d147f8f098"],[]]},{"id":"59b3d2339aa50c7f","type":"api-render-template","z":"d70babf0b4e7045c","g":"dbc9af2f087c5d81","name":"Anouncement","server":"7742f894.e9abc8","version":0,"template":"\n\"Tumble Dryer is finished\"\n","resultsLocation":"payload","resultsLocationType":"msg","templateLocation":"template","templateLocationType":"msg","x":1180,"y":740,"wires":[["c3f4a9b6f2217074"]]},{"id":"d2e1a3ced2275ca6","type":"api-call-service","z":"d70babf0b4e7045c","g":"dbc9af2f087c5d81","name":"Alexa - Notification - Living Room","server":"7742f894.e9abc8","version":5,"debugenabled":false,"domain":"notify","service":"alexa_media_craig_s_fire_tv_cube","areaId":[],"deviceId":[],"entityId":[],"data":"","dataType":"jsonata","mergeContext":"","mustacheAltTags":false,"outputProperties":[],"queue":"none","x":320,"y":840,"wires":[[]]},{"id":"6ddf513462eabbba","type":"template","z":"d70babf0b4e7045c","g":"dbc9af2f087c5d81","name":"Alexa device - Template","field":"payload","fieldType":"msg","format":"handlebars","syntax":"mustache","template":"{\n\"data\": \n {\n \"message\": \"{{ payload.data.message}}\",\n \"target\": \"{{ payload.data.target }}\",\n \"data\": {\n \"type\": \"tts\"\n }\n }\n} ","output":"json","x":740,"y":780,"wires":[["01df062007221902","02d9054696a19e2c","d2e1a3ced2275ca6"]]},{"id":"7412eed53af670b3","type":"function","z":"d70babf0b4e7045c","g":"dbc9af2f087c5d81","name":"Create Alexa Alert","func":"\nvar target = global.get('target')\nvar message = msg.payload \n\nvar payload = \n{\n \"data\":\n {\n \"target\": `${target}`,\n \"message\": `${message}`\n }\n}\nmsg.payload = payload\nmsg.topic = `${target}`\nreturn msg","outputs":1,"noerr":0,"initialize":"","finalize":"","libs":[],"x":480,"y":780,"wires":[["6ddf513462eabbba"]]},{"id":"c3f4a9b6f2217074","type":"change","z":"d70babf0b4e7045c","g":"dbc9af2f087c5d81","name":"Set Alexa Attributes","rules":[{"t":"set","p":"volume","pt":"flow","to":"0.4","tot":"str"},{"t":"set","p":"target","pt":"global","to":"media_player.office_echo_dot","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":240,"y":780,"wires":[["7412eed53af670b3"]]},{"id":"02d9054696a19e2c","type":"api-call-service","z":"d70babf0b4e7045c","g":"dbc9af2f087c5d81","name":"Alexa - Notification - Bedroom","server":"7742f894.e9abc8","version":5,"debugenabled":false,"domain":"notify","service":"alexa_media_bedroom","areaId":[],"deviceId":[],"entityId":[],"data":"","dataType":"jsonata","mergeContext":"","mustacheAltTags":false,"outputProperties":[],"queue":"none","x":680,"y":840,"wires":[[]]},{"id":"01df062007221902","type":"api-call-service","z":"d70babf0b4e7045c","g":"dbc9af2f087c5d81","name":"Alexa - Notification - Office","server":"7742f894.e9abc8","version":5,"debugenabled":false,"domain":"notify","service":"alexa_media_office_show","areaId":[],"deviceId":[],"entityId":[],"data":"","dataType":"jsonata","mergeContext":"","mustacheAltTags":false,"outputProperties":[],"queue":"none","x":1020,"y":840,"wires":[[]]},{"id":"8efb995d23eeecbe","type":"api-call-service","z":"d70babf0b4e7045c","g":"dbc9af2f087c5d81","name":"Tumble Dryer: Turn OFF","server":"7742f894.e9abc8","version":5,"debugenabled":false,"domain":"input_boolean","service":"turn_off","areaId":[],"deviceId":[],"entityId":["input_boolean.tumble_dryer_bypass"],"data":"","dataType":"json","mergeContext":"","mustacheAltTags":false,"outputProperties":[],"queue":"none","x":950,"y":640,"wires":[[]]},{"id":"3669d46796f84dfc","type":"api-call-service","z":"d70babf0b4e7045c","g":"dbc9af2f087c5d81","name":"Send notify - Craig","server":"7742f894.e9abc8","version":5,"debugenabled":false,"domain":"notify","service":"mobile_app_craigs_iphone","areaId":[],"deviceId":[],"entityId":[],"data":"{\"message\":\" The Tumble Dryer is finished\",\"title\":\"Tumble Dryer\",\"data\":{\"actions\":[{\"action\":\"RESET_WAS_READY_MESSAGE\",\"title\":\" Ignore message\"}]}}","dataType":"json","mergeContext":"","mustacheAltTags":false,"outputProperties":[],"queue":"none","x":900,"y":560,"wires":[["bff02d1a33725ce7"]]},{"id":"bff02d1a33725ce7","type":"api-call-service","z":"d70babf0b4e7045c","g":"dbc9af2f087c5d81","name":"Send notify - Lizzie","server":"7742f894.e9abc8","version":5,"debugenabled":false,"domain":"notify","service":"mobile_app_lizzie_iphone","areaId":[],"deviceId":[],"entityId":[],"data":"{\"message\":\" The Tumble Dryer is finished\",\"title\":\"Tumble Dryer\",\"data\":{\"actions\":[{\"action\":\"RESET_WAS_READY_MESSAGE\",\"title\":\" Ignore message\"}]}}","dataType":"json","mergeContext":"","mustacheAltTags":false,"outputProperties":[],"queue":"none","x":1140,"y":560,"wires":[["59b3d2339aa50c7f"]]},{"id":"3b875ae0c12893ae","type":"api-current-state","z":"d70babf0b4e7045c","g":"c2fc039288c4e74c","name":"State is Dry?","server":"7742f894.e9abc8","version":3,"outputs":2,"halt_if":"Dry","halt_if_type":"str","halt_if_compare":"is","entity_id":"input_select.tumble_dryer_status","state_type":"str","blockInputOverrides":false,"outputProperties":[{"property":"payload","propertyType":"msg","value":"","valueType":"entityState"},{"property":"data","propertyType":"msg","value":"","valueType":"entity"}],"for":0,"forType":"num","forUnits":"minutes","x":410,"y":940,"wires":[["4a35e45ef108436f"],[]]},{"id":"52a24d5723b07149","type":"server-state-changed","z":"d70babf0b4e7045c","g":"c2fc039288c4e74c","name":"Door Tumble Dryer opened?","server":"7742f894.e9abc8","version":4,"exposeToHomeAssistant":false,"haConfig":[{"property":"name","value":""},{"property":"icon","value":""}],"entityidfilter":"binary_sensor.contact_sensor_laundry_tumble_dryer_door_contact","entityidfiltertype":"exact","outputinitially":false,"state_type":"str","haltifstate":"on","halt_if_type":"str","halt_if_compare":"is","outputs":2,"output_only_on_state_change":true,"for":"0","forType":"num","forUnits":"minutes","ignorePrevStateNull":false,"ignorePrevStateUnknown":false,"ignorePrevStateUnavailable":false,"ignoreCurrentStateUnknown":false,"ignoreCurrentStateUnavailable":false,"outputProperties":[{"property":"payload","propertyType":"msg","value":"","valueType":"entityState"},{"property":"data","propertyType":"msg","value":"","valueType":"eventData"},{"property":"topic","propertyType":"msg","value":"","valueType":"triggerId"}],"x":160,"y":940,"wires":[["3b875ae0c12893ae"],[]]},{"id":"4a35e45ef108436f","type":"api-call-service","z":"d70babf0b4e7045c","g":"c2fc039288c4e74c","name":"Set state to Idle","server":"7742f894.e9abc8","version":5,"debugenabled":false,"domain":"input_select","service":"select_option","areaId":[],"deviceId":[],"entityId":["input_select.tumble_dryer_status"],"data":"{\"option\":\"Idle\"}","dataType":"json","mergeContext":"","mustacheAltTags":false,"outputProperties":[],"queue":"none","x":640,"y":940,"wires":[[]]},{"id":"b3560ffa00b4bba9","type":"switch","z":"d70babf0b4e7045c","g":"a653e849e89b8b3a","name":"Stop message wash ready?","property":"payload.event.action","propertyType":"msg","rules":[{"t":"eq","v":"RESET_WAS_READY_MESSAGE","vt":"str"}],"checkall":"true","repair":false,"outputs":1,"x":380,"y":1040,"wires":[["8c1741eeee137d3d"]]},{"id":"662eb4b7cdf1db91","type":"server-events","z":"d70babf0b4e7045c","g":"a653e849e89b8b3a","name":"Notify app action","server":"7742f894.e9abc8","version":2,"eventType":"mobile_app_notification_action","exposeToHomeAssistant":false,"eventData":"","haConfig":[{"property":"name","value":""},{"property":"icon","value":""}],"waitForRunning":true,"outputProperties":[{"property":"payload","propertyType":"msg","value":"","valueType":"eventData"},{"property":"topic","propertyType":"msg","value":"$outputData(\"eventData\").event_type","valueType":"jsonata"}],"event_type":"","x":120,"y":1040,"wires":[["b3560ffa00b4bba9"]]},{"id":"8c1741eeee137d3d","type":"api-call-service","z":"d70babf0b4e7045c","g":"a653e849e89b8b3a","name":"Set state to Idle","server":"7742f894.e9abc8","version":5,"debugenabled":false,"domain":"input_select","service":"select_option","areaId":[],"deviceId":[],"entityId":["input_select.tumble_dryer_status"],"data":"{\"option\":\"Idle\"}","dataType":"json","mergeContext":"","mustacheAltTags":false,"outputProperties":[],"queue":"none","x":660,"y":1040,"wires":[[]]},{"id":"7742f894.e9abc8","type":"server","name":"Home Assistant","version":5,"addon":true,"rejectUnauthorizedCerts":true,"ha_boolean":"y|yes|true|on|home|open","connectionDelay":true,"cacheJson":true,"heartbeat":false,"heartbeatInterval":30,"areaSelector":"friendlyName","deviceSelector":"friendlyName","entitySelector":"friendlyName","statusSeparator":"at: ","statusYear":"hidden","statusMonth":"short","statusDay":"numeric","statusHourCycle":"h23","statusTimeFormat":"h:m","enableGlobalContextStore":true}]
