I would argue with that. If you install HA using docker the best way to go on Linux like Ubuntu, because it is harder to configure network from Windows based host. But if you install ubuntu what is the difference with HA OS? None. HA OS also based on Docker with advantage to automate install and update more. You can the same way SSH to your HA OS and run and configure any additional Docker container.
How Ubuntu instalation is different form HA OS if you will not use GUI?
