Great thanks for your reply. From looking, it seems to be WiFi based. So you are saying that you use it to emit MQTT events that your then translate into zigbee commands usign Z2M?
Unfortunately I am using ZHA so that may well be a no-go for me but I am sure its a useful pointer for visitors to this thread.
Do you know of any guides on how to configure #6 on the MINIR4?
I’ve had good success with GE / Enbrighten Zigbee switches: https://ezzigbee.com
In particular, I’ve bound two switches directly together so toggling one toggles the other. As well, I have one switch bound to a Sengled plug to turn on a china cabinet’s lights when the dining room light goes on: Sengled E1C-NB7 control via MQTT | Zigbee2MQTT
I’m using zigbee2mqtt, but I don’t see why this wouldn’t work with ZHA either.
I’ve had mixed success with direct binding in general. For example, I have a Sengled bulb that responds to on and dimming commands, but not off. I think many manufacturers don’t test direct binding at all.
Thanks for this, on reading the website it’s not clear of these are ZigBee controlled switches. Or mains-powered ZigBee controllers. I.e do the cut power to the light fixture? How do they work with ZigBee smart bulbs?
Which of the six points in the OP do they satisfy?
They work with regular light bulbs and cut power to the fixture. It’s much cheaper than bulbs, especially for fixtures like chandeliers that have many bulbs. I wouldn’t recommend them for smart bulbs. Instead, leave a regular switch but put something like this to ensure people don’t turn them off.
I fear you haven’t read my original post. I’m looking for ZigBee controllers, and to only trigger the relay if the ZigBee/HA network fails.
N.B it looks as if the Aqara H1 could satisfy many of these requirements as when integrated via Zigbee2MQTT it has a decouple option that stops the button presses triggering the relay.
Emit zigbee events that can be used to control a zigbee smart bulb
Emit dimming events that can be used to control a zigbee smart bulb
Directly bind a good number of bulbs so that operation will continue if HA goes down
Is mains/neutral powered
Is cheap £34.99
Has a fallback mode so that if it does not successfully trigger the bulb it triggers a relay. (Fallback to dumb) (but can be switched from de-coupled to coupled via home assistant)
If you’ve read that thread, you’ve probably seen my post towards the bottom.
The Aqara Z1 Pro seems to fulfil all your requirements except 5 & 6.
I’m considering it not cheap purely because it’s around €70 for a 4-gang version, but considering you get twice the switches and a slider compared to the T2, it works out to be the same price.
You can forget about 6 on any zigbee device. It’s a feature which doesn’t exist so far.
I don’t have one yet (got impatient waiting for it to be supported and bought a bunch of H1Ms), but it should. At the very least, you should be able to get on/off control via direct binding.
The bad news is that I can’t seem to find anyone selling it apart from a site in Singapore. You might have to be a bit more patient than I was and wait for it to start showing up on other sites.
