Best way to template definitions of MQTT 433MHz temp/humid sensors?
as per this discussion it’s not always possible because of high power consumption and difficulty of deep sleep stuff.
I did it quite straightforward. This bit is specific to RFLink that creates sensors with generated names.
# it uses the fact that rflink creates sensor.xxx_update_time
# and updates its value every time new readings (_temp and _hum) arrive
# so we can find out the original sensors' names
# and copy their values into the target sensors (all temperature, humidity and update_time)
# that means the target sensors are updated every time, not only when it's changed!
- alias: sensor_thb_rflink_route_value_to_entity
    platform: state
    entity_id:
      - sensor.dummy_update_time
      # reception
      # lounge
      # kitchen
    service: python_script.sensor_thb_rflink_route_value_to_entity
    data_template:
      object_id : "{{ trigger.to_state.object_id }}"
      value     : "{{ trigger.to_state.state }}"
and then
arg                     = 'object_id'
object_id               = data.get(arg)
assert object_id, "Please specify %s!" % arg
arg                     = 'value'
value                   = data.get(arg)
assert value, "Please specify %s!" % arg
arg                     = 'force_update'
force_update            = data.get(arg, 'True').lower() == 'true'
update_time_suffix      = '_update_time'
# figure out the base name if the sensor from object_id
base_object_id = object_id.replace(update_time_suffix, '')
known_sensors = {
    'prologue_97b0' : 'rflink_ground_floor_reception',
    'prologue_9100' : 'rflink_ground_floor_lounge',
    'prologue_9440' : 'rflink_ground_floor_kitchen'
if base_object_id in known_sensors:
    cmd                     = 'set_state'
    attr_entity_id          = 'entity_id'
    attr_state              = 'state'
    all_siffixes            = {
        'temp': 'temperature',
        'hum': 'humidity'
    for source_suffix, target_suffix in all_siffixes.items():
        source_entity_id = "sensor.{}_{}".format(base_object_id, source_suffix)
        source_object = hass.states.get(source_entity_id)
        assert source_object, "Cannot find %s" % source_entity_id
        source_value = source_object.state
        target_entity_id = "sensor.{}_{}".format(known_sensors[base_object_id], target_suffix)
        # update state only if it's different
        if not force_update:
            target_object = hass.states.get(target_entity_id)
            assert target_object, "Cannot find %s" % target_entity_id
            targer_value = target_object.state
            if source_value == targer_value:
                logger.debug("%s: state (%s) is the same, not updating", target_entity_id, source_value)
                continue
        logger.debug("%s(%s: %s, %s: %s)", cmd, attr_entity_id, target_entity_id, attr_state, source_value)
        hass.services.call('python_script', cmd, {attr_entity_id: target_entity_id, attr_state: source_value} )
    # and finally set state of the target _update_time sensor as we have the source value already and it should be always updated (as it's always different)
    target_entity_id = "sensor.{}{}".format(known_sensors[base_object_id], update_time_suffix)
    logger.debug("%s(%s: %s, %s: %s)", cmd, attr_entity_id, target_entity_id, attr_state, value)
    hass.services.call('python_script', cmd, {attr_entity_id: target_entity_id, attr_state: value} )
else:
    logger.warning("sensor.%s not configured", base_object_id)
With OMG Pilight it’s slightly easier as I only need to add a new ID to a python script
id          = int(float(data.get('id', -1)))
temperature = data.get('temperature')
humidity    = data.get('humidity')
battery     = data.get('battery')
known_entities = {
    39      : 'ground_floor_reception',
    16      : 'ground_floor_lounge',
    68      : 'ground_floor_kitchen'
if id in known_entities.keys():
    hass.services.call(
        'python_script',
        'sensor_thb_pilight_set_values',
            'object_id_prefix' : "sensor_pilight_{}_".format(known_entities[id]),
            'temperature'   : temperature,
            'humidity'      : humidity,
            'battery'       : battery
else:
    logger.warning("id %i not configured", id)
