Yep, i have my own integration over mqtt (based on rave’s old code), but if it supported in api - it will be soon in HA component =)
It didn’t support playing files by url - only uploaded via mi home (when you upload this file it takes an internal ID and you can play sounds by id only - not url).
I’m not familiar with synology DSM capabilities, but you might be able to create the dir and copy files via the GUI.
Or maybe if you mount the homeassistant dir via SMB?
Then you could download the ZIP of raves github and copy the files like that?
Wow - I was just tinkering the install with this, I was sure I was going to fluff it up.
Worked first go. Very chuffed!
I have 1x gateway, 3x motion sensors, 4x temp sensors, 5x door sensors.
Things I would love to see:
Door/window sensors - they should report as open/closed - not on/off
Motion sensors:
would be great to see the time of motion last detected
it’s a confusing label to say a sensor is “off” - I would love to come up with a more accurate term
Battery usage - awesome! I can’t even find that in the Mi home UI!
I think a killer item would be to estimate battery life - how many sensor hours per 1% of battery charge?
I would love to see some idea on how to integrate the gateway and sensors into an alarm panel - perhaps the “Manual Alarm” example in the components gallery?
I do see some funny things - nothing concrete - just delays or dropouts - nothing serious mind - but they might cause a pickle in the event of creating an alarm system.
I can see myself using more of the motion and door sensors - so ridiculously easy! Battery usage - has anyone had their sensors go flat yet? How long is the life of these babies?
Thanks again to the devs on this one - bloody great work.
Hi everybody! I follow you and this topic is great.
I’m such a beginner but I learn about you day by day. I’m quite interested in Xiaomi Gateway integration.
I updated custom_components folders with @Danielhiversen modified folder but I can’t see battery atribute in HA. Anyone knows why?
Can I do anything useful with a V1 gateway?
I mistakenly purchased a V1 gateway in the GW+Sensor pack.
I subsequently bought a V2 gw and and using all the sensors from the pack, leaving me with a redundant V1 GW.
I’d like to do something with it, but as far as I can tell there is no way to enable any form of API on the V1 - e.g. to use the light/sensor/audio (currently light and audio only supported in the API)
I expect I will ebay it, but just checking before I do…
Okay we should definitly get a plan here as to which repo we should use. @Danielhiversen are you planning on integrating your repo into ha at some point? I am currently on raves repo but I am not sure if I should switch to yours and I think this is unnecessary ground for confusion at the moment.
