I am getting errors with this component. Is it still working for anyone else ins 84.1?
Error loading custom_components.binary_sensor.device_tracker_sensor. Make sure all dependencies are installed
Yes, I got the same error message. The original custom component code contains an import statement that is not actually required.
To fix this, find file device_tracker_sensor.py in your custom_components folder, and remove (or comment out) the following line:
from homeassistant.helpers.restore_state import async_get_last_state
thanks for the tip! just made my config useable again
as the original (from the first post) url gives me 404 - is there any place on github where this component is being kept and developed? my search failed, and just thought that it would be nice to have āthe original sourceā on the web just in case.
It is here: https://github.com/abmantis/homeassistant-custom-components/tree/master/others/binary_sensor
Iāve not updated it to 0.84 yet.
great, thanks!
Thank you for sharing the fix. Much appreciated
You really should submit a PR for this. It is a GREAT component.
It wonāt be accepted since this can already be done with templates (in a more tedious way, but still).
I use templates in my setup to accomplish what this custom component does (found my way here while exploring Home Assistant configs on github). Itās really about the same amount of effort, since you list the device trackers for either one? Sure thereās some extra values set for the template, but itās mostly copy paste between them (I have one set up for each of my cameras).
Using binary_sensor template platform:
sensors:
int_dome_01:
device_class: connectivity
entity_id: device_tracker.camera_interior_01
friendly_name: Int Cam 01
value_template: "{{ is_state('device_tracker.camera_interior_01', 'home') }}"
icon_template: mdi:cctv
iāve get this error on check configuration on home assistant 0.92.0:
General Errors:
Iāve get this error with add-on check configuration. How resolve this?
I am also getting the same error after updating just now to 0.92.0 from 0.91.4
Maybe this is the fix ? Will try later.
Iāve added the missing file for this custom_component to the github repo. Please download the component with the new folder structure.
To help others I downloaded the whole file from here it is under āhomeassistant-custom-components/others/device_tracker_sensor/ā
I copied both the new init file and binary_sensors.py file over but the built in checker kept running and running but was ok via CLI (this could be just related to my HA instance). I restarted HA from CLI ācore-ssh:~# hassio ha restartā and all seems to be working as usual
Since the restart the built in checker now runs fine - weird
Hi abmantis,
iām using your great component for a long time but now with the new version 0.110 it doesnāt work anymore.
Logger: homeassistant.components.binary_sensor
Source: components/binary_sensor/__init__.py:174
Integration: BinƤrsensor ([documentation](https://www.home-assistant.io/integrations/binary_sensor)
First occurred: 25. Mai 2020, 19:39:17 (1 occurrences)
Last logged: 25. Mai 2020, 19:39:17
BinarySensorDevice is deprecated, modify DeviceTrackerSensor to extend BinarySensorEntity
do you still maintain this competent?
Greetings,
El Grande
Hey,
I was hopping someone could submit a PR to fix it, I donāt think the change is too hard but I havenāt been able to find the time to do it.
So this aint working anymore for me as of 0.118.0. But the results can still be obtained by creating regular binary_sensors.
platform: template
sensors:
device_tracker_devicename_a:
entity_id:
- device_tracker.devicename_a
value_template: '{% if states.device_tracker.devicename_a %}
{% if states.device_tracker.devicename_a.state == "home" %}
On
{% else %}
Off
{% endif %}
{% else %}
n/a
{% endif %}'
device_tracker_devicename_b:
entity_id:
- device_tracker.devicename_b
value_template: '{% if states.device_tracker.devicename_b %}
{% if states.device_tracker.devicename_b.state == "home" %}
On
{% else %}
Off
{% endif %}
{% else %}
n/a
{% endif %}'
This will return On / Off / n/a depending if state is home/away/unresolvable.
Will also have to specify binary_sensor data in customization.
binary_sensor.device_tracker_devicename_a:
icon: mdi:icon-for-device-a
friendly_name: Device A
binary_sensor.device_tracker_devicename_b:
icon: mdi:icon-for-device-b
friendly_name: Device B
