BHT-6000 Thermostat (tuya) support
Hi all
I flashed the Thermostat with the tuya-convert and it was good. The only thing I’m not sure I did it correctly is I simply downloaded the tuya-convert package and used to flash the device right away, I didn’t replace anything before flashing. Now the device is running the Tasmota firmware but not sure how to proceed further. Should I re-flash it using tuya-convert and replace the /files/ folder with the firmware or can I upload the right firmware straight from Tasmota now ?
