BHT-6000 Thermostat (tuya) support
Mosquito separato da home-assistant
ah e come mai?? ti paice di piu? ha senso?
ho risolto anke io con la nuova versione del termostato.
/OT
Avevo già il broker mqtt prima di home-assistant, poi, se non ricordo male, quando passai ad hass non era previsto ancora il broker interno.
Ciao,
sai mica dirmi se funziona anche con BHT-8000
Non saprei, ho provato solo il 6000
I have a error:
Platform error climate.localtuya - cannot import name ‘STATE_AUTO’ from ‘homeassistant.components.climate’ (/usr/src/homeassistant/homeassistant/components/climate/init.py)
Can you help?
Maybe you have script, that read schedule values from Mqtt topic?
Any other way to make the connection?
a me non mi riesce farlo andare con MQTT??
cosa cavolo non gli piace?
Hello I wanted to inform everyone that there is a custom component compatible with many tuya thermostats, I recently also had the developer add the BHT-6000. the repo is this https://github.com/make-all/tuya-local
Italiano:
Ciao volevo informare tutti che esiste un custom component compatibile con molti termostati tuya, io da poco ho fatto anche aggiungere il BHT-6000 dallo sviluppatore. la repo è questa https://github.com/make-all/tuya-local
Did you test BHT-6000 thermostat with this custom component? Or did it someone else? It works well?
Yes i have bht-6000 and works good with this custom component
Man awesome, you saved my life! I spent the last 2 days trying to config my thermostat in hass by customizing the config made by Fraschi (without having any knowledge). Fortunately my thermostat works the same way as yours so I only had to copy and paste. Now it finally works
For me the best way is this without flashing firmware
Hello I wanted to inform everyone that there is a custom component compatible with many tuya thermostats, I recently also had the developer add the BHT-6000. the repo is this GitHub - make-all/tuya-local: Local support for Tuya devices in Home Assistant 8
Hi, I’m using the BHT-6000 via old tuya and everything is ok, but I would like to disconnect from the cloud. Just one thing: this custom component does not allow me to interact with the thermostat, but it behaves, more or less like the new official integration: like shit xD.
Could you share a step by step (even if honestly everything is quite straightforward) and any configurations? Thanks a lot.
Ciao, sto usando il BHT-6000 via old tuya ed è tutto ok, ma vorrei sganciarmi dal cloud.
Solo che questo custom component non mi permette di interagire con il termostato, ma si comporta, più o meno come l’integrazione ufficiale nuova: una merda xD.
Potresti condividere un passo passo (anche se onestamente è abbastanza lineare il tutto) e eventuali configurazioni? Grazie mille.
Add custom report in HACS and than add integration tuya local.
Give the device id and key (you ca retrive from tuya api cloud)
And that’s clear and easy.
but I cannot start thermostat.
It’s there, I can see programs, I can setup temperature but it won’t work.
Be sure that have the tuya app closed on Smartphone because tuya local allow only one local connection a time
Mmm, interesting. I have to try.
Thanks a lot
it also for this mode ?
BHT8000GC
