Hi! I have multiple cooling valves (0-100%) and I want to create a binary sensor that will be on if any of the valves is above 0% (and otherwise be off). If the binary sensor is "on’ then an automation will turn-on the cool water circulator and the cooling function of the heat pump. My question is how I can make such a template (I am not familiar with the syntax).
Also, I would like to create a similar template being “on” if any wled light is “on” as well.
Many thanks!
