Theengs Gateway is now available also as a docker container
docker pull theengs/gateway
https://gateway.theengs.io/install/install.html#install-theengs-gateway-as-a-docker
Thanks to @maretodoric
We just released a new version. Could you try again?
Yes.
Iâve installed last version and it works.
Now Iâm trying to use TheengsGateway-MQTT (decoded) data inside Home Assistant but Iâm very confused on how to do thisâŚ
Iâm searching for exhaustive documentation but I canât find too.
Glad that it works!
If you want the gateway to decode the payload coming from OMG (MQTTtoMQTT decoding) you can refer to this chapter of the documentation.
https://gateway.theengs.io/use/use.html#mqtttomqtt-decoding
Ok.
Iâm trying many ways⌠Iâll update you with my results.
New version available:
https://gateway.theengs.io/install/install.html#install-theengs-gateway-as-an-add-on-in-home-assistant
New BLE devices and changes:
| Devices | Model | Measurements |
| BlueMaestro | TempoDisc 1 in 1 | temperature/battery |
| BlueMaestro | TempoDisc 4 in 1 | temperature/humidity/pressure/battery |
| ClearGrass alarm clock | CGD1 | temperature/humidity/battery |
| ClearGrass alarm clock | CGC1 | temperature/humidity/battery |
| GOVEE | H5074 | temperature/humidity/battery |
| GOVEE | H5101 | temperature/humidity/battery |
| GOVEE | H5106 | PM2.5/temperature/humidity/battery |
| GOVEE | H5174 | temperature/humidity/battery |
| GOVEE | H5177 | temperature/humidity/battery |
| Oria/Brifit/SigmaWit/SensorPro | TH Sensor T301 | temperature/humidity/battery |
| Mopeka | Pro | temperature/level/sync status/voltage/battery/reading quality |
| Sensirion | MyCOâ/COâ Gadget | temperature/humidity/carbon dioxide |
| Sensirion | SHT4X TH sensor | temperature/humidity |
| ThermoPro | TP393 | temperature/humidity |
Full Changelog: v0.6.6âŚv0.7.0
Hey - First of all: Thanks for putting in so much work and effort to help us with your project.
Unfortunately it seems I have problems understanding the way it works.
Assumption:
Thatâs it? Any settings needed? Theengs HA plugin is not needed?
Thanks for clarifying this to dumb ppl like me
// EDIT: An additional question. Due to very poor performance on the piZERO â Do you recommend the python or the docker installation?
I would suggest the python one to decrease the layers.
You should be good. Do you see traffic if you connect to the mqtt broker with a client like mqtt explorer?
Oh, yes - Thanks for that hint.
I can see a lot of my devices.
Now is the question: How do I add them to HA?
Cool that you see your devices, so if MQTT discovery is activated in your MQTT integration you should see them into Settings->Devices & Services->Devices
That was the missing piece of the puzzle. Thank you for your patience and help!
Me again
Unfortunately my theengs stopped working with the govees. This happened some days ago and I canât remember changing anything - only that I bought 2 new devices.
With the MQTT Explorer I still see my 2 old devices, but only the âconfigâ topic (Dunno if this is âold stuffâ).
I rebooted the raspi several times, I have even reinstalled theengs.
journalctl -u TheengsGateway
Shows â No entries â
Connection to the Broker seems to work:
INFO:BLEGateway:Starting BLE scan
INFO:BLEGateway:Connected to MQTT Broker!
INFO:BLEGateway:Subscribed to home/+/BTtoMQTT/undecoded
What to do/debug here? Thanks again.
Another user opened an issue yesterday with the same problem, but we havenât found the root cause yet. Did you update Theengs Gateway? Update the operating system? What does your theengsgw.conf look like?
Maybe try setting the environment variable BLEAK_LOGGING to 1 to see what the underlying Bluetooth library is doing. You can do that in your systemd service unit file with the Environment key.
Did not update the theengs gateway. OS updates not in the last 14 days:
root@raspberrypi:~# ls -lrt /var/cache/apt/archives |tail
-rw-r--r-- 1 root root 259536 27. Jan 15:10 gir1.2-gtk-3.0_3.24.24-4+rpt12+deb11u2_armhf.deb
-rw-r--r-- 1 root root 59148 27. Jan 15:10 lxtask_0.1.10-1+rpt1_armhf.deb
-rw-r--r-- 1 root root 1263796 27. Jan 15:10 raspberrypi-ui-mods_1.20230127_armhf.deb
-rw-r--r-- 1 root root 308756 28. Jan 01:21 libcurl4_7.74.0-1.3+deb11u5_armhf.deb
-rw-r--r-- 1 root root 306240 28. Jan 01:21 libcurl3-gnutls_7.74.0-1.3+deb11u5_armhf.deb
-rw-r--r-- 1 root root 257952 28. Jan 01:21 curl_7.74.0-1.3+deb11u5_armhf.deb
-rw-r--r-- 1 root root 1829216 29. Jan 07:44 git-man_1%3a2.30.2-1+deb11u1_all.deb
-rw-r--r-- 1 root root 269816 29. Jan 23:08 libtiff5_4.2.0-1+deb11u3_armhf.deb
-rw-r--r-- 1 root root 4706728 30. Jan 05:08 git_1%3a2.30.2-1+deb11u1_armhf.deb
drwx------ 2 _apt root 4096 31. Jan 09:08 partial
Theengs config is the standard one:
"adapter": "",
"ble_scan_time": 5,
"ble_time_between_scans": 5,
"discovery": 1,
"discovery_device_name": "TheengsGateway",
"discovery_filter": [
"IBEACON",
"GAEN",
"MS-CDP"
"discovery_topic": "homeassistant/sensor",
"hass_discovery": 1,
"host": "xxx",
"log_level": "DEBUG",
"pass": "xxx",
"port": 1883,
"publish_topic": "home/TheengsGateway/BTtoMQTT",
"scanning_mode": "active",
"subscribe_topic": "home/+/BTtoMQTT/undecoded",
"time_format": 0,
"time_sync": [],
"user": "theengs"
I will try the debugging with BLEAK_LOGGING and will let you now as soon as I did this
//EDIT: Wait⌠The adpater field shouldnât be empty or?
The adapter field is empty by default, thatâs no problem, then Theengs Gateway just uses the default adapter.
Hi all!
A little of a side question to see if I manage to use the BT gw to solve a Plejd problem. I have two different Plejd meshes due to distance between my garage and my house. For the house mesh I am using the native bluetooth integration from Thomas Loven that is working flawlessly, but I am trying to see if I could use the Theengs BT gw to add as well the BT puck on the garage. I have started the GW as a docker in a NUC in the garage and it does find the Plejd entity: {
âmanufacturerdataâ: â7703070000230aa544c0e3f11263f584837b00â,
ânameâ: âP meshâ,
âidâ: âF1:E3:C0:44:A5:0Aâ,
ârssiâ: -61
ârssiâ: 0
which is published under home/Theengsgateway/BTtoMQTT, along with some other discovered BT entities (no sensors, though), but it is not published in the homeassistant autodiscovered topic, since I assume it is not recognized by the GW? According to the Plejd addon (thomasloven/hass_plejd) the BT proxy with an ESP32 is supported, so I assume that it can be done. What do I need to do for the GW to publish the entity as a lights entity? any quick pointers? Thanks!
You would need to add support for your device to Theengs Decoder. Thereâs some documentation about adding a decoder, but if youâre not up to the task, open an issue in the decoder repository and weâll try to create a decoder if itâs possible.
But I donât know the Plejd hardware, so maybe just to avoid confusion and disappointment: is it a sensor, or a light you want to turn on and off? Because currently Theengs Gateway is only able to pick up sensor measurements, it canât control devices such as lights (clocks are the only supported devices the gateway can control).
Ah! good point⌠It is a light I want to control. so yes, it would require enabling on/off type of capabilities. Iâll have a look at the code and try to find some time to contribute it⌠Thanks for the clarification!
Hi.
Iâve succesfully installed Theengs Gateway on my Home Assistant (working on Raspberry Pi 4).
It read an ESP32 BLE device but sends data like RSSI to the Mosquitto MQTT broker (even installed on the same Raspberry) only every 10 secs.
Otherwise if I usean app like nRF Connect on my smartphone, I see the same update every few ms.
Iâve tried to modify SCAN duration and TIME between parameters on my Theengs Gateway configuration file but with no success.
Any idea?
Thanks in advance
