Blink Camera as Video Doorbell
I’m not using node red, but I want to send it via telegram too, I need some help with this
The data structure for Telegram looks slightly different, see here: https://www.home-assistant.io/components/telegram/#video-support.
I don’t use Telegram myself so I can’t test but I think it should look something like this:
data = {
    "message": "Doorbell",
    "data": {
        "video": {
            "url": "{}/local/{}?1=1".format(
                secrets["blinkHassApiBaseURL"], VIDEO_FILENAME
That works, thank you, but I get the video but not the text, sorry I’m new in python
Maybe try:
data = {
    "data": {
        "video": {
            "caption": "Doorbell"
just try this, its working now, awasome, thank you
Hi, I’m notice that my home assistant get unresponsive after trigger the script, have to reboot the container, any thoughts?this is the log after i run the script before get unresponsive
2019-04-22 21:08:56 INFO (ThreadPoolExecutor-0_0) [pycec] Looking for new devices...
2019-04-22 21:08:56 ERROR (ThreadPoolExecutor-0_0) [asyncio] Exception in callback functools.partial(<bound method HDMINetwork._after_polled of <pycec.network.HDMINetwork object at 0x7fe4ccbdf780>>, 0)
handle: <Handle functools.partial(<bound method HDMINetwork._after_polled of <pycec.network.HDMINetwork object at 0x7fe4ccbdf780>>, 0)>
File "uvloop/cbhandles.pyx", line 68, in uvloop.loop.Handle._run
File "/usr/local/lib/python3.7/site-packages/pycec/network.py", line 345, in _after_polled
self._device_status[device] = task.result()
File "/usr/local/lib/python3.7/site-packages/pycec/tcp.py", line 73, in _poll_device
self.transmit(PollCommand(device))
File "/usr/local/lib/python3.7/site-packages/pycec/tcp.py", line 92, in transmit
self._transport.write(("%s\n" % command.raw).encode())
AttributeError: 'NoneType' object has no attribute 'write'
2019-04-22 21:08:56 ERROR (ThreadPoolExecutor-0_0) [asyncio] Exception in callback functools.partial(<bound method HDMINetwork._after_polled of <pycec.network.HDMINetwork object at 0x7fe4ccbdf780>>, 1)
handle: <Handle functools.partial(<bound method HDMINetwork._after_polled of <pycec.network.HDMINetwork object at 0x7fe4ccbdf780>>, 1)>
2019-04-22 21:08:56 ERROR (ThreadPoolExecutor-0_0) [asyncio] Exception in callback functools.partial(<bound method HDMINetwork._after_polled of <pycec.network.HDMINetwork object at 0x7fe4ccbdf780>>, 2)
handle: <Handle functools.partial(<bound method HDMINetwork._after_polled of <pycec.network.HDMINetwork object at 0x7fe4ccbdf780>>, 2)>
2019-04-22 21:08:56 ERROR (ThreadPoolExecutor-0_0) [asyncio] Exception in callback functools.partial(<bound method HDMINetwork._after_polled of <pycec.network.HDMINetwork object at 0x7fe4ccbdf780>>, 3)
handle: <Handle functools.partial(<bound method HDMINetwork._after_polled of <pycec.network.HDMINetwork object at 0x7fe4ccbdf780>>, 3)>
2019-04-22 21:08:56 ERROR (ThreadPoolExecutor-0_0) [asyncio] Exception in callback functools.partial(<bound method HDMINetwork._after_polled of <pycec.network.HDMINetwork object at 0x7fe4ccbdf780>>, 4)
handle: <Handle functools.partial(<bound method HDMINetwork._after_polled of <pycec.network.HDMINetwork object at 0x7fe4ccbdf780>>, 4)>
2019-04-22 21:08:56 ERROR (ThreadPoolExecutor-0_0) [asyncio] Exception in callback functools.partial(<bound method HDMINetwork._after_polled of <pycec.network.HDMINetwork object at 0x7fe4ccbdf780>>, 5)
handle: <Handle functools.partial(<bound method HDMINetwork._after_polled of <pycec.network.HDMINetwork object at 0x7fe4ccbdf780>>, 5)>
2019-04-22 21:08:56 ERROR (ThreadPoolExecutor-0_0) [asyncio] Exception in callback functools.partial(<bound method HDMINetwork._after_polled of <pycec.network.HDMINetwork object at 0x7fe4ccbdf780>>, 6)
handle: <Handle functools.partial(<bound method HDMINetwork._after_polled of <pycec.network.HDMINetwork object at 0x7fe4ccbdf780>>, 6)>
2019-04-22 21:08:56 ERROR (ThreadPoolExecutor-0_0) [asyncio] Exception in callback functools.partial(<bound method HDMINetwork._after_polled of <pycec.network.HDMINetwork object at 0x7fe4ccbdf780>>, 7)
handle: <Handle functools.partial(<bound method HDMINetwork._after_polled of <pycec.network.HDMINetwork object at 0x7fe4ccbdf780>>, 7)>
2019-04-22 21:08:56 ERROR (ThreadPoolExecutor-0_0) [asyncio] Exception in callback functools.partial(<bound method HDMINetwork._after_polled of <pycec.network.HDMINetwork object at 0x7fe4ccbdf780>>, 8)
handle: <Handle functools.partial(<bound method HDMINetwork._after_polled of <pycec.network.HDMINetwork object at 0x7fe4ccbdf780>>, 8)>
2019-04-22 21:08:56 ERROR (ThreadPoolExecutor-0_0) [asyncio] Exception in callback functools.partial(<bound method HDMINetwork._after_polled of <pycec.network.HDMINetwork object at 0x7fe4ccbdf780>>, 9)
handle: <Handle functools.partial(<bound method HDMINetwork._after_polled of <pycec.network.HDMINetwork object at 0x7fe4ccbdf780>>, 9)>
2019-04-22 21:08:56 ERROR (ThreadPoolExecutor-0_0) [asyncio] Exception in callback functools.partial(<bound method HDMINetwork._after_polled of <pycec.network.HDMINetwork object at 0x7fe4ccbdf780>>, 10)
handle: <Handle functools.partial(<bound method HDMINetwork._after_polled of <pycec.network.HDMINetwork object at 0x7fe4ccbdf780>>, 10)>
2019-04-22 21:08:56 ERROR (ThreadPoolExecutor-0_0) [asyncio] Exception in callback functools.partial(<bound method HDMINetwork._after_polled of <pycec.network.HDMINetwork object at 0x7fe4ccbdf780>>, 11)
handle: <Handle functools.partial(<bound method HDMINetwork._after_polled of <pycec.network.HDMINetwork object at 0x7fe4ccbdf780>>, 11)>
2019-04-22 21:08:56 ERROR (ThreadPoolExecutor-0_0) [asyncio] Exception in callback functools.partial(<bound method HDMINetwork._after_polled of <pycec.network.HDMINetwork object at 0x7fe4ccbdf780>>, 12)
handle: <Handle functools.partial(<bound method HDMINetwork._after_polled of <pycec.network.HDMINetwork object at 0x7fe4ccbdf780>>, 12)>
2019-04-22 21:08:56 ERROR (ThreadPoolExecutor-0_0) [asyncio] Exception in callback functools.partial(<bound method HDMINetwork._after_polled of <pycec.network.HDMINetwork object at 0x7fe4ccbdf780>>, 13)
handle: <Handle functools.partial(<bound method HDMINetwork._after_polled of <pycec.network.HDMINetwork object at 0x7fe4ccbdf780>>, 13)>
2019-04-22 21:08:56 ERROR (ThreadPoolExecutor-0_0) [asyncio] Exception in callback functools.partial(<bound method HDMINetwork._after_polled of <pycec.network.HDMINetwork object at 0x7fe4ccbdf780>>, 14)
handle: <Handle functools.partial(<bound method HDMINetwork._after_polled of <pycec.network.HDMINetwork object at 0x7fe4ccbdf780>>, 14)>
2019-04-22 21:09:01 ERROR (MainThread) [ngrok_init] <urlopen error [Errno 111] Connection refused>
2019-04-22 21:09:07 ERROR (MainThread) [ngrok_init] <urlopen error [Errno 111] Connection refused>
2019-04-22 21:09:07 INFO (MainThread) [homeassistant.components.automation] Executing doorbell
2019-04-22 21:09:07 INFO (MainThread) [homeassistant.helpers.script] Script doorbell: Running script
2019-04-22 21:09:07 INFO (MainThread) [homeassistant.helpers.script] Script doorbell: Executing step call service
Are you running HassIO or your own Docker container? If the latter then I would suggest maybe trying to run the script from within the Docker container to see how it gets on i.e. run…
command docker exec -it <container name> /bin/bash
…to get a Shell and then run the script in there.
If you’re using HassIO then I can’t really help troubleshoot as I’ve never used it.
Ok thank you, I’m using hassio on Docker, it’s strange tough, it was working before, I’m not set the camera yet, so I been testing it, I realized yesterday that stops working and make hassio unresponsive
Hmm, anyone else seeing issues over the last few days?
I’m not getting any videos through so I did some digging. Running api.request_videos with a time value a few days ago shows the latest video being dated mid-day yesterday. The app however shows lots of videos since then. Not sure where things are going wrong here.
same thing here. haven’t been getting anything since 3 days ago and haven’t got time to look into it yet.
Must be an API change, I’ll have a look when I get a chance.
Maybe something for @fronzbot to be aware of.
Yep, blink changed the endpoints again :man_facepalming: I don’t have any videos past May 13th with the current endpoint, but I’ve had success with the following (albeit, fields have changed which is very annoying):
/api/v1/accounts/<account_id>/media/changed?since=<time>&page=<page>
So I think you guys can fix your script by removing line 48 and adding:
url = "{}/api/v1/accounts/{}/media/changed?since={}&page={}".format(blink.urls.base_url, blink.account_id, from_time, 0)
videos = api.http_get(blink, url)['media']
Also I opened an issue here on my repo that hopefully I (or someone else :slightly_smiling_face:) can get to in short order to push out the bugfix.
Thanks @fronzbot. Unfortunately I’m seeing Cannot obtain new token for server auth. and then None is returned. I’ll do some more digging when I get some time.
Hmm, I wonder if that endpoint is region specific or something then
got it working.
  • need to set the region: https://rest-u003.immedia-semi.com (u003 is new york)
  • responseData[“videos”] ==> responseData[“media”]
  • videos[0][“address”] ==> videos[0][“media”]
  • camera_name ==> device_name
code updated: Here
Thank you @fronzbot
Just fyi, AFAIK that endpoint is only valid in the US. If you authenticate with a prde (Europe) endpoint, you will be denied access to US servers
Hey guys. I just made a pre-release for this fix. If you can test it locally to make sure it’s working, it would be HUGELY appreciated. Just install it with the following command:
pip install blinkpy==0.14.0.dev0
Fantastic! Works a treat. Thanks @fronzbot.
I had to change:
videos = api.request_videos(blink, time=from_time)["videos"]
to
videos = api.request_videos(blink, time=from_time)["media"]
and also
video_address = "{}{}".format(blink.urls.base_url, video["address"])
to
video_address = "{}{}".format(blink.urls.base_url, video["media"])
But other than that (for the purposes of this script at least) it works again :slight_smile:.
Perfect! Thanks for checking. Hopefully it will work for a few more weeks before Blink randomly changes endpoints again lol :roll_eyes:
I did install blinkpy-0.14.0.dev0 using the pip install above and still can’t have blink back with HA. It keeps saying Error to endpoint.
@Dullage which file did you change?
