Blink. How?
Thanks for the tip.
Sorry to necro, but has anyone got this working with a Binary light? Specifically I want a light that blinks while it is turned on, but I can turn it off. I can see that
  1. Pulse doesnt work with binary light
  2. Strobe effect seems broken on binary light
  3. The slow_pwm approach doesnt work for me at all, it is just on.
  4. The interval approach doesnt seem to have a way to turn it on or off…
Anyone can help me to traslate this
irsend.mark(1000);
Irsend.space(1000);
To
esphome:
  platform: ESP8266
  board: d1_mini
  #For blinking the greenLED
  on_boot:
    priority: -100
    then:
      - output.turn_on:
          my_slow_pwm
      - output.set_level:
          level: "50%"
output:
    platform: slow_pwm
    pin: D3
    period: 1000ms
Regards
esphome:
  friendly_name: Capteur Lumière
  platform: ESP8266
  board: d1_mini
  on_boot:
    priority: -100
    then:
      - output.turn_on:
          my_slow_pwm
      - output.set_level:
          level: "50%"
output:
    platform: slow_pwm
    pin: GPIO2
    period: 1000ms
# Enable logging
logger:
# Enable Home Assistant API
api:
  encryption:
    key: "jb+VhPzw4jcnk39tggF1zs1saWQF1h2r0+J16Tla/mM="
ota:
  password: "ba9ea2bb85379b7b4d61bec42747202e"
wifi:
  ssid: !secret wifi_ssid
  manual_ip:
    static_ip: 10.10.10.190
    gateway: 10.10.10.1
    subnet: 255.255.255.0
    dns1: 10.10.10.1
  ap:
    ssid: "Capteur-Lumiere Fallback Hotspot"
    password: "01234567"
captive_portal:
i2c:
  sda: GPIO4
  scl: GPIO5
  scan: True
switch:
 - platform: restart
   name: Reboot Capteur de Lumière
  - platform: bh1750
    name: "Capteur de lumière"
    address : 0x23
    update_interval : 20 s
  - platform: uptime
    name: En marche depuis
    update_interval: 60s
    on_raw_value:
      then:
        - text_sensor.template.publish:
            state: !lambda |-
              int seconds = round(id(uptime_sensor_days).raw_state);
              int days = seconds / (24 * 3600);
              seconds = seconds % (24 * 3600);
              int hours = seconds / 3600;
              seconds = seconds % 3600;
              int minutes = seconds /  60;
              seconds = seconds % 60;
              return (
                (days ? String(days) + "d " : "") +
                (hours ? String(hours) + "h " : "") +
                (minutes ? String(minutes) + "m " : "") +
                (String(seconds) + "s")
              ).c_str();
time:
  - platform: homeassistant
text_sensor:
  - platform: version
  - platform: wifi_info
    ip_address:
    bssid:
    ssid:
    icon: mdi:clock-start
For anyone trying to get a 5mm LED blinking, this code worked for me. I just had to change D4 to GPIO4 as I would get an error: Cannot resolve pin name ‘D4’ for board esp32doit-devkit-v1
5mm LED type
