Johnny67
(Jürgen)
January 29, 2025, 4:51pm
21
Thank you for providing this blueprint.
I recently purchased the IKEA Styrbar E2002 dimmer, as my Philips Hue one gave up after years of use.
I had a hard time to find a blueprints which supports the Styrbar with MQTTs actual release.
I looking forward on updates of this blueprint with even more color adjusting possibilities…
Great work …
it would be awesome that we can program the left and right button or add more light entities. i.e. switch scenes with the left and right buttons. Or do some other things.
Edit:
I changed something in your blueprint, so the right button will be a scene switcher.
herefor you need a input switch helper where you put in your scenes you ant to toggle. You can also add multiple lights to control with the styrbar. The right button is connected to the sceneswitcher hard coded. Using !input scene_switcher gave errors.
blueprint:
name: Styrbar Remote Control for Lights
description:
"Provides integration and control for the IKEA E2001/E2002 Styrbar
remote control. Allows for turning lights on/off, adjusting brightness, and changing
color temperature. Designed for a Zigbee2MQTT group of light bulbs.
domain: automation
input:
light_entity:
description: The light to control.
selector:
entity:
domain:
- light
multiple: true
scene_entity:
description: The scene to control.
selector:
entity:
multiple: false
mqtt_device:
description: The IKEA E2001/E2002 remote control.
selector:
device:
multiple: false
brightness_step:
description: Brightness adjustment step (slider percentage, 1-100%).
default: 5
selector:
number:
min: 1.0
max: 100.0
step: 1.0
unit_of_measurement: "%"
mode: slider
delay_ms:
name: Delay (ms) Between Steps
description: Delay in milliseconds between brightness adjustment steps.
default: 300
selector:
number:
min: 100.0
max: 2000.0
step: 100.0
unit_of_measurement: ms
mode: slider
transition_seconds:
name: Transition Time (Seconds)
description: The duration in seconds for the light transition effect.
default: 1
selector:
number:
min: 0.1
max: 9999.0
step: 0.1
unit_of_measurement: s
mode: slider
source_url: https://github.com/ouhlar/home_assistant/blob/main/blueprints/styrbar_light_remote_control.yaml
- platform: device
device_id: !input mqtt_device
domain: mqtt
type: action
subtype: "on"
- platform: device
domain: mqtt
type: action
subtype: "off"
- platform: device
domain: mqtt
type: action
subtype: arrow_left_click
- platform: device
domain: mqtt
type: action
subtype: arrow_right_click
- platform: device
domain: mqtt
type: action
subtype: brightness_move_down
- platform: device
domain: mqtt
type: action
subtype: brightness_move_up
- platform: device
domain: mqtt
type: action
subtype: brightness_stop
- choose:
- conditions:
- condition: trigger
sequence:
- service: light.turn_on
entity_id: !input light_entity
- conditions:
sequence:
- service: light.turn_off
- conditions:
sequence:
- service: input_select.select_next
entity_id: !input scene_entity
- service: scene.turn_on
entity_id: "{{ states('input_select.sceneswitch') }}"
- conditions:
sequence:
kelvin: 2000
- conditions:
sequence:
- repeat:
sequence:
brightness_step_pct: -{{ states('input.brightness_step') | int(5) }}
transition: !input transition_seconds
- delay:
milliseconds: !input delay_ms
until:
- conditions:
sequence:
- repeat:
sequence:
brightness_step_pct: "{{ states('input.brightness_step') | int(5) }}"
- delay:
until:
mode: restart
Hi everybody! Here is a small code enhancement that adds incremental colour temperature adjustment (single click as coarse adjustment as well as continuous press as a little bit more refined increments). Feel free to adopt it if you want - I just feel I have to give something back to the community
blueprint:
name: Styrbar Remote Control for Lights - adjusted
description: >
Provides integration and control for the IKEA E2001/E2002 Styrbar remote control.
Allows for turning lights on/off, adjusting brightness, and changing color temperature.
Added incremental color temperature adjustment.
domain: automation
input:
light_entity:
selector:
entity:
domain: light
mqtt_device:
selector:
device: {}
brightness_step:
description: "Brightness adjustment step (slider percentage, 1-100%)."
default: 5
selector:
number:
min: 1
max: 100
step: 1
delay_ms:
description: "Delay in milliseconds between brightness adjustment steps."
default: 300
selector:
number:
min: 100
max: 2000
step: 100
unit_of_measurement: "ms"
transition_seconds:
description: "The duration in seconds for the light transition effect."
default: 1
selector:
number:
min: 0.1
max: 9999
step: 0.1
unit_of_measurement: "s"
- platform: device
domain: mqtt
type: action
subtype: "on"
- platform: device
domain: mqtt
type: action
subtype: "off"
- platform: device
domain: mqtt
type: action
- platform: device
domain: mqtt
type: action
subtype: arrow_left_hold
- platform: device
domain: mqtt
type: action
subtype: arrow_left_release
- platform: device
domain: mqtt
type: action
- platform: device
domain: mqtt
type: action
subtype: arrow_right_hold
- platform: device
domain: mqtt
type: action
subtype: arrow_right_release
- platform: device
domain: mqtt
type: action
- platform: device
domain: mqtt
type: action
- platform: device
domain: mqtt
type: action
variables:
light_entity: !input light_entity
- choose:
- conditions:
sequence:
- conditions:
sequence:
- conditions:
sequence:
color_temp_kelvin: "{{ state_attr(light_entity, 'color_temp_kelvin') - 200 }}"
- conditions:
sequence:
- repeat:
sequence:
color_temp_kelvin: "{{ state_attr(light_entity, 'color_temp_kelvin') - 100 }}"
- delay:
until:
- conditions:
sequence:
color_temp_kelvin: "{{ state_attr(light_entity, 'color_temp_kelvin') + 200 }}"
- conditions:
sequence:
- repeat:
sequence:
color_temp_kelvin: "{{ state_attr(light_entity, 'color_temp_kelvin') + 100 }}"
- delay:
until:
- conditions:
sequence:
- repeat:
sequence:
brightness_step_pct: "-{{ states('input.brightness_step') | int(5) }}"
- delay:
until:
- conditions:
sequence:
- repeat:
sequence:
- delay:
until:
mode: restart
Just implementet Your code (when I found out how to😉) seems to work perfectly - will report back if any issues - ideas
Johnny67
(Jürgen)
February 5, 2025, 1:35pm
25
one question:
How did you implement the code?
I’m actually struggling to do so…
Here You go
I guess You have the ‘Terminal’ option in Your side menu ?
Anyway in here or in any editor do: cd config/blueprints/automation/ouhlar
You can also do the changes in ‘File editor’ just click Your way to /blueprints/automation/ouhlar
Here You find the ‘styrbar_light_remote_control.yaml’
Make a copy: cp styrbar_light_remote_control.yaml styrbar_light_remote_control.yaml.save just for safety
(I’m not sure how to do that in File editor)
You can then replace the current code with the one from above - and remember to restart
Hope this get You further
Johnny67
(Jürgen)
February 5, 2025, 3:44pm
28
Thanks for your quick reply.
That worked just fine…
All, if you want to insert a custom code in your blueprints/ have your own blueprint, just place the code in a file in your /config/www/blueprints/your_blueprint.yaml then you can import it as new blueprint by using your local hass ip in the webaddress on the import blueprint form:
http://xxx.yyy.zzz.ttt:8123/local/blueprints/your_blueprint.yaml
droidgren
(Droidgren)
March 4, 2025, 10:39am
30
The brightness_step is not working, (It’s locked on 5%, change the slider does not matter), can you fix it please?
heli500
(Heli500)
March 19, 2025, 6:42pm
32
Hello
not workingThe brightness step,It was working perfectly before, but now it’s not working at all, can you help?
Hadea
August 31, 2025, 2:25pm
35
I’m really happy with the “styrbar_light_remote_control.yaml” blueprint since it works perfectly with Zigbee2MQTT in Home Assistant and doesn’t require any sensors, which often cause errors for me.
Is it possible to use the arrow keys to change RGB colors by IKEA Tradfri (using e.g. “rgb_color”) with this blueprint for RGB lights, instead of just switching white tones (“kelvin”)?
Thanks in advance!
Hadea
Thank you for the easy-to-use interface, it really helps us beginner.
unfortunately it doesn’t work for me. Neither with a single light nor with the multiple light.
Any idea how can I find the problem?
Giulio
