FAQ - How do I setup the sensors?
Why are there two sensors?
You need two sensors for each blueprint you want to track:
- GitHub REST Sensor
Fetches the latest version from the online blueprint (via the raw GitHub or Gist URL). - Local Command Line Sensor
Reads the installed version from your local blueprint file using a shell command.
These sensors are compared to detect if a new version is available.
How often do these sensors update?
Only once per day.
The scan_interval is set to 86400 seconds (24 hours), which is more than enough.
Why only once a day?
- Blueprints rarely update more than once daily.
- Scanning too often may result in your IP being rate-limited or blocked by GitHub.
- Every time the automation runs, it manually updates both sensors, so a daily scan is sufficient.
Can I change the name of the sensors?
Yes. The name: field defines how your sensor appears in Home Assistant.
You can rename it to suit your language or preferences, just ensure the entity_id is updated accordingly in your automations or dashboard.
How do I add these sensors?
Paste the following code into your configuration.yaml
(or into sensors.yaml or command_line.yaml if you split your configuration):
Important:
Only includesensor:andcommand_line:once in your configuration file.
When you add any additional sensors, make sure they are placed under the correct heading (sensor:orcommand_line:).
Below are the sensors used for the
Sensor Light Blueprint.
- platform: rest
name: "Sensor Light Blueprint Gist Version Number"
icon: mdi:cloud-tags
resource: "https://gist.githubusercontent.com/Blackshome/6edfec0ff6a25c5da0d07b88dc908238/raw/sensor-light.yaml"
method: GET
headers:
accept: "text/plain"
value_template: >
{% set match = value | regex_findall('\\*\\*Version:\\s*([0-9.]+)\\*\\*') %}
{{ match[0] if match else 'unknown' }}
scan_interval: 86400
command_line:
- sensor:
name: "Sensor Light Blueprint Local Version Number"
icon: mdi:code-not-equal-variant
command: "grep -oE '[*][*]Version: [0-9.]+' /config/blueprints/automation/Blackshome/sensor-light.yaml | grep -oE '[0-9.]+'"
How do I apply changes after adding the sensors?
- Save your configuration file.
- Restart Home Assistant:
Go to Settings → System → Click the power icon (top-right) → Select Restart Home Assistant. - After the restart, your sensors will become available.
How do I check if the sensors are working?
- Add the sensors to any dashboard.
- You should see version numbers like
1.2or1.3. - If the value shows
unknown, the sensor may be misconfigured. Double-check:- The path to your local blueprint file
- The URL of your GitHub Gist
- Any formatting issues in your confi
What are all your blueprint sensors?
See the example code below for all of my blueprint sensors used to track the version of each blueprint. Simply copy the ones you need and adjust the names or settings to match your language or preferences.
Sensor Light - Motion Sensor - Door Sensor - Sun Elevation - LUX Value - Scenes - Time
- platform: rest
method: GET
headers:
value_template: >
command_line:
- sensor:
Smart Light - Entity - Sun Elevation - Ambient & Time Triggers
- platform: rest
name: "Smart Light Blueprint Gist Version Number"
resource: "https://gist.github.com/Blackshome/e6c8f1bf846bab2fa4431934a0a85770/raw/smart-light.yaml"
method: GET
headers:
value_template: >
command_line:
- sensor:
name: "Smart Light Blueprint Local Version Number"
command: "grep -oE '[*][*]Version: [0-9.]+' /config/blueprints/automation/Blackshome/smart-light.yaml | grep -oE '[0-9.]+'"
Sensor Light Add On - Media & Movie Lights - House Alarm Lights - Smoke Alarm Lights & Exhaust Fans + More
- platform: rest
name: "Sensor Light Add On Blueprint Gist Version Number"
resource: "https://gist.github.com/Blackshome/85d6e7dbfa3390afbcf3e801b8be6294/raw/sensor-light-add-on.yaml"
method: GET
headers:
value_template: >
command_line:
- sensor:
name: "Sensor Light Add On Blueprint Local Version Number"
command: "grep -oE '[*][*]Version: [0-9.]+' /config/blueprints/automation/Blackshome/sensor-light-add-on.yaml | grep -oE '[0-9.]+'"
Holiday & Away Lighting
- platform: rest
name: "Holiday & Away Lighting Blueprint Gist Version Number"
resource: "https://gist.github.com/Blackshome/0a34870755762bcb9fab159d5b94fd25/raw/holiday-away-lighting.yaml"
method: GET
headers:
value_template: >
command_line:
- sensor:
name: "Holiday & Away Lighting Blueprint Local Version Number"
command: "grep -oE '[*][*]Version: [0-9.]+' /config/blueprints/automation/Blackshome/holiday-away-lighting.yaml | grep -oE '[0-9.]+'"
Bathroom Humidity Exhaust Fan
- platform: rest
name: "Bathroom Humidity Exhaust Fan Blueprint Gist Version Number"
resource: "https://gist.github.com/Blackshome/8e09a8213b834f1be4ab49ba880abed8/raw/bathroom-humidity-exhaust-fan.yaml"
method: GET
headers:
value_template: >
command_line:
- sensor:
name: "Bathroom Humidity Exhaust Fan Blueprint Local Version Number"
command: "grep -oE '[*][*]Version: [0-9.]+' /config/blueprints/automation/Blackshome/bathroom-humidity-exhaust-fan.yaml | grep -oE '[0-9.]+'"
Low Battery Notifications & Actions
- platform: rest
name: "Low Battery Blueprint Gist Version Number"
resource: "https://gist.github.com/Blackshome/4010fb83bb8c19b5fa1425526c6ff0e2/raw/low-battery-notifications-and-actions.yaml"
method: GET
headers:
value_template: >
command_line:
- sensor:
name: "Low Battery Blueprint Local Version Number"
command: "grep -oE '[*][*]Version: [0-9.]+' /config/blueprints/automation/Blackshome/low-battery-notifications-and-actions.yaml | grep -oE '[0-9.]+'"
Appliance Notifications & Actions - Washing Machine - Clothes Dryer - Dish Washer - ETC
- platform: rest
name: "Appliance Notification Blueprint Gist Version Number"
resource: "https://gist.github.com/Blackshome/42586b567d243d432887cadf54e18906/raw/appliance-notifications.yaml"
method: GET
headers:
value_template: >
command_line:
- sensor:
name: "Apliance Notification Blueprint Local Version Number"
command: "grep -oE '[*][*]Version: [0-9.]+' /config/blueprints/automation/Blackshome/appliance-notifications.yaml | grep -oE '[0-9.]+'"
Notifications & Announcements
- platform: rest
name: "Notification & Announcments Blueprint Gist Version Number"
resource: "https://gist.github.com/Blackshome/180ca4a24af81cd5d843acfc039039bc/raw/notifications-and-announcements.yaml"
method: GET
headers:
value_template: >
command_line:
- sensor:
name: "Notification & Announcments Blueprint Local Version Number"
command: "grep -oE '[*][*]Version: [0-9.]+' /config/blueprints/automation/Blackshome/notifications-and-announcements.yaml | grep -oE '[0-9.]+'"
Calendar Notifications & Actions
- platform: rest
name: "Calendar Notification Blueprint Gist Version Number"
resource: "https://gist.github.com/Blackshome/40bfd92fb1fe6a9a9189325704a3c81b/raw/calendar-notifications-and-actions.yaml"
method: GET
headers:
value_template: >
command_line:
- sensor:
name: "Calendar Notification Blueprint Local Version Number"
command: "grep -oE '[*][*]Version: [0-9.]+' /config/blueprints/automation/Blackshome/calendar-notifications-and-actions.yaml | grep -oE '[0-9.]+'"
State Notifications & Actions
- platform: rest
name: "State Notification Blueprint Gist Version Number"
resource: "https://gist.github.com/Blackshome/06f6f28e76299267b813dac48608f549/raw/state-notifications-and-actions.yaml"
method: GET
headers:
value_template: >
command_line:
- sensor:
name: "State Notification Blueprint Local Version Number"
command: "grep -oE '[*][*]Version: [0-9.]+' /config/blueprints/automation/Blackshome/state-notifications-and-actions.yaml | grep -oE '[0-9.]+'"
Battery Charger Notifications & Actions
- platform: rest
name: "Batery Charger Notification Blueprint Gist Version Number"
resource: "https://gist.github.com/Blackshome/b99340b548d7fe4aedd96adc8c7a175d/raw/battery-charger-notifications.yaml"
method: GET
headers:
value_template: >
command_line:
- sensor:
name: "Battery Charger Notification Blueprint Local Version Number"
command: "grep -oE '[*][*]Version: [0-9.]+' /config/blueprints/automation/Blackshome/battery-charger-notifications.yaml | grep -oE '[0-9.]+'"
Blueprint Update Notifications
- platform: rest
name: "Blueprint Update Notifications Blueprint Gist Version Number"
resource: "https://gist.github.com/Blackshome/ede9cf745f3b86ff8576c21b6ca1509a/raw/blueprint-update-notifications.yaml"
method: GET
headers:
value_template: >
command_line:
- sensor:
name: "Blueprint Update Notifications Blueprint Local Version Number"
command: "grep -oE '[*][*]Version: [0-9.]+' /config/blueprints/automation/Blackshome/blueprint-update-notifications.yaml | grep -oE '[0-9.]+'"
Manual Control Status Tracker
- platform: rest
name: "Manual Control Status Tracker Blueprint Gist Version Number"
resource: "https://gist.github.com/Blackshome/993beed8b1c6ea29613b67f54d592456/raw/manual-control-status-tracker.yaml"
method: GET
headers:
value_template: >
command_line:
- sensor:
name: "Manual Control Status Tracker Blueprint Local Version Number"
command: "grep -oE '[*][*]Version: [0-9.]+' /config/blueprints/automation/Blackshome/manual-control-status-tracker.yaml | grep -oE '[0-9.]+'"
Bee In The Hive Sensor
- platform: rest
name: "Bee In The Hive Sensor Blueprint Gist Version Number"
resource: "https://gist.github.com/Blackshome/00da6c9c96e1f7ec3aeeab400f048c16/raw/bee-in-the-hive-sensor.yaml"
method: GET
headers:
value_template: >
command_line:
- sensor:
name: "Bee In The Hive Sensor Blueprint Local Version Number"
command: "grep -oE '[*][*]Version: [0-9.]+' /config/blueprints/automation/Blackshome/bee-in-the-hive-sensor.yaml | grep -oE '[0-9.]+'"
Android Notification Channel Manager
- platform: rest
name: "Android Notification Channel Manager Blueprint Gist Version Number"
resource: "https://gist.github.com/Blackshome/610854c4868aa73e32347ca54aa276ae/raw/android-notification-channel-manager.yaml"
method: GET
headers:
value_template: >
command_line:
- sensor:
name: "Android Notification Channel Manager Blueprint Local Version Number"
command: "grep -oE '[*][*]Version: [0-9.]+' /config/blueprints/automation/Blackshome/android-notification-channel-manager.yaml | grep -oE '[0-9.]+'"
Toilet Exhaust Fan with time delay
- platform: rest
name: "Toilet Exhaust Fan Blueprint Gist Version Number"
resource: "https://gist.github.com/Blackshome/70349658a0c7543dbaa5f2e69e10cce0/raw/toilet-exhaust-fan.yaml"
method: GET
headers:
value_template: >
command_line:
- sensor:
name: "Toilet Exhaust Fan Blueprint Local Version Number"
command: "grep -oE '[*][*]Version: [0-9.]+' /config/blueprints/automation/Blackshome/toilet-exhaust-fan.yaml | grep -oE '[0-9.]+'"
Entity - Run ON Timer
- platform: rest
name: "Entity - Run ON Timer Blueprint Gist Version Number"
resource: "https://gist.github.com/Blackshome/99ac675f3189a64b11daae5ff7eafaa7/raw/run-on-timer.yaml"
method: GET
headers:
value_template: >
command_line:
- sensor:
name: "Entity - Run ON Timer Blueprint Local Version Number"
command: "grep -oE '[*][*]Version: [0-9.]+' /config/blueprints/automation/Blackshome/run-on-timer.yaml | grep -oE '[0-9.]+'"
Trigger - Run ON Timer
- platform: rest
name: "Trigger - Run ON Timer Blueprint Gist Version Number"
resource: "https://gist.github.com/Blackshome/495198096386f0db2cdaf91c0bda50ea/raw/trigger-run-on-timer.yaml"
method: GET
headers:
value_template: >
command_line:
- sensor:
name: "Trigger - Run ON Timer Blueprint Local Version Number"
command: "grep -oE '[*][*]Version: [0-9.]+' /config/blueprints/automation/Blackshome/trigger-run-on-timer.yaml | grep -oE '[0-9.]+'"
Manual light control with auto OFF
- platform: rest
name: "Manual Light Blueprint Gist Version Number"
resource: "https://gist.github.com/Blackshome/9f9785d7aa0ba7978fa6515a2d73d192/raw/manual-light.yaml"
method: GET
headers:
value_template: >
command_line:
- sensor:
name: "Manual Light Blueprint Local Version Number"
command: "grep -oE '[*][*]Version: [0-9.]+' /config/blueprints/automation/Blackshome/manual-light.yaml | grep -oE '[0-9.]+'"
Closet, Pantry, and Cupboard Lighting
- platform: rest
name: "Closet, Pantry, and Cupboard Lighting Blueprint Gist Version Number"
resource: "https://gist.github.com/Blackshome/5aac0fe94d23a71154aee5ba8d1375bc/raw/closet-pantry-cupboard-lighting.yaml"
method: GET
headers:
value_template: >
command_line:
- sensor:
name: "Closet, Pantry, and Cupboard Lighting Blueprint Local Version Number"
command: "grep -oE '[*][*]Version: [0-9.]+' /config/blueprints/automation/Blackshome/closet-pantry-cupboard-lighting.yaml | grep -oE '[0-9.]+'"
Timer
- platform: rest
name: "Timer Blueprint Gist Version Number"
resource: "https://gist.github.com/Blackshome/ec0afd31dce7fc6b106e378d06b01940/raw/timer.yaml"
method: GET
headers:
value_template: >
command_line:
- sensor:
name: "Timer Blueprint Local Version Number"
command: "grep -oE '[*][*]Version: [0-9.]+' /config/blueprints/automation/Blackshome/timer.yaml | grep -oE '[0-9.]+'"
Temperature Control Fan
- platform: rest
name: "Temperature Control Fan Blueprint Gist Version Number"
resource: "https://gist.github.com/Blackshome/043e1e4e8bcf91d7efa1fa56c06bde2f/raw/temperature-control-fan.yaml"
method: GET
headers:
value_template: >
command_line:
- sensor:
name: "Temperature Control Fan Blueprint Local Version Number"
command: "grep -oE '[*][*]Version: [0-9.]+' /config/blueprints/automation/Blackshome/temperature-control-fan.yaml | grep -oE '[0-9.]+'"
Temperature Control Exhaust Fan - Inverted
- platform: rest
name: "Temperature Control Exhaust Fan - Inverted Blueprint Gist Version Number"
resource: "https://gist.github.com/Blackshome/b87a33849ca06dea3623480dbbbb45bb/raw/temperature-control-exhaust-fan-inverted.yaml"
method: GET
headers:
value_template: >
command_line:
- sensor:
name: "Temperature Control Exhaust Fan - Inverted Blueprint Local Version Number"
command: "grep -oE '[*][*]Version: [0-9.]+' /config/blueprints/automation/Blackshome/temperature-control-exhaust-fan-inverted.yaml | grep -oE '[0-9.]+'"
Toggle Switch - Turn ON & OFF Entities
- platform: rest
name: "Toggle Switch Blueprint Gist Version Number"
resource: "https://gist.github.com/Blackshome/fd16903e90c2aa58c75e92d2cafc6115/raw/toggle-switch-turn-on-off-entities.yaml"
method: GET
headers:
value_template: >
command_line:
- sensor:
name: "Toggle Switch Blueprint Local Version Number"
command: "grep -oE '[*][*]Version: [0-9.]+' /config/blueprints/automation/Blackshome/toggle-switch-turn-on-off-entities.yaml | grep -oE '[0-9.]+'"
Press Button - Turn ON & OFF Entities
- platform: rest
name: "Press Button Blueprint Gist Version Number"
resource: "https://gist.github.com/Blackshome/ca6be121c8d3e4404e33114fc88b599a/raw/press-button-turn-on-off-entities.yaml"
method: GET
headers:
value_template: >
command_line:
- sensor:
name: "Press Button Blueprint Local Version Number"
command: "grep -oE '[*][*]Version: [0-9.]+' /config/blueprints/automation/Blackshome/press-button-turn-on-off-entities.yaml | grep -oE '[0-9.]+'"
- platform: rest
name: "Switch - Turn ON & OFF Entities Blueprint Gist Version Number"
resource: "https://gist.github.com/Blackshome/dbcd8ebfdd0350144fc1503fc0fa8112/raw/switch-turn-on-off-entities.yaml"
method: GET
headers:
value_template: >
command_line:
- sensor:
name: "Switch - Turn ON & OFF Entities Blueprint Local Version Number"
command: "grep -oE '[*][*]Version: [0-9.]+' /config/blueprints/automation/Blackshome/switch-turn-on-off-entities.yaml | grep -oE '[0-9.]+'"
