Ok, I will stop for now. Thanks for your help and suggestions.
I used an old mobile and installed a bluetooth scanner. I can’t find my current mobile with this (and vice versa, as they are both motorola’s).
My mobile is picked up by other equipment (like headphones and Hue lights), but for some reason it is not visible in the scanner. Even with discovery active. Might be the same reason why RPi3 does not show it with a ‘bluetoothctl’ command.
My insight in the functioning of HA BT has increased, but I am lost in Motorola’s BT implementation.
Sorry to hear that you give up (at least for now).
I have to admit that the BT stack of the RPi 3 is crap.
It doesn’t detect my amazon echo dot
Or, sometimes, it is after a looooooong time (ran systemctl scan on for 2 days for it to show up)
@Spiro: range was not the issue, I held the scanner next to my mobile. I suspect the BT implementation by Motorola has some items why the scanner does not pick it up as a BT, while other BT equipment can (still) pair with it.
But that is definitely beyond my knowledge and capabiltiy to figure out.
@Olivier1974: It is not the end, I will definitely try again when I have replaced my mobile (which might take a year or 2). I found out that HA (and smart home in general) is addictive. About 1,5 year ago, I had just 1 light to figure out HA for fun and wondered what else to do with it (and why). When I installed shutters, I also installed shelly switches for them and that brought on the fever. It is still no necessity, but it fun to play with.
For me, yes, it is the built in one.
I was using an ESPHome ESP32 explicitly as BT relay as HA was not BT friendly when I started.
Now that HA is BT friendly, I moved to the internal BT. But this is not reliable.
I believe it is the same internal BT of the Pi for @spijkers09, to confirm.
Nevertheless, the packages used internaly or by external dongles are the same: bluetoothpi-bluetooth and bluez (optional blueman if you’re using the desktop environment, which I dont)
Hello! I have a similar issue. I have updated OS from 7.6 to 9.4, and core to 2023.1.6 (don’t remember what version it was before an update). And my bluetooth integration has stopped working.
When I enable passive scanning then the error disappears, but bluetooth still doesn’t work. bluetoothctl show returns power: no, any command like power on, scan on returns org.Bluez.Error.NotReady/Busy. I don’t know what’s going on, can’t find any idea to fix it. I also have RPi b+ with built-in bluetooth.
Same issue here, I have updated my Pi3 for Pi4 and it does not see my iPhone as well while my old setting on Rpi3 is still accurate. Did setup a ESP32 for the BT detection however get a lot of devices in HA as Known Devices.
Would like to know what the best solution would be or the best script in ESP32, still looking for it
Same with me. I have 2 HA instances one is Pi4 and BT works fine. But the one with Pi3 cannot start BT. Adapter is visible (like the image of LiLatee above) but cannot start in active mode. Did anyone figured this out.
