BMW ConnectedDrive component
Which card did you use from that site? I like that it is a picture card with text on the statuses which you cant do with the normal one.
@Sluddsy do you have the bmw remote services?
@Alexxander0
Yes I do but looks like I have id4 so this may not be compatible.
I took the Temperature glance as example. I am using a picture where I made the bottom grey-transparent in Photoshop.
So picture-elements card with custom:text-element, state-icon and state-icon on the bottom.
On the top custom:circle-sensor-card.
Links for the custom parts I have used.
custom:text-element
Here is a part of my card.
  - icon: mdi:car-connected
    title: BMW X1
    cards:
      - type: picture-elements
        image: /local/lovelace/bmw_layer.jpg
        elements:
        # lock
        - type: custom:text-element
          text: "Slot"
          style:
            top: 86%
            left: 10%
            color: white
            # background-color: rgba(54, 65, 78, 0.8)
        - type: state-icon
          entity: binary_sensor.x1_sdrive18i_door_lock_state
          tap_action: more-info
          style:
            top: 91.5%
            left: 10%
            "--paper-item-icon-color": white
        - type: state-label
          style:
            top: 97.5%
            left: 10%
            color: white
        # remaining fuel
        - type: custom:circle-sensor-card
          entity: sensor.x1_sdrive18i_remaining_fuel
          max: 63
          min: 0
          stroke_width: 15
          # stroke_color: '#03a9f4'
          gradient: true
          fill: rgba(54, 65, 78, 0.6)
          units: ' '
          font_style:
            font-size: 1.1em
            color: white
            # text-shadow: '2px 2px black'
          color_stops:
            5: '#09C7E8'
            63: '#09A50C'
          style:
            top: 6%
            left: 5%
            width: 4em
            height: 4em
            transform: none
Since this morning I get the following errors when I restart HASS:
2018-09-18 09:11:01 ERROR (SyncWorker_15) [bimmer_connected.account] Unknown status code 400, expected 200
2018-09-18 09:11:01 ERROR (SyncWorker_15) [bimmer_connected.account] {
“error” : “invalid_grant”,
“error_description” : “the authN circuit failed”
2018-09-18 09:11:01 ERROR (MainThread) [homeassistant.setup] Error during setup of component bmw_connected_drive
File “/usr/src/app/homeassistant/setup.py”, line 148, in _async_setup_component
component.setup, hass, processed_config)  # type: ignore
File “/usr/local/lib/python3.6/concurrent/futures/thread.py”, line 56, in run
File “/usr/src/app/homeassistant/components/bmw_connected_drive/init.py”, line 61, in setup
accounts.append(setup_account(account_config, hass, name))
File “/usr/src/app/homeassistant/components/bmw_connected_drive/init.py”, line 90, in setup_account
read_only)
File “/usr/src/app/homeassistant/components/bmw_connected_drive/init.py”, line 137, in init
self.account = ConnectedDriveAccount(username, password, region)
File “/usr/local/lib/python3.6/site-packages/bimmer_connected/account.py”, line 55, in init
self._get_vehicles()
File “/usr/local/lib/python3.6/site-packages/bimmer_connected/account.py”, line 181, in _get_vehicles
self._get_oauth_token()
File “/usr/local/lib/python3.6/site-packages/bimmer_connected/account.py”, line 88, in _get_oauth_token
expected_response=200, post=True)
File “/usr/local/lib/python3.6/site-packages/bimmer_connected/account.py”, line 128, in send_request
raise IOError(msg)
OSError: Unknown status code 400, expected 200
Any ideas? Nothing has changed as far as I know…
Same error here. Maybe BMW changed the authentication workflow ?
Edit: I’m in Belgium
Not working for me either
Edit: Im in the UK (Or ‘rest of world’ according to BMW regions)
Looks like BMW has changed something regarding the API indeed.
We will have a look at it.
Mine’s working fine - I’m in the US. I compared the data against the BMW Connected app and it matches.
Broken here, Norway.
also broken with in Germany
PR is made https://github.com/home-assistant/home-assistant/pull/16780.
Thanks to @m1n3rva for fixing the library which was necessary because the login url to the BMW server has changed.
what is the new login url for europe? is an update available or can it be made manualy right now? actual bimmer version is installed via pip.
@gerard33 could somebody explain a noob how to update his Bmw component?
old url: webapi/oauth/token
new_url: gcdm/oauth/token
Find the file __init__.py in bmw_connected_drive folder and change
REQUIREMENTS = ['bimmer_connected==0.5.1'] to REQUIREMENTS = ['bimmer_connected==0.5.2'].
Or just wait until HA 0.79 is available.
Sooo… a total HA noob here. Trying to get something out of this component.
So far all I’ve done, is add this to the configuration.yaml:
# BMW Connected
bmw_connected_drive:
  name:
    username: [email protected]
    password: xxx
    region: "rest_of_world"
And I get these errors:
Fri Sep 28 2018 18:34:35 GMT+0300 (Eastern European Summer Time)
  File "/usr/local/lib/python3.6/site-packages/homeassistant/components/bmw_connected_drive/__init__.py", line 150, in update
    self.account.update_vehicle_states()
  File "/usr/local/lib/python3.6/site-packages/bimmer_connected/account.py", line 205, in update_vehicle_states
    car.update_state()
  File "/usr/local/lib/python3.6/site-packages/bimmer_connected/vehicle.py", line 58, in update_state
    self.state.update_data()
  File "/usr/local/lib/python3.6/site-packages/bimmer_connected/state.py", line 92, in update_data
    VEHICLE_STATUS_URL.format(server=self._account.server_url, vin=self._vehicle.vin), logfilename='status')
  File "/usr/local/lib/python3.6/site-packages/bimmer_connected/account.py", line 128, in send_request
    raise IOError(msg)
And this
Fri Sep 28 2018 18:44:35 GMT+0300 (Eastern European Summer Time)
Error updating the vehicle state.
And this
  "error" : {
    "code" : 500,
    "description" : "(SmartPhoneUtil-A-101) Mandatory parameter(s) missed or blank: dlat and dlon are required for BMW vehicles!"
For longitude and latitude, I have this:
homeassistant:
  # Name of the location where Home Assistant is running
  # Location required to calculate the time the sun rises and sets
  latitude: xx.xxxxxx
  longitude: yy.yyyyyy
So, any tips on how to go forward? Should I add some ’ or " around the password and username? Something else? Nothing is shown in the overview UI regarding this.
Got a BMW 320D 2014, a working connection to that from the iOS app and the location is Finland. Running HA 0.78.3 from hass.io rpi image.
after the update I get following error messages
No data available for attribute <function VehicleState.charging_status at 0x63b1be88>!
I have already made a PR for that, but it wasn’t merged in the 0.79 release :confused:
https://github.com/home-assistant/home-assistant/pull/16877
But you can safely ignore that message, it’s no actual error and the PR makes sure the logs are not filled with these messages.
you have to update to hass 0.79 to fix the issue
As mentioned above you indeed need HA 0.79 as that contains a fix for a change made in the api by BMW.
Besides that I think you car isn’t supported. There is some work in progress to support older cars for which lon and lat coordinates needs to be send, but that’s not implemented yet.
