It eventually connected but keeps going unavailable every so often it makes it unusable.
Let’s hope it comes back soon
Guess BMW is fumbling again on their API today. I have several connection problems today again.
Been using this for a while and just updated HA to latest point release and this has stopped working. Tried removing it from HACS (I am on the beta) and HA, adding to HACS and HA and get this:
Config flow could not be loaded: undefined
Logs show that it is is recognised:
We found a custom integration bmw_connected_drive which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
Then I get this:
022-05-21 11:31:15 ERROR (MainThread) [homeassistant.setup] Setup failed for custom integration bmw_connected_drive: Requirements for bmw_connected_drive not found: ['bimmer_connected==0.9.0.0b10'].
Any ideas anyone?
mb
EDIT: Solved. Uninstalled the beta in Hacs. Reboot. Reboot agains once it has come up 100%. Install from integration and all good in the hood.
For about 3 HA versions this component has been working terribly (probably due to BMW) but it gets disconnected like 20 times a day now. Anyone else or just me?
File "/usr/src/homeassistant/homeassistant/helpers/update_coordinator.py", line 191, in _async_refresh
self.data = await self._async_update_data()
File "/usr/src/homeassistant/homeassistant/components/bmw_connected_drive/coordinator.py", line 59, in _async_update_data
self.account = await self.hass.async_add_executor_job(
File "/usr/local/lib/python3.9/concurrent/futures/thread.py", line 58, in run
File "/usr/local/lib/python3.9/site-packages/bimmer_connected/account.py", line 88, in __init__
self._get_vehicles()
File "/usr/local/lib/python3.9/site-packages/bimmer_connected/account.py", line 383, in _get_vehicles
self._get_oauth_token()
File "/usr/local/lib/python3.9/site-packages/bimmer_connected/account.py", line 113, in _get_oauth_token
raise ex
File "/usr/local/lib/python3.9/site-packages/bimmer_connected/account.py", line 99, in _get_oauth_token
token_data = self._login_row_na()
File "/usr/local/lib/python3.9/site-packages/bimmer_connected/account.py", line 223, in _login_row_na
_LOGGER.error("Authentication failed: %s", response.text)
UnboundLocalError: local variable 'response' referenced before assignment
The error is bogus as the login is correct and I can use the myBMW app just fine.
I can confirm the same issue, since yesterday it stopped working and login is no longer possible.
This seems to be working again now following yesterdays upgrade to version 20220528.1 of the custom component (well, at least it is for me).
I can confirm
can you please provide the link to the custom component?
thank you.
Sure …
thank you. Much appreciated
apologies, for troubling you.
I set it up, but the repo doesn’t say how to configure it in homeassistant.
is there a yaml snipet for the config.yalm file?
Thank you again
Edit: never mind, answer is using the standard config flow.
Thank you again
Hi!
I’m really interested as well in way to start and stop charging through API. I have used a shelly smart plug, but this is not very reliable recently - it will power on, but charger will have error sometimes and won’t start charging.
So it would be exccelent if i can start and stop charging through API.
Martin
Is this broken again? Haven’t been able to connect for over 1 day.
2022-06-11 19:49:20 WARNING (MainThread) [homeassistant.config_entries] Config entry 'xxxx' for bmw_connected_drive integration not ready yet: Error communicating with BMW API: Client error '429 Too Many Requests' for url 'https://cocoapi.bmwgroup.com/eadrax-vcs/v1/vehicles?apptimezone=60.0&appDateTime=1654973346008&tireGuardMode=ENABLED'
It’s listed a pull request on their github. I’m also hoping for this feature to be implemented.
HA newbie here - I realise that this post (Map display) is from March 2018, but have loaded this integration and was wondering how I could get this map in HA. All I get is a circle with a ‘5’ in the center and was wondering how you managed this.
Also, earlier posts referenced the ‘conditioned based services’, but later on they seem to have been dropped/removed. Are these no longer available (would be good to set reminders, calendar updates, etc. if they were.
any news regarding start/stop charge?
any connection problems again? I just saw my integration does not work since roughly 3 hours. Is there any fix in this issues or do I have just to wait on BMW? BR JJ
Yup, same here. Since latest BMW App update…
Fyi, issue reported: https://github.com/home-assistant/core/issues/75270
