It all depends on how “invasive” and “handy” you are. Assuming there is a control pannel on the wall with a LED indicating the status of the device, I see two possible options:
- set a light sensor (photoresistor) on the top of the LED to read its status and then send a signal via a 433MHz device, e.g. this one. The con of this option is that you are to loose visibility on the led.
- Open the device and connect two wires to the led so its signal is to drive the 433MHz transmitter.
