Brightness & Brightness_pct not working in automations
Yeah, but have they been discovered correctly.
They all show as lights with
supported_features: 41
I can adjust brightness on all lights in UI so they work with brightness
It acts like when you send the brightness setting it works 1 time and
then not for multiple lights or even when I did each one manual only
the 1st one works.
Sounds like you need to open an issue.
How do I do that?
As ZHA is a core integration you go to the core repository on github and open an issue there. It’s always wise to search the existing issues first though, then you might find someone has already reported the issue, like this:
That’s not exactly your problem so a new issue can be created:
Unless you already have one, create a free GitHub account then head over to the Home Assistant Core repository (“repo”) and create a new Issue. You’ll be presented with a form requesting various bits of information. Have a look at some of the other open Issues to get an idea of what information is required. After you submit the new Issue, it will be assessed by one of the developers and then assigned to the developer(s) responsible for the ZHA integration.
EDIT
Ninja’d!
Will do
Problem was with my Sengled lights.
Updated the firmware on all 15 of my lights and now everything works perfect.
