the code below is a working example for the ESP32 compiled with Arduino IDE. It turns one light on/off once a second.Tested with this light → Amazon.de
The code is based on java script code of @ArcadeMachinist.
Maybe this code helps finding a solution available in Home Assistant or ESPHome (maybe derived from BLEAdvertising class).
I’m not an expert in Home Assistant or ESPHome, so I can’t do it, sorry.
#include "BLEDevice.h"
#include "BLEUtils.h"
#include "BLEServer.h"
#include "BLEBeacon.h"
* see:
* https://circuitdigest.com/microcontroller-projects/esp32-based-bluetooth-ibeacon
* https://community.home-assistant.io/t/brmesh-app-bluetooth-lights/473486/19
// See the following for generating UUIDs:
// https://www.uuidgenerator.net/
BLEAdvertising *pAdvertising; // BLE Advertisement type
#define BEACON_UUID "87b99b2c-90fd-11e9-bc42-526af7764f64" // UUID 1 128-Bit (may use linux tool uuidgen or random numbers via https://www.uuidgenerator.net/)
const uint8_t my_key[] = { 0x23, 0x15, 0x55, 0x38 }; // Your unique Mesh key - see README
const uint8_t default_key[] = { 0x5e, 0x36, 0x7b, 0xc4 };
uint8_t lightId = 1;
void setup() {
Serial.begin(115200);
Serial.printf("start ESP32 DEVICEID - %llX\n", ESP.getEfuseMac());
// Create the BLE Device
BLEDevice::init("ESP32 as iBeacon");
pAdvertising = BLEDevice::getAdvertising();
BLEDevice::startAdvertising();
void send(uint8_t* data, uint8_t dataLength);
uint8_t SEND_SEQ = 0;
uint8_t SEND_COUNT = 1;
const uint8_t BLE_CMD_RETRY_CNT = 1;
const uint8_t DEFAULT_BLE_FASTCON_ADDRESS[] = { 0xC1, 0xC2, 0xC3 };
const uint8_t addrLength = 3;
void dump(const uint8_t* data, int length)
for (int i = 0; i < length; i++)
printf("%2.2X", data[i]);
uint8_t package_ble_fastcon_body(int i, int i2, uint8_t sequence, uint8_t safe_key, int forward, const uint8_t* data, int length, const uint8_t* key, uint8_t*& payload)
if (length > 12)
printf("data too long\n");
payload = 0;
return 0;
uint8_t payloadLength = 4 + 12;
payload = (uint8_t*)malloc(payloadLength);
payload[0] = (i2 & 0b1111) << 0 | (i & 0b111) << 4 | (forward & 0xff) << 7;
payload[1] = sequence & 0xff;
payload[2] = safe_key;
payload[3] = 0; // checksum
// fill payload with zeros
for (int j = 4; j < payloadLength; j++) payload[j]=0;
memcpy(payload + 4, data, length);
uint8_t checksum = 0;
for (int j = 0; j < length + 4; j++)
if (j == 3) continue;
checksum = (checksum + payload[j]) & 0xff;
payload[3] = checksum;
for (int j = 0; j < 4; j++) {
payload[j] = default_key[j & 3] ^ payload[j];
for (int j = 0; j < 12; j++) {
payload[4 + j] = my_key[j & 3] ^ payload[4 + j];
return payloadLength;
uint8_t get_payload_with_inner_retry(int i, const uint8_t* data, int length, int i2, const uint8_t* key, int forward, uint8_t*& payload) {
printf("data: "); dump(data, length); printf("\n");
SEND_COUNT++;
SEND_SEQ = SEND_COUNT;
uint8_t safe_key = key[3];
return package_ble_fastcon_body(i, i2, SEND_SEQ, safe_key, forward, data, length, key, payload);
void whiteningInit(uint8_t val, uint8_t* ctx)
ctx[0] = 1;
ctx[1] = (val >> 5) & 1;
ctx[2] = (val >> 4) & 1;
ctx[3] = (val >> 3) & 1;
ctx[4] = (val >> 2) & 1;
ctx[5] = (val >> 1) & 1;
ctx[6] = val & 1;
void whiteningEncode(const uint8_t* data, int len, uint8_t* ctx, uint8_t* result)
memcpy(result, data, len);
for (int i = 0; i < len; i++) {
int varC = ctx[3];
int var14 = ctx[5];
int var18 = ctx[6];
int var10 = ctx[4];
int var8 = var14 ^ ctx[2];
int var4 = var10 ^ ctx[1];
int _var = var18 ^ varC;
int var0 = _var ^ ctx[0];
int c = result[i];
result[i] = ((c & 0x80) ^ ((var8 ^ var18) << 7))
+ ((c & 0x40) ^ (var0 << 6))
+ ((c & 0x20) ^ (var4 << 5))
+ ((c & 0x10) ^ (var8 << 4))
+ ((c & 0x08) ^ (_var << 3))
+ ((c & 0x04) ^ (var10 << 2))
+ ((c & 0x02) ^ (var14 << 1))
+ ((c & 0x01) ^ (var18 << 0));
ctx[2] = var4;
ctx[3] = var8;
ctx[4] = var8 ^ varC;
ctx[5] = var0 ^ var10;
ctx[6] = var4 ^ var14;
ctx[0] = var8 ^ var18;
ctx[1] = var0;
uint8_t reverse_8(uint8_t d)
uint8_t result = 0;
for (uint8_t k = 0; k < 8; k++) {
result |= ((d >> k) & 1) << (7 - k);
return result;
uint16_t reverse_16(uint16_t d) {
uint16_t result = 0;
for (uint8_t k = 0; k < 16; k++) {
result |= ((d >> k) & 1) << (15 - k);
return result;
uint16_t crc16(const uint8_t* addr, const uint8_t* data, uint8_t dataLength)
uint16_t crc = 0xffff;
for (int8_t i = addrLength - 1; i >= 0; i--)
crc ^= addr[i] << 8;
for (uint8_t ii = 0; ii < 4; ii++) {
uint16_t tmp = crc << 1;
if ((crc & 0x8000) !=0)
tmp ^= 0x1021;
crc = tmp << 1;
if ((tmp & 0x8000) != 0)
crc ^= 0x1021;
for (uint8_t i = 0; i < dataLength; i++) {
crc ^= reverse_8(data[i]) << 8;
if ((crc & 0x8000) != 0)
tmp ^= 0x1021;
crc = tmp << 1;
crc ^= 0x1021;
crc = ~reverse_16(crc) & 0xffff;
return crc;
uint8_t get_rf_payload(const uint8_t* addr, const uint8_t* data, uint8_t dataLength, uint8_t*& rfPayload)
uint8_t data_offset = 0x12;
uint8_t inverse_offset = 0x0f;
uint8_t result_data_size = data_offset + addrLength + dataLength+2;
uint8_t* resultbuf = (uint8_t*)malloc(result_data_size);
memset(resultbuf, 0, result_data_size);
resultbuf[0x0f] = 0x71;
resultbuf[0x10] = 0x0f;
resultbuf[0x11] = 0x55;
console.log("");
console.log("get_rf_payload");
console.log("------------------------");
console.log("addr: " + Buffer.from(addr).toString('hex'));
console.log("data: " + Buffer.from(data).toString('hex'));
printf("get_rf_payload\n");
printf("addr: "); dump(addr, addrLength); printf("\n");
printf("data: "); dump(data, dataLength); printf("\n");
for (uint8_t j = 0; j < addrLength; j++) {
resultbuf[data_offset + addrLength - j - 1] = addr[j];
for (int j = 0; j < dataLength; j++) {
resultbuf[data_offset + addrLength + j] = data[j];
printf("inverse_offset: %d\n", inverse_offset);
printf("inverse_offset addr.len + 3: %d\n", (inverse_offset + addrLength + 3));
for (int i = inverse_offset; i < inverse_offset + addrLength + 3; i++) {
resultbuf[i] = reverse_8(resultbuf[i]);
int crc = crc16(addr, data, dataLength);
resultbuf[result_data_size-2] = crc & 0xff;
resultbuf[result_data_size-1] = (crc >> 8) & 0xff;
rfPayload = resultbuf;
return result_data_size;
uint8_t do_generate_command(int i, const uint8_t* data, uint8_t length, const uint8_t* key, int forward, int use_default_adapter, int i2, uint8_t*& rfPayload)
if (i2 < 0) i2 = 0;
uint8_t* payload = 0;
uint8_t* rfPayloadTmp = 0;
uint8_t payloadLength = get_payload_with_inner_retry(i, data, length, i2, key, forward, payload);
uint8_t rfPayloadLength = get_rf_payload(DEFAULT_BLE_FASTCON_ADDRESS, payload, payloadLength, rfPayloadTmp);
free(payload);
uint8_t ctx[7];
whiteningInit(0x25, &ctx[0]);
uint8_t* result = (uint8_t*)malloc(rfPayloadLength);
printf("payload raw: "); dump(rfPayloadTmp, rfPayloadLength); printf("\n");
whiteningEncode(rfPayloadTmp, rfPayloadLength, ctx, result);
printf("payload cip: "); dump(result, rfPayloadLength); printf("\n");
rfPayload = (uint8_t*)malloc(rfPayloadLength-15);
memcpy(rfPayload, result + 15, rfPayloadLength - 15);
free(result);
free(rfPayloadTmp);
return rfPayloadLength-15;
void single_control(uint16_t addr, const uint8_t* key, const uint8_t* data, uint8_t dataLength)
uint8_t* result= (uint8_t*)malloc(dataLength+2);
result[0] = (uint8_t)(2 | ((sizeof(dataLength)+1) << 4));
result[1] = addr & 0xff;
memcpy(result + 2, data, dataLength);
uint8_t ble_adv_data[] = { 0x02, 0x01, 0x1A, 0x1B, 0xFF, 0xF0, 0xFF };
uint8_t* rfPayload = 0;
uint8_t rfPayloadLength = do_generate_command(5, result, dataLength + 2, key, true /* forward ?*/, true /* use_default_adapter*/, 0, rfPayload);
free(result);
uint8_t* advPacket = (uint8_t*)malloc(rfPayloadLength + sizeof(ble_adv_data));
memcpy(advPacket, ble_adv_data, sizeof(ble_adv_data));
memcpy(advPacket+ sizeof(ble_adv_data), rfPayload, rfPayloadLength);
free(rfPayload);
send(advPacket, rfPayloadLength + sizeof(ble_adv_data));
free(advPacket);
void Brightness(uint8_t id, uint8_t on, uint8_t brightness)
uint8_t command[1];
command[0] = 0;
if (on) command[0] = (brightness & 127);
single_control(id, my_key, command, 1);
printf("Adv-Cmd : btmgmt -i 1 add-adv -d "); dump(data, dataLength); printf(" 1\n");
printf("datalen=%d\n", dataLength);
BLEBeacon oBeacon = BLEBeacon();
oBeacon.setManufacturerId(0xf0ff); // fake Apple 0x004C LSB (ENDIAN_CHANGE_U16!)
oBeacon.setProximityUUID(BLEUUID(BEACON_UUID));
oBeacon.setMajor(0);
oBeacon.setMinor(0);
BLEAdvertisementData oAdvertisementData = BLEAdvertisementData();
BLEAdvertisementData oScanResponseData = BLEAdvertisementData();
oAdvertisementData.setFlags(0x04); // BR_EDR_NOT_SUPPORTED 0x04
std::string strServiceData = "";
strServiceData += (char)(dataLength-4); // Len
for (int i=4;i<dataLength;i++)
strServiceData += (char)data[i];
oAdvertisementData.addData(strServiceData);
pAdvertising->setAdvertisementData(oAdvertisementData);
pAdvertising->setScanResponseData(oScanResponseData);
pAdvertising->start();
delay(50);
pAdvertising->stop();
bool isOn = false;
unsigned long lastMillis = 0;
void loop()
if (millis()-lastMillis > 500) // every 500ms
isOn = !isOn;
Brightness(lightId, isOn ? 1 : 0, isOn ? 127 : 0);
lastMillis = millis();
