I have an AUX ac with AC Freedom app. I have tried both the Docker container and the Python version of the plugin on the host (I run a new HA container), and I get the same result above.
Watching this topic for interesting develoments.
I could help, not sure what you need, I’m not on Telegram though.
These AC units are super common where I live.
been testing . Seems like the new broadlink devices (what these AC’s are) have new function called “lock”.
So seems one might be able to go into some of the apps and unlock the device,
OR one can try setup the device using the broadlink app. https://www.broadlink.ae/broadlink-app
You use the generic wifi device and setup with that. (mine worked, but mine is old)
> Broadlink will now, by default, lock your device when it is configured so that it cannot be reached by local devices. This will prevent this plug-in from discovering or connecting to the device. To unlock either abort the setup process when you're prompted for a room, or follow these steps:
> Open the Broadlink app
> From the Home screen, tap on your Broadlink device
> Tap the ... in the top right
> Scroll down and toggle "Lock device" to Off
> Tap OK when prompted "Confirm to unlock the device"
Thanks for looking into this.
Still no luck.
The AC Freedom app doesn’t have a way to unlock the device.
So I removed the AC from the app and installed the Broadlink app.
But I couldn’t setup the AC with the Broadlink app, generic wifi device. It gets stuck on the AP setup method, it just keeps saying to connect to device AP even when I am already connected to the AC***** wifi, it looks like it’s not recognizing the wifi as correct and the setup never goes on.
So I reinstalled the AC Freedom app, redid the setup there, exited before selecting the room as per instructions, AC is connected to wifi, not showing in the app, but the plugin doesn’t work anyway, I tried again both docker and system Python. Same output as above, just stopping continuously.
Python version: 3.10.6
I have an new AUX ac, and I’ve done these steps too, but I can’t unlock the device with the app either. The broadlink app doesn’t recognize the climate for me either.
Phyton: 3.10.6
I have downloaded the latest AC Freedom app. Than i started to add my device. When it promts you to select a room, just close the app. Your AC should be available on your network by then.
After that i have restarted the addon and everything was working fine.
I sent a request to join the group, I am member of the Home Assistant core team, I also thought about writing an official integration for this, however I am in the same situation as others with a new AC that doesn’t work. Ping me if I can help, would be really nice to have an official integration.
I am also facing same issue as before. I tried to use AC freedom v2 and stop before adding to the room, also tried to install AC Freddom v1 but it crashes. Unfortunately I am getting socket timeout with monitor.py and getting Stopping Starting loop on the add-on.
Hi ! andremain. I’m new to Home Assistant. I Wonder hoy to Run the apt Command i dont ges it if i need another computer running. Im running on a Raspberry pi. I Wonder where i can Run the comandante Lines.
I had a similar problem, I couldn’t connect the air conditioner to Wi-Fi using AC Freedom. But then I found the Broadlink E-control app on Google Play. It’s old, but it works for me
Hi all.
I’m using:
Home Assistant 2023.2.3 Supervisor 2023.01.1 Operating System 9.5 (virtual machine on Synology)
I have configured AC MQTT proxy for home assistant (0.6.2) and Mosquitto broker (6.1.3).
My AC freedom is v2.3.0.
But I’m not able to connect to my Aux AC:
s6-rc: info: service s6rc-oneshot-runner: starting
s6-rc: info: service s6rc-oneshot-runner successfully started
s6-rc: info: service fix-attrs: starting
s6-rc: info: service fix-attrs successfully started
s6-rc: info: service legacy-cont-init: starting
s6-rc: info: service legacy-cont-init successfully started
s6-rc: info: service legacy-services: starting
services-up: info: copying legacy longrun broadlink-ac-mqtt (no readiness notification)
s6-rc: info: service legacy-services successfully started
Starting Monitor…
(200, (‘192.168.1.33’, 80))
