Broadlink Returning different codes for same button
When I use remote.learn_command to learn my Coship cable tv settop box remote code, I get different codes for the same button everytime I press it. Sometimes this code works also but mostly it wont. Why is this so? How can i solve it? I see the same problem while using broadlink manager learn command also.
Have you been able to solve this? I have the same problem with different remotes. Some buttons of these remotes I was able to use but some send a different code each time I try. This is an example from my lg soundbar mute button from the /config/.storage/broadlink_remote_24dfa7d608c9_codes file (10 tries with 10 different outcomes);
        "lgsb": {
            "1": "JgBWAI+TEBUQFBE5EDkRFBA5ERQRFBAVEBQRORA5ERQQOREUERQQORE5EDkROBE5ERQQFRAUERQRFBAUERQRFBE4ETkROBEABgSSlBE5EAAMV4+UETkQAA0F",
            "2": "JgBOAI2VEBQRFBE4ETkRFBA5ERQQFRAUERQROBE5ERQQOREUEBUQORE5EDkROBE5EBUQFBEUERQQFRAUERQRFBA5ETkQOREABgOTlBE5EAANBQAAAAAAAAAA",
            "3": "JgBOAI6UEBUQFBE5EDkRFBE4ERQRFBAVEBQRORA5ERQROBEUERQROBE5EDkRORA5ERQRFBAUERQRFBAVEBQRFBE5EDkROBEABgSTlBA5EQANBQAAAAAAAAAA",
            "4": "JgBOAI+TERQRFBA5ETkQFBE5ERQQFBEUERQQORE5EBQROREUEBQRORA5ETkQORE4ERQRFBEUEBQRFBEUERQQFBE5ETgRORAABgiQkxA5EQANBQAAAAAAAAAA",
            "5": "JgBWAI+TERQRFBA5ETkQFBE5EBQRFBEUERQQORE5EBQRORAVEBQRORA5ETkQORE4ERQRFBEUEBQRFBEUERQQFBE5ETgRORAABgSSlBE5EQAMU5OUEDkRAA0F",
            "6": "JgBWAI6UEBQRFBE4ETkQFRA5ERQQFRAUERQROBE5ERQQOREUEBUQORE4ETkROBE5EBQRFBEUERQQFBEUERQRFBA5ETgROREABgOTlBA5EQAMWI+TETkQAA0F",
            "7": "JgBOAI2VERQQFBE5ETgRFBE4ERQRFBEVDxQRORA5ERQROBEUERQROBE5EDkRORA5ERQQFRAUERQRFBAVEBQRFBE4ETkROBEABf6YlBE4EQANBQAAAAAAAAAA",
            "8": "JgBOAI+SEhQRFBA5ETgRFBE5EBQRFBEUERQQORE5EBQRORAUERQRORA5ETgRORE4ERQRFBAVEBQRFBEUEBUQFBE5EDkRORAABgOUlBA5EQANBQAAAAAAAAAA",
            "9": "JgBOAI+TERQRFBA5ETkQFBE5ERQQFBEUERQQORE5EBQRORAVEBQRORE4ETkQORE4ERQRFBEUEBQRFBEUERQQFBE5ETgRORAABgOUlBA5EQANBQAAAAAAAAAA",
            "10": "JgBOAI+TERQQFRA5ETgRFBE5EBQRFBEUEBUQORE4ERQRORAUERQROBE5ETgRORA5ERQRFBAUERQRFBEUEBQRFBE5EDkROBEABgSTkxE5EAANBQAAAAAAAAAA"
I think this is the same problem as discussed here
