Hi
Have you managed to get those codes?
Hi
Hey, I have a Samsung 49ks7000 and controlling with a RM4C. Iâve tried th codes from [quasar66] and yours and there are 2 codes that I canât get to work: DOWN and LEFT. All others I used worked like a charm.
anyone has an alternative code for this model?
Hi guys,
anybody knows the b64 code of samsung tv remote Netflix button?
the code maybe is
âJgAYAZaSFTYVNhQ3FBEVERQRFREUEhQ2FTYUNxQRFREUEhQRFREUNhU2FREUERU2FDcUNhU2FREUERU2FDcUERURFBIUERUABeqVkxQ2FTYUNxQRFREUEhQRFREUNhU2FTYUEhQRFREUERURFDcUNhURFBIUNhU2FDcUNhURFBIUNhU2FBIUERURFBEVAAXqlZMUNhU2FTYUEhQRFREUERURFDcUNhU2FBIUERURFBIUERU2FDYVERURFDYVNhU2FDYVERURFDYVNhURFBEVERQSFAAF6pWTFDcUNhU2FREUERURFBIUERU2FDcUNhURFBIUERQSFBEVNhQ3FBEVERQ3FDYVNhQ3FBEVERQ3FDYVERQSFBEVERQADQU=â,
Hi everybody,
i have a question, how can i use the specific commands? in a script for example. I use the custom component smartir and i have json file with all codes, and i want use the codes like, netflix or not standard code standard.
you mean the script like this:
samsoldtvon:
alias: samsoldtvon
sequence:
Does anyone have a command for switching output of the sound? (Selecting speakers). Normally itâs necessary on my tv to go through a sequence in the menu, but this sequence is not constant, depends on connected devices on HDMI, which alters the menu. And I donât have a specific button for it in my remote. Thanks in advance!
I was on in the same situation, but got these ones which worked for me:
DOWN = JgBEAJaTFDYUNhQ2FBEUERQRFBEUERQ2FDYUNhQRFBEUERQRFBEUNhQRFBEUERQRFDYUNhQRFBEUNhQ2FDYUNhQRFBEUNhQADQU=
LEFT = JgBEAJaTFDYUNhQ2FBEUERQRFBEUERQ2FDYUNhQRFBEUERQRFBEUNhQRFDYUERQRFDYUNhQRFBEUNhQRFDYUNhQRFBEUNhQADQU=
Also have a code for the âMOREâ button on my Samsung remote which opens up a virtual remote on the screen which I could not find anywhere online. Very useful code to use in conjunction with the IOS remote since you then have access to all the potential buttons.
MORE = gBGAJWOFTIRNhM0FQ4UDxMOEw4TDxE3FDIUMxERERERERIQFA4VDRUyERETDxUyERERNhM1FDIRERE2ETcUDxMyFA4VDRUADQUAAA==
How can i get HDMI codes? I Have a Sony TV, I searched for the HDMI codes for long time but i couldnât find them. Can anybody help please.
@Hassan_Fardan do you mean CEC commands to send over HDMI? Iâm not an expert on this but have used them. The CEC protocol is a standard and doesnât relate to your TV model except for which commands would be supported. It also doesnât relate to IR commands (infrared remote controls) and thus the Broadlink devices â the topic of this thread. Youâll need to try another thread or start a new topic, unless Iâm misunderstanding you.
No I mean the base 64 codes like these:
âsourcesâ: {
âHDMI1â: âJgBGAJKVETkRORE5ERQQFRAVERQQFRE5ETkROREUERQRFBEUERQRORAVERUPOxAVDzsQOhA6EBUQOhA6EBUQOhAVEBUPFhAADQUAAA==â,
âHDMI2â: âJgBGAJOUETkRORA6ERQQFRAVERQRFBA6ETkROhAVDxYQFQ8WEBUQFQ87EDoRORA6DzsQFRA6DzsPFhAVDxYQFRAVEDoQFRAADQUAAA==â,
âHDMI3â: âJgBGAJOUEDoRORE5ERQRFRAUERQRFBE5EDsQOhAVEBUPFg8WDxYPFhA6EBUPFg8WEBUROQ87EDoQFQ87EDoQOhA6EBUPFhAADQUAAA==â,
âHDMI4â: âJgBGAJOVETgRORE6DxYQFQ8WDxYPFhA6EDoQOhAVDxYQFQ8WDxYPOw8WEDoQFRAVDxYPOxA6EBUQOhAVEDoQOhA6EBUPFhAADQUAAA==â
These are for samsung TVâs. I want for my Sony TV.
Right, Iâm with you now: The IR codes for switching the HDMI source.
You can use the learn service in HA but given your last post, Iâm assuming your remote only has a single source or HDMI button and you want to switch to a specific source.
Have you tried some of the IR databases out there? I canât remember anymore which one I used but I found my Samsung codes on one of them.
If you have access to a Windows machine Broadlink Manager is really easy to use. Just put it in capture mode, point the remote at your RM3 and press the button you want.
