shlomki
January 27, 2017, 8:37am
450
shlomki:
Hey guys, I’m completely at a loss. Ever since upgrading to the latest HA, the broadlink package fails to install.This is something that has to do with pycrypto, even though it is installed. The broadlink package already worked for me, but since upgrading, it won’t install.
Here is the error which shows up in the console:
Well, if anyone is interested or runs into the same problem, here’s how I’ve fixed it (in the most awkward of ways, but at least it works):
The problem is that the broadlink package lists pycrypto as a requirement, but for some reason fails to see that it’s already installed, and then it tries to install it in a way that doesn’t really work.
What I did was to remove the requirement of pycrypto from the install files of the broadlink package.
Make sure you have pycrypto installed by running: pip3 show pycrypto. If it’s not installed, install it from here: GitHub - sfbahr/PyCrypto-Wheels: Built Distributions of PyCrypto on Windows
Go to: C:\Users\YOUR_WINDOWS_USER\AppData\Local\pip\cache\wheels and run a search for “broadlink” (if does not exist, run pip install broadlink==0.3)
You will find a .whl file. Rename it to .zip and unpack it.
Edit the file broadlink-0.3.dist-info\METADATA: and remove the line which contains “pycrypto”. Save the edited file.
Edit the file broadlink-0.3.dist-info\metadata.json , search for the following (including the quotes ): “pycrypto (==2.6.1)” and delete it. Do not delete the square brackets around it. Save it.
Repack the file as zip and rename it back to .whl
Run home assistant again.
Profit.
gpa18mx
(Gpa18mx)
January 28, 2017, 8:57am
451
Hi guys i have some issues with this, the log saids that the ip or the mac is incorrect. Its a A1 sensor
Basically i have:
platform: broadlink
update_interval: 60
host: 192.168.0.77 (where my devices is connected)
mac: ‘b6:89:0c:vg:v6:67’ it’s a dummy mac
monitored conditions:
-temperature […]
Could you post the exact error message?
Ashfaaa
(Ash Faa)
January 28, 2017, 10:45am
453
I’m running HA on windows and I’m facing the same problem after upgrade to 0.36.1
I don’t find any wheels folder in C:\Users\YOUR_WINDOWS_USER\AppData\Local\pip\cache\
please help me.
shlomki
January 28, 2017, 11:08am
454
Ashfaaa:
YOUR_WINDOWS_USER
Hi, you need to replace “YOUR_WINDOWS_USER” in the path with your windows username. If you don’t know it, just go to C:\Users and see which one it is by looking at the folders.
EDIT:
I didn’t read your message correctly at first. I’m not sure why you can’t find a wheels folder. Maybe you looked in the wrong user? What is the error you are getting when running homeassistant?
Ashfaaa
(Ash Faa)
January 28, 2017, 11:16am
455
yes i replaced that and searched could not find but problem is fixed now. i opened cmd installed pip install broadlink==0.3
then the problem was fixed.
gpa18mx
(Gpa18mx)
January 28, 2017, 3:53pm
456
this is the error
INFO:homeassistant.util.package:Attempting install of broadlink==0.3
Exception:
File “/srv/homeassistant/homeassistant_venv/lib/python3.4/site-packages/pip/basecommand.py”, line 215, in main
status = self.run(options, args)
File “/srv/homeassistant/homeassistant_venv/lib/python3.4/site-packages/pip/commands/install.py”, line 423, in run
shutil.rmtree(target_item_dir)
File “/usr/lib/python3.4/shutil.py”, line 463, in rmtree
_rmtree_safe_fd(fd, path, onerror)
File “/usr/lib/python3.4/shutil.py”, line 401, in _rmtree_safe_fd
_rmtree_safe_fd(dirfd, fullname, onerror)
File “/usr/lib/python3.4/shutil.py”, line 421, in _rmtree_safe_fd
onerror(os.unlink, fullname, sys.exc_info())
File “/usr/lib/python3.4/shutil.py”, line 419, in _rmtree_safe_fd
os.unlink(name, dir_fd=topfd)
PermissionError: [Errno 13] Permission denied: ‘SHA256.py’
ERROR:homeassistant.bootstrap:Not initializing sensor.broadlink because could not install dependency broadlink==0.3
gpa18mx
(Gpa18mx)
January 28, 2017, 4:04pm
459
I just do that but now it didn´t show anything, the last time this message also appear
“* sensor.broadlink Please check your config; title=Invalid config” im using the config like this
sensor 1:
platform: broadlink
update_interval: 60
host: 192.168.0.77
mac: “p4:43:0d:cd:j6:38”
temperature
humidity
air_quality
light
noise
Sorry I´m new with this of HASS
gpa18mx
(Gpa18mx)
January 28, 2017, 5:44pm
461
so there is no error but I cannot see anything, what do you think I´m doing wrong.
`17-01-28 11:39:09 INFO (MainThread) [homeassistant.loader] Loaded sensor.broadlink from homeassistant.components.sensor.broadlink
17-01-28 11:39:09 INFO (MainThread) [homeassistant.bootstrap] Setting up sensor´
do I have to do something else? no icons or something that tell me that I do it right.
So there is no error when you run hass --script check_config ?
And there is no error in the log when hass is running?
And none of the sensors are shown in when you open the frontend?
gpa18mx
(Gpa18mx)
January 28, 2017, 6:35pm
463
That’s correct!! at least I can’t see any error.
Strange, how is your config now?
maybe is not, but try to use ’ instead of "
My HASS is on a pi3 though
switch 2:
platform: broadlink
host: 192.168.1.90
mac: 'b4:22:22:21:2a:10'
switches:
tv:
command_on: 'JgCEAw4ODQ4ODg4ODg4OKw4ODg4ODg4ODg4NDg4ODg4ODg4rDg4ODg4ODg4ODg0ODg4ODg4ODiKw4ODg4ODg4ODg4ODg4ODg0ODg4ODg4OKw4ODg4ODg4ODg4ODQ4ODg4ODg4rOKw4ODg4ODg4ODg4ODQ8NDg4ODg4rDg4ODg4ODg4ODg4NDw0ODg4ODisOKw4qDisOKw4ODg4ODg4qDisOKw4rDioODg4rDgAJlHM4Dg4OKw4NDg4ODg4ODg4ODg4ODg4ODg4ODg4OKg4ODg4ODg4ODg4ODg4ODg4ODg4qDg4ODg4ODg4ODg4ODg4ODg4ODioOKw4rDisOKg4ODg4ODg4rDisOKg4rDisODg4qDgAJlHM4Dg4OKw4ODg4ODg4ODQ4ODg4ODg4ODg4ODg4OKw4ODg0PDQ4ODg4ODg4ODg4ODg4rDg4ODQ8NDg4ODg4ODg4ODg4ODisOKg4rDisOKw4NDw0ODg4rDisOKw4qDisODg4rDgANBQAAAAA='
command_off: 'JgCEAw4ODg4ODg4NDw0OKw4ODg4ODg4ODg4ODg4ODg0PDQ4rDg4ODg4ODg4ODg4ODg4ODQ8qDisOKw4qDisOKw4ODg4OKg8qDisOKw4qDisODg4rDgAJk3Q4Dg4OKg4ODg4ODg4ODg4ODg4ODg4ODg4NDw0OKw4ODg4ODg4ODg4ODg4ODg0PDQ8qDg4ODg4ODg4ODg4ODg4ODQ8qDisOKw4qDyoOKw4ODg4OKg8qDisOKw4qDyoODg4rDgAJk3M5Dg4OKg4ODg4ODg4ODg4ODg4ODg4ODg4NDw0OKw4ODg4ODg4ODg4ODg4NDw0PDQ4rDg4ODg4ODg4ODg4ODg0PDQ8qDisOKw4qDisOKw4ODg4OKg4rDisOKw4qDisODg4rDgAJk3M5Dg0PKg4ODg4ODg4ODg4ODg4ODg4ODQ8NDw0OKw4ODg4ODg4ODg4ODg4NDw0PDQ4rDg4ODg4ODg4ODg4ODg0PDQ8qDisOKw4qDisOKw4ODg4OKg4rDisOKw4qDisODg4rDgAJk3M5Dg0PKg4ODg4ODg4ODg4ODg4ODg4ODQ8NDw0OKw4ODg4ODg4ODg4ODg4NDw0PDQ4rDg4ODg4ODg4ODg4ODg0PDQ4rDisOKw4qDisOKw4ODg4OKg8qDisOKw4qDisODg4rDgAJk3M5Dg0PKg4ODg4ODg4ODg4ODg4ODg4ODQ8NDg4OKw4ODg4ODg4ODg4ODg4NDw0ODg4rDg4ODg4ODg4ODg4ODg0PDQ4rDisOKw4qDisOKw4ODg4OKg4rDisOKw4qDisODg4rDgAJk3M5Dg0PKg4ODg4ODg4ODg4ODg4ODg4ODQ8NDw0PKg4ODg4ODg4ODg4ODg4NDw0PDQ8qDg4ODg4ODg4ODg4ODg0PDQ8qDisOKw4qDisOKw4ODg4OKg4rDisOKw4qDisODg4rDgAJk3M5Dg0PKg4ODg4ODg4ODg4ODg4ODg4ODQ8NDw0OKw4ODg4ODg4ODg4ODQ8NDw0PDQ8qDg4ODg4ODg4ODg4ODg0PDQ8qDisOKw4qDisOKw4ODg4OKg4rDisOKw4qDisODg4rDgAJk3M4Dw0PKg4ODg4ODg4ODg4ODg4ODg0PDQ8NDg4OKw4ODg4ODg4ODg4ODQ8NDw0ODg4rDg4ODg4ODg4ODg4NDw0ODg4rDisOKw4qDisOKw4ODg4OKg4rDisOKw4qDisODg4rDgANBQAAAAA='
friendly_name: 'TV'
gpa18mx
(Gpa18mx)
January 28, 2017, 8:19pm
466
My config is like this. I know that I´m doing something but don’t know what haha
Looks fine.
Can you see if you find your sensors here: YOUR_IP:8123/dev-state ?
gpa18mx
(Gpa18mx)
January 28, 2017, 8:30pm
468
yes sure, im also planning to reinstall is there any tutorial or something to uninstall all so I can do a clean install, I’m in a pi
pronsta
January 29, 2017, 3:46am
469
I think you can go with hassbian image. bruh automation make good videos to start with HA - Link: Bruh Automation Tutorials
Just found out about HA a few days ago and the integration with the RM2 Pro and a multitude of other stuff I have been wanting in a centralised and connected service.
I extracted all my RF codes per the documentation from the e-broadlink app. I was having a few errors with the length must be a multiple of 16. Once i got past that hurdle I added all the switches to the configuration to start testing and developing my ha a little more.
However, i have a strange problem with a few codes that make the list of switches disappear completely from the HA page. I have included my switch config with the codes that exhibit the problem commented out.
As you can see, Bauhn’s 1 and 4 with both command on and off will make the list disappear. Bauhn 3 works without trouble and Bauhn’s 2 and 5(all) have a problem with just the command_on line. This occurred on both 36.1 and now 37.0.
Appreciate any advice to rectify the problem. Thanks.
switch:
platform: broadlink
host: 192.168.1.11
mac: 'b4:43:0d:39:30:0c'
switches:
fan_lv_light:
friendly_name: 'Fan - Living Room: Light'
command_on: '6QAMASIQERAQEg8SDxMOEw4UDhMOEw4IGQkYCRgKFwoYChcKFwsWFgsLFgwVDRUMFQ0UDwgAAZALFwoXChgJGAoYCRgJGQkYCRgJGQkNFA0UDRQOFA0UDRUNFA0UGAoNFA0UDRUXChgJDRUAAYUMFQwVDBYLFgwWCxYLFgwWCxYLFgwLFgsWCxcLFgsWCxYMFgsWFgwLFgsWCxYXCxYLCxYAAYUNFA0UDRUMFQwWDBUMFQwWDBUMFQwLFwoXChcKFwsXChcKFwsXFQwLFgsXChcWCxYMChcAAYQNFA0UDRUMFQ0UDRUMFQwVDRUMFQwKGAoXChcKGAoXChcKGAoXFQwKFwsXChcVDBYMChcABdwAAAAAAAAAAAAAAAA='
command_off: ''
fan_lv_inc:
friendly_name: 'Fan - Living Room: Increase Speed'
command_on: '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'
command_off: ''
fan_lv_dec:
friendly_name: 'Fan - Living Room: Decrease Speed'
command_on: '6QBCASQGGA4SEBERDxIPEhASDxIPEw4TDggZCRgJGAoXChgKFwoXChcLFwoXCxYLFhcKDRQAAYYLFgwWCxYLFwoXCxcKFwoXCxcKFwoYCQ0UDhQOEw4TDhQNFA4UDRQNFA4UDRQYCRkJDRQAAYYMFQwWCxYLFgwWCxYLFwsWCxYLFwsWCwsWDBYLFgsWDBYLFgwWCxYLFgwWCxYXChcLCxYAAYQNFQ0UDRUMFQwWDBUMFQwWDBUMFgsWDAoXCxYLFwoXCxYLFwoXCxYLFwoXCxYWDBYLCxcAAYQNFA0UDRUMFQ0UDRUMFQ0VDBUMFQ0VDAoXChgKFwoXChgKFwoXCxcKFwoXCxYWDBUMCxcAAYMOEw4UDRQNFQwVDRQNFQwVDRQNFQwVDQkYChcKFwoYChcKFwsXChcKFwsXChcVDBYMChcABdwAAAAAAAA='
command_off: ''
fan_lv_reverse:
friendly_name: 'Fan - Living Room: Reverse'
command_on: '6QAKAREREREPEg8SEBIOEw8TDhMOCBkJGAkYChgKFwoXChcWDAoXCxYLFxYLFgsWCxcLAAGFDBUMFQwWDBUMFgsWCxcLFgsXChcLCxYMFQ0UDhMOFA0UDhMZCQ0UDhQNFBgJGQkYCRgKAAGFDBYLFgwVDBYLFgsXCxYLFgwWCxYLDBYLFgsWDBYLFgsWDBYWCwsWDBYLFhcLFgsWCxcLAAGEDRQNFQwVDRUMFQwWDBUMFQwWDBUMCxYLFwoXChcLFwoXChcWDAoXCxYLFxYLFgwVDBYLAAGEDhQNFA0UDRUNFA0VDBUMFQ0VDBUNCRgKFwoYChcKFwoXCxcVDAoXCxcKFxYMFQwVDBYMAAXcAAAAAAAAAAAAAAAAAAA='
command_off: ''
fan_lv_off:
friendly_name: 'Fan - Living Room: Off'
command_on: '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'
command_off: ''
watts1:
friendly_name: 'Watts 1'
command_on: '6QAGAQQEFRsOGA8bIQkfCQwdCx0fCh8JHwoKHwoeHgsKHx0LHQseCwkgHQsJIB0LHQwcDQciBgABPAkgCR8JIBwNHA0HIQciGw4aEBgQBSMFIxoPBSQZDxkQGQ8FIxoPBSMaDxoOGg8FIwYAATwJIAggCSAcDRwMCCEHIRwNHAwcDQchCCEcDAggHQwcDRwMCCEcDAghHAwcDRwMCCEHAAE8CR8KHwkfHQwdCwkgCSAcDB0MHAwJIAggHQwIIB0MHAwdDAggHQwIIB0LHQwdDAggCQABOwkfCh4KHx4LHQsJIAkfHgsdCx0MCR8JIB0LCSAdCx0MHQsJIB0MCCAdCx0MHQsJIAkABdwAAA=='
command_off: '6Qs0AAsfCx8LHx8LHwsKIAofHwwfDB4MCiAKIB8LCiAfCx4MHgsKIB4MCiAKIB4MHgwKIAoAATsAAAAA'
watts2:
friendly_name: 'Watts 2'
command_on: '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'
command_off: '6Qc0AB4MHQwJIAkgHgwJIB4MHgweDAkgHgwJIQkgHgwJIAkgCgABOwsfCx8LHx8LHgwKIAogHgwAAAAA'
watts3:
friendly_name: 'Watts 3'
command_on: '6RI0AAsgHgsKIB4LHgweDAogHgwKIB0MCiAeDQogCgABOwsfCx8LHx8MHwsKIAogHgwfCx4MCiAAAAAA'
command_off: '6Rg0AAogHgsKIAogCiAeCwogCgABOwsfCx8LHx8LHwwKHwsfHwseDB4LCh8KIB4LCiAeDB4LHgwAAAAA'
wattsall:
friendly_name: 'Watts All'
command_on: '6SQ0AAwfCx8MHx8LHgwLHwogHwseDB8LCiALHx4MCx8eDB8MHgwKIR4MCiEeDAkhCiAfDAoAATsAAAAA'
command_off: '6Q40AAsfCx4LHx8LHgsLHwofHwseCx4LCiAKHx4LCh8eDB4LHgwKIB4MCiAKIAogCiAeCwoAAToAAAAA'
ba2uhn1:
friendly_name: 'Bauhn1'
#command_on: '6QDsAQAEOAQNBAACBBQEDwAB8io9tQQPBgsOEw0THQQMFRwEDBUaBwoWCxULFgsVGwYaBxkHChcJFwoXGQcaBxkIGAgJGBgJBxkXCgcaFgsGGhYLBQABDAcZFwoHGgYaBxoWCwYbFQwFGxULBhsFGwYaBhsWCxULFgoGGwYaBhoXChYLFgoWCwYaFgsGGhYLBhoWCgcaFgoHAAEKCRgYCQcZCBgIGRgICBkYCQcZGAgIGQgYCRgIGBgJGAgYCQgYCRgIGBgJGAgYCRgICRgYCAkYGAgJGBgICRgYCAgAAQoJFxkICRcJGAkXGQgJFxkICRcZCAkXCRgJFwkYGAgZCBgICRgJFwkYGAgZCBgIGQgJFxkICRcZCAkXGQgJFxkICAABCQoXGQcKFwkXChcZBwoXGQcJGBkHChcJFwoXCRcZCBkHGQgJFwoXCRcZCBkHGQgZBwkYGQcJGBkICBgZCAgYGQcJAAEJChcZBwoXCRcKFxkHChcZBwoXGQcKFwkXChcJFxkIGQcZCAkXChcJFxkIGQcZCBkICRcZCAkXGQgJFxkICRcZBwkAARAKFhoHCRcKFwkXGgcJFxoHCRcaBwkXChcJFwoXGQcaBxkICRcJFwoXGQcZCBkIGAgJGBgICRgYCAkXGQgJGBgICQAF3AcZFwoHGgYaBxoWCw=='
#command_off: '6QCcAQQEBCwjBA8NBAQNEw4THAQNFBsGCxUbBgsVCxYKFgsWGgYaBxkICRcKFwkXChcZBxkIGQcJGBgICRgYCRcKFwoGGhYLBgABCwcZFwoHGgcZBxoWCwYaFgwEHBUMBBwFGwYbBRsVDBULFQwFGwYaBhsGGhYLFQsWCwYaFgsGGhYLFgoWCwYaFgoHAAEKCBkXCgcZCBgIGRcKBxkXCgcZFwkIGQgYCBkIGBgJFwkYCQgYCBkIGAgZGAgYCRcJCBkYCAgZGAgYCRcJCBkXCQgAAQkKFxkICBgJGAkXGQgJFxkICBgZCAgYCRgJFwkYGAgZCBgICRgIGAkYCRcZCBgIGQgIGBkICBgZCBgIGQgIGBkICAABCQoXGQcKFwkXChcZBwoXGQcJGBkHCRgJFwkYCRcZCBkHGQgJGAgYCRcKFxkHGQgZCAgYGQcJGBkHGQgZCAgYGQcJAAEJChcZBwoXCRcKFxkHChcZBwoXGQcKFwkXChcJFxkIGQcZCAkXCRgJFwoXGQcZCBkHCRgZBwkYGQcZCBkHCRgZBwkABdwAAAAAAAAAAAAAAAA'
ba2uhn2:
friendly_name: 'Bauhn2'
#command_on: '6QCcARgEDgQPBDAEDRMOEw0UGwUMFRsFCxYbBgoWCxYKFgsWGQcaBxkHChcJFwoXGQcKFxkIGAgJGBgICRgYCAkYCBgYChYKBwABCggZFwoHGQgZBxkXCgcaFgsFHBQNBBwFGwUcBRsVDBULFQwFGwUbBhoWCwYaFgsWCgYbFgoHGhYKBxoGGhYLFgoGAAELCBgYCQgZBxkIGBgJCBgYCQgYGAkIGQcZCBgIGRgIGAkYCAgZCBgIGRgICBkYCBgJCBgYCQgYGAkIGAgZGAgYCQgAAQkJFxkICRgJFwkYGAgJGBgICRgYCAkYCRcJGAkXGQgYCBkICRcJGAkXGQgJFxkIGAgJGBgICBkYCAkYCBgZCBgICQABCAoXGQgJFwkYCRcZCAkXGQgJFxkICRcJGAkXCRcaBxkIGAgJGAkXCRgYCAkXGQgZCAkXGQgJFxkICRcJFxkIGQcJAAEJChYaBwoXCRcKFhoHChYaBwkYGQcJGAkXCRcKFxkHGgcZBwoXCRcKFxkICRcZBxkICRcZCAkXGQgJFwoXGQcZCAkABdwAAAAAAAAAAAAAAAA'
command_off: '6QCuAQoGBAQECAcEEgQFDgQNBAQEBAQJChIEBR0EDBULFQwUHAUMFRsFCxYaBgsWCxULFgoWGgcaBxkHChcJFwoXCRcKFxkHGQgJFxkICRgYCBgKBxkXChYKBgABCwgZFwoHGQcaBxkXCwUbFQ0EGxUMBRsGGwUbBhoWCxUMFQsGGgYbBhoGGwYaFgsWCgYaFwoGGhcKFgoHGhYKFwoGAAEKCRgYCQgYCBkIGBgJBxkYCQgYGAkIGAgZCBgIGBgJGAkXCQgZCBgIGAkYCBgYCRgICBkYCAkYGAgYCQgYGAkYCAgAAQkKFxkICRcJGAgYGQgIGBkICBgZCAgYCRgIGAkXGQgZCBgICRcJGAkXCRgJFxkIGAgJGBgICRgYCBkICRcZCBgICQABCQkXGQgJFwoXCRcZCAkXGQgJFxkICRcJGAkXCRgZBxkIGQcJGAkXCRgJFwkYGAgZCAkXGQgJFxkIGAgJFxkIGQcJAAEJChYaBwoXCRcKFxkHChcZBwkYGQcJGAkXCRgJFxkHGgcZCAkXCRcKFwkXChcZBxkICRcZCAkXGQgZBwkYGQcZCAkABdwAAAAAAAAAAAAA'
ba2uhn3:
friendly_name: 'Bauhn3'
command_on: '6QCUAQ0TDRQMFBwFCxUbBgsWGgYLFgoWCxYKFhoHGQcaBwkXChcJFxkIGQgIGBkICBgYCQgZFwoHGRcKFgsVDAQAAQwHGhYKBxoGGwYaFgwEHBULBhsVDAQcBRsGGgYbFQsWCxULBhsGGgYaFgsWCwYaFgoHGhYKBxoWCgcZFwoWCxYKBgABCwgYGAkIGAgZCBgYCQgYGAkIGBgJCBgIGQgYCBkXCRgJFwkIGQgYCBkXCRgJCBgYCQgYGAkIGBgJCBgYCBgJGAgIAAEJChcZCAkXCRgJFxkICBgZCAgYGQgIGAkYCBgJGBgIGQgYCAkYCBgJFxkIGAgJGBgICRgYCAkYGAgJGBgIGQgYCAkAAQgKFxkICRcJGAkXGQgJFxkICRcZCAkXCRgJFwkXGQgZCBgICRcKFwkXGQgZBwkYGQcJGBkHCRgZBwkYGAgZCBgICQABCQkXGQgJFwoXCRcZCAkXGQgJFxkICRcJGAkXCRcZCBkIGAgJFwoXCRcZCBkHCRgZBwkYGQcJGBkHCRgYCBkIGAgJAAXcAAAAAA=='
command_off: '6QAcAg8SDRMNFBwEDBUbBgsVGwYKFgsWChYLFhoGGgcZBwoXCRcKFwkXGQgJFxkICRcZCAkXGQgYCRcKFgsWCwUAAQsIGRcKBhoHGgYaFgwFGxUNBBwUDAUbBRwFGwUbFgsVCxUMBRsGGgYbBhoWCwYaFgsGGhYLBhoWCxYKFgoXChYKBwABCggYGAkIGQcZCBkXCQgYGAkIGRcJCBgIGQgYCBkXCRgJFwkIGQgYCBkIGBgICRgYCQgYGAkIGBgIGAkYCBgJGAgIAAEJChcZCAgYCRgIGBgJCBgYCQgYGAkIGAkXCRgJFxkIGAgZCAkXCRgJFwkYGAgJGBgICRgYCAkYGAgZCBgIGAkYCAgAAQkKFxkHCRgJFwoXGQcJGBkHCRgZBwkYCRcJGAkXGQgYCBkICRcJGAkXCRcZCAkXGQgJFxkICRcZCBkHGQgZBxkICAABCQoXGQcKFwkXChcZBwkYGQcJGBkHCRgJFwkXChcZCBgIGQgJFwkXChcJFxkICRcZCAkXGQgJFxkIGQcZCBgIGQgIAAEQCRcZCAkXChcJFxkICRcZCAkXGQgJFwkYCRcJFxoHGQgYCAkXChcJFwoXGQcKFxkHCRgZBwkYGQcZCBkHGQgYCAkAAQ8KFhoHChcJFwoXGQcKFhoHCRgZBwkXChcJFwoXGQcZCBkHChcJFwoXCRcZCAkXGQgJFxkICRcZCBgIGQgYCBkHCQAF3AgYGAkIGBgIGAkYCA=='
ba2uhn4:
friendly_name: 'Bauhn4'
#command_on: '6QAIAQgZFwkIGRcJCBkXCQgZCBgIGAkYGAgYCRgJBxkIGAkYGAgYCRgICBkIGBgJCBgYCQgYGAkIGAgYCAABCQoXGQgIGAkXCRgZBwkYGQcJGBgICRgJFwkYCRcZCBgIGQgJFwkYCBgZBxkIGQgIGAkXGQgJFxkICRcZCAkXCRcJAAEJChYaBwkXChcJFxkICRcZCAkXGQgJFwkYCRcJFxoHGQcZCAkXChcJFxkIGQcZCAkXCRgZBwkYGAgJGBgICRgJFwkAAQgKFxkHChcJFwoXGQcKFxkHChcZBwoXCRcKFwkXGQgZBxkICRcJFwoXGQcZCBkHChcJFxkICRcZCAkXGQgJFwkXCQAF3A'
#command_off: '6QCiAQYEBAQFBAQIBgcQBB4EDRQMFA0UGwUMFRsFDBUbBQsWChcKFgsWGgYaBxkHChcJFwoXCRcZCBkHCRgJFxkICRcZCBgJFwoHGQcaBgABCgkYGAkIGAgZBxkYCQcaFgsGGhYMBBwFGwYbBRsVDBULFQwFGwUbBhoHGhYLFQsGGgYbFgoGGxYKFgsWCgYaBxoGAAEKCRgYCQcZCBkHGRgJBxkYCQcZGAkHGQgYCBkIGBgJFwkYCQgYCBkIGAgYGAkYCQgYCBgYCQgYGAkYCBgJCBgJFwkAAQkJFxkICRcJGAkXGQgJFxkICRcZCAkXCRgJFwkYGAgZCBgICRgIGAkXCRgZBxkICRcJGBgICRgYCBkIGAgJGAgYCQABCAoXGQcKFwkXChcZBwkYGQcJGBkHCRgJFwkXChcZBxkIGQcKFwkXChcJFxkIGQcJGAkXGQgJFxkIGAgZCAkXCRcJAAEJChYaBwkXChcJFxkICRcZCAkXGQgJFwkXChcJFxoHGQcZCAkXChcJFwoXGQcZCAkXCRgZBwkYGQcZCBgICRcKFwkABdwAAAAAAAA'
ba2uhn5:
friendly_name: 'BauhnAll'
#command_on: '6QCjAQQEFgcECQQEBAQEBgQ7BA4SDRQMFBwFCxYbBQsWGgYLFgoWCxYKFhoHGQcaBwkYCRcKFwkXGQcKFwkYCRcZBwkYGQcZCBgJFwoHGQcAAQoIGRcKBxkIGAgZFwoHGRcKBhsVDQQbBRwFGwUcFQsVDBULBRwFGwUbBhoWCwYaBhsGGhYLBhoWCxYKFgoWCwYaBwABCggYGAkIGAgZCBgYCQcZGAkHGRgJBxkIGAgZCBgYCRgIGAkIGAgZCBgIGRcJCBgJGAgYGAkIGBgJGAgYCRgICBgJAAEJCRcZCAkXCRgJFxkICBgZCAgYGQgIGAkXCRgJFxkIGAgZCAkXCRgIGAkXGQgJFwkYCRcZCAkXGQgYCBkIGAgJFwkAAQkKFhkICRcKFwkXGQgJFxkICRcZCAkXCRgJFwkXGQgZBxkICRcJGAkXChcZBwkYCRcJGBgICRcZCBkHGQgZCAkXCQABCAoWGgcKFwkXChYaBwoWGgcJFxoHCRcKFwkXChcZBxkIGQcKFwkXCRgJFxkICRcJFwoXGQcKFxkHGQgZBxkICRcJAAXcAAAAAAA'
command_off: '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'
