Broadlink RM Pro setup failure and error after latest upgrade of hassio
Yeah, I forgot this fondamental rule
Sorry, I’m not using Hassio, therefore I can’t provide a workaround.
See you found the process, hope all is good for you now :slight_smile:
Im still dead with no clue as what to do. Curl command not found
0.64.1 will fix broadlink issues identified in 0.64. Not sure how long after for hass.io to get the update.
https://github.com/home-assistant/home-assistant/pull/12742
Ok i will have to wait until then i guess no choice
Ok just upgraded to 0.64.1 and it switched well
Hey 0.64.1 is out. We give it a go, or better wait 0.64.2 :slight_smile:
:rofl:
I was going to wait for 64.2 as there was no mention of Broadlink fixes in the release notes that I could see but @dearlk seems happy.
Updated to 0.64.2 and now i`m stuck on loading data screen. Will curl to the 0.59.1 again.
In for a penny etc… all good now. Seemed to take longer to update than normal and threw a load of unobvious errors but after another restart it cleared up.
Hass.io panel is still a bit reluctant sometimes but it’s been like that since they changed it.
