Broadlink S1C Alarm Kit Custom Sensor Component
hi I have hassbian 0.65.5, I followed the guide but the sensors do not appear in the home assistant, in the log I see:
File “/home/homeassistant/.homeassistant/custom_components/sensor/broadlink_s1c.py”, line 91, in async_setup_platform
conn_obj = HubConnection (ip_address, mac_addr, timeout)
File “/home/homeassistant/.homeassistant/custom_components/sensor/broadlink_s1c.py”, line 172, in init
self._hub = broadlink.S1C ((ip_addr, 80), mac_addr)
AttributeError: module ‘broadlink’ has no attribute ‘S1C’
I tried to delete the broadlink_s1c.cpython-35.pyc file and restart HA but without success.
How can I solve?
Correct extension is .py not .pyc maybe is The reason Why this file in not found…
Ciao Roberto
the file broadlink_s1c.cpython-35.pyc automatically creates it on reboot in the pycache_ folder
Have you put this file broadlink_s1c.py in the right folder?
yes, i have put the broadlink_s1c.py file in: /home/homeassistant/.homeassistant/custom_components/sensor
It seem not using broadlink 0.6 but previus version and don’t find s1c library have you Used last version plugin ?
i have used the last component sensor https://github.com/TomerFi/home-assistant-custom-components/tree/master/broadlink_s1c/custom_components/sensor
Right ! Try to restart raspberry and see if work , otherwise you need force use of broadlink library 0,6 all’ is tested since version HA 0.65.4
i have restart the raspberry but don’t work.
How i force the library 0.6 ?
Yes becouse ha use broadlink 0.5 as default while s1c sensor working only with broadlink 0.6
how do i make it work with 0.6?
Now works!
with hassbian 0.65.5 don’t work, i updated to 0.65.6 and it work!
edit:
it worked once, but you have later reboots no longer worked…
I installed this with the latest HA, 0.65.6 but I get this error:
What do I need to modify to get this to work with the latest HA?
Thank you Tomer
The configuration should be like this
  • platform: broadlink_s1c
    ip_address: 192.168.31.68
    mac: ‘34:EA:34:XX:XX:XX’
    timeout: 10
Is the timeout in minutes or seconds?
Thanks as always
Seconds …
I’ve updated the component:
  • Fixed for version 0.67.1 which uses the new broadlink 0.8 library.
  • Canceled the use of the custom broadlink 0.6 library (If you’re updating from the previous version, please make sure there is no broadlink folder in your /config/deps folder).
  • Fix unnecessary log writes of repeated time outs (@Marc_R this one is for you :wink: )
@roberto87 @imperialjoy
Sorry it took me so long to reply.
I hope you got the component working.
If not, please try the new version.
If it still doesn’t work please reply with log details and I’ll do my best to help.
Thank you so much. I will try tonight. By the way the old one is working fine for me. The only problem is that if I restart HA. The status will show unknown. So I have to turn on then off the alarm to get the new status of the alarm.
For those who got this error
> Traceback (most recent call last):
      File "/srv/homeassistant/lib/python3.5/site-packages/homeassistant/helpers/entity_platform.py", line 82, in async_setup
        SLOW_SETUP_MAX_WAIT, loop=hass.loop)
      File "/usr/lib/python3.5/asyncio/tasks.py", line 400, in wait_for
        return fut.result()
      File "/usr/lib/python3.5/asyncio/futures.py", line 293, in result
        raise self._exception
      File "/usr/lib/python3.5/asyncio/tasks.py", line 239, in _step
        result = coro.send(None)
      File "/usr/lib/python3.5/asyncio/coroutines.py", line 210, in coro
        res = func(*args, **kw)
      File "/home/homeassistant/.homeassistant/custom_components/sensor/broadlink_s1c.py", line 91, in async_setup_platform
        conn_obj = HubConnection(ip_address, mac_addr, timeout)
      File "/home/homeassistant/.homeassistant/custom_components/sensor/broadlink_s1c.py", line 172, in __init__
        self._hub = broadlink.S1C((ip_addr, 80), mac_addr)
      File "/srv/homeassistant/lib/python3.5/site-packages/broadlink/__init__.py", line 753, in __init__
    TypeError: __init__() missing 1 required positional argument: 'devtype'
To fix it, I’ve download last version of the fantastic python script of @TomerFi put it in its custom folder and then I deleted the file:
custom_components/sensor/__pycache__/broadlink_s1c.cpython-35.pyc
Restarted home assistant with:
systemctl restart [email protected]
Tested on Broadlink Alarm kit S2C and it works :slight_smile:
That’s all
