Here my config
- platform: broadlink
host: 192.168.1.8
mac: 'xxxxxxxx'
timeout: 200
switches:
led_red:
friendly_name: "Red LED"
command_on: 'JgBQAAABJ5QSExEUERQRFBIUERMSFBEUETgROBI4ETgRFBE4EjgROBEUERQSNxIUERQRFBEUERQROBI4ERQROBE4EjgROBE4EgAFQgABJkoSAA0FAAAAAAAAAAA='
command_off: 'JgBYAAABJ5QUERMSEhQSExITEhMSExMSEzcSNxI3EjgRFBI3EzcSNxITEjgRFBEUERQSExITExISOBITETgTNxE4EjcTNxE4EgAFQgABJ0oSAAxQAAEmShIADQU='
blue_led:
friendly_name: "Blue Led"
command_on: 'JgBQAAABJ5QTExITERQSExITERQSExMSEzcROBE4EzcSExE4EzYTNxEUEjcSOBEUEhMSExITERQSNxIUERQSNxI3EjgSNxI3EgAFQgABKEkSAA0FAAAAAAAAAAA='
command_off: 'JgBQAAABJ5QTExITERQSExITERQSExMSEzcROBE4EzcSExE4EzYTNxEUEjcSOBEUEhMSExITERQSNxIUERQSNxI3EjgSNxI3EgAFQgABKEkSAA0FAAAAAAAAAAA='
green_led:
friendly_name: "Green LED"
command_on: 'JgBYAAABJ5USExITEhMSExMSEhQRFBEUEjcTNxI3EjcTExE4EjcTNxI3EhMSNxMTERQRFBITEhMSExI4EhMSNxM3EjcSNxM3EQAFQwABJ0oSAAxQAAEnShIADQU='
command_off: 'JgBQAAABJJMSEhISETgSEhITEBMSEhMSETcSNxMREjcSNxI3EjcSOBETERITNhM2EhITERM2EzcRNxI3ExISEhI3EjcRExETEgAFLQABJEoRAA0FAAAAAAAAAAA='
light1_livingroom:
friendly_name: "Livingroom Down Lights"
command_on: 'slA0AA0iDSINIg0iDSIkCw0iJAsNIg0iDSINIg0iDSINIiQLDSINIg0iJAsNIiQLDSIkCw0AAUUAAAAA='
command_off: 'sjc0AA0iDSINIg0iDCMkCw0iJAsNIg0iDSINIg0iDSINIiMLDSINIg0iJAsNIiQLDSINIg0AAUUAAAAA='
livingroom_led_power:
friendly_name: "Livingroom LED Power"
command_on: 'slE0AA0jDCINIw0jDSIkDA0iJAwNIyQMDSINIg0iDSINIiQMDCMNIw0iJAwNIyQMDSIkDAwAAUQAAAAA='
command_off: 'sk00AAwjDSMNIwwjDCMjDAwjIwwMIyMMDCMMIwwjDCMMIyMMDCMNIwwjIwwNIyQMDCMMIwwAAUUAAAAA='
kitchen_led_power:
friendly_name: "Kitchen LED Power"
command_on: 'slE0AA0iDSINIg0iDSIkCw0iJAwNIw0iDSMkCw0jDSMNIiQMDSMNIg0iJAsNIiQLDSIkDA0AAUUAAAAA='
command_off: 'sjs0AAwjDCMNIw0jDCMkDA0jIwwMIwwjDCMjDAwjDCMMIyMMDCMMIwwjIwwMIyMMDCMMIwwAAUUAAAAA='
This is my config. I had same problem all i did was add = <- Equals symbol to end of each command on and command off and then the switches would show up in my frontend.
Wheezy
May 31, 2017, 11:24pm
10
I was organizing my IR buttons into scripts so that they wouldn’t be switches and I realized you might be able to bypass the whole “switches not showing up” thing if you ran scripts using the “send_packet” command example from the broadlink component page .
script:
tv_select_source:
- service: broadlink.send_packet_192_168_0_107
packet:
- "JgCMAJSSFDYUNhQ2FBEUERQRFBEUERQ2FDYUNhQRFBEUERQRFBEUERQRFDYUERQRFBEUERQRFDYUNhQRFDYUNhQ2FDYUNhQABfWUkhQ2FDYUNhQRFBEUERQRFBEUNhQ2FDYUERQRFBEUERQRFBEUERQ2FBEUERQRFBEUERQ2FDYUERQ2FDYUNhQ2FDYUAA0FAAAAAAAAAAAAAAAA"
I wanted to clean up my IR blaster HASS dashboard buttons anyway by making scripts to trigger the switches, since I think it looks nicer. If you want to try that, read on – if not, no worries I just got excited and wanted to post my setup below:
Making broadlink switches into grouped scripts:
Code for my switches (re-posted with new variable names):
switch:
#Broadlink "RM mini 3" IR Transciever
# type: rm_mini
timeout: 15
host: 192.168.1.12
mac: '34:EA:34:B2:F0:E5'
switches:
ac_power:
friendly_name: "AC Power"
command_on: 'JgBoAAABJJQSNxETEhMRExITERMSExE4ERMSNxI3EhMRExI3EjgRExE4EhMRExITERMSExETEjcSExE4ETgROBE4ETgROBITEQAFZgABI0sRAAxAAAEjSxEADD8AASRKEgAMPwABI0sRAA0F'
command_off: 'JgBoAAABJJQSNxETEhMRExITERMSExE4ERMSNxI3EhMRExI3EjgRExE4EhMRExITERMSExETEjcSExE4ETgROBE4ETgROBITEQAFZgABI0sRAAxAAAEjSxEADD8AASRKEgAMPwABI0sRAA0F'
ac_temp_up:
friendly_name: "AC Temp Up"
command_on: 'JgBYAAABJpEUNRQRFBAUERQRExEUERM2ExEUNRQ1FBETERQ1FDUUERM2FBAUNRQRFBAUERQREzYTERQ1FBETNhM2EzYTNhMRFAAFZAABJUkTAAw9AAEmSBQADQU='
ac_temp_down:
friendly_name: "AC Temp Down"
command_on: 'JgBQAAABJZIUNRQRExEUERMRFBETERQ1FBETNhQ1FBETERQ1FDUUERMRFDUUERM2ExEUERMRFDUUNhMRFDUUERM2EzYTNhMRFAAFZAABJUkTAA0FAAAAAAAAAAA='
ac_fan_speed:
#Cycles through three available fan speeds when pressed repeatedly
friendly_name: "AC Fan Speed"
command_on: 'JgBQAAABJZIUNRQRExEUERMRFBEUERM2ExEUNRQ1FBETERQ1FDUUERM2ExEUERQ1FDUUERMRFDUUERM2EzYTERQREzYTNhMRFAAFZAABJUkTAA0FAAAAAAAAAAA='
ac_mode:
friendly_name: "AC Mode"
command_on: 'JgCAAAABJpEUNhMRFBETERQRExEUERM2ExEUNRQ1FBETERQ1FDYTERQ1FDUUERM2EzYTERQREzYTERQREzYTEhMREzYTNhMSEwAFYwABJkkUAAw9AAElSRMADD4AASVJEwAMPgABJUkTAAw9AAEmSRMADD0AASZIFAAMPQABJkgUAA0FAAAAAAAAAAA='
ac_timer:
#Timer goes up to 24 when pressed repeatedly
friendly_name: "AC Timer"
command_on: 'JgB4AAABJZEUNhMRFBETERQRExEUERM2ExEUNRQ1FBETEhM2EzYTERQ1FDUUNRQ1FDUUERMRFDUUERQRExEUERMRFDUUNRQREwAFZQABJUgUAAw8AAEmSRMADD0AASZJEwAMPQABJkgUAAw9AAElSRMADD4AASVIFAANBQ=='
livingroom_amp_power:
friendly_name: "Livingroom Amp Power"
command_on: 'JgCoAFASKBIWESkRFhEpEhUSFhEWERYRFhIVEigAA0tQEikRFhIoEhUSKREVEhUTFRIVEhUSFRMnAANMTxMoEhUSKBIVEygSFRIVEhUTFBMVEhUSKAADTE8TJxMVEigSFRIoExQTFRIVEhUSFRMVEigAA0tPEygSFRMoEhUSKREWERYSFRIWERYRFhEpAANLUBIoEhYRKREWEigSFhEWERYRFhIVEhYRKQANBQ=='
command_off: 'JgCoAFASKBIWESkRFhEpEhUSFhEWERYRFhIVEigAA0tQEikRFhIoEhUSKREVEhUTFRIVEhUSFRMnAANMTxMoEhUSKBIVEygSFRIVEhUTFBMVEhUSKAADTE8TJxMVEigSFRIoExQTFRIVEhUSFRMVEigAA0tPEygSFRMoEhUSKREWERYSFRIWERYRFhEpAANLUBIoEhYRKREWEigSFhEWERYRFhIVEhYRKQANBQ=='
livingroom_amp_vol_up:
friendly_name: "Livingroom Amp Vol Up"
command_on: 'JgCMAE8TFRIoEhUSFRMoEhUSFRIVExQTFRIVEigAA19PEhUTKBIVEhUSKBMUExUSFRIVEhUTFBMoAANeTxMVEigTFBMVEigSFRIVExQTFRIVEhUSKAADX08TFBMoEhQTFRMnExQTFRIUExQUFBMUEygAA19PEhUTJxMVEhUSKBIVExQTFRIVEhUTFBMnAA0FAAAAAAAAAAAAAAAA'
livingroom_amp_vol_down:
friendly_name: "Livingroom Amp Vol Down"
command_on: 'JgCMAFASKBMoEhUSFRIoEhUTFBMVEhUSFRIVEygAA0tPEygSKBIVExUSKBIVEhUSFRMVEhUSFRIoAANMTxMoEigSFRIVEigTFRIVEhUSFRMUExUSKAADS1ASKBMnExUSFRIoEhUTFBMVEhUSFRIUFCgAA0tPEygSKBIVExUSKBIVEhUSFRMVEhUSFRIoAA0FAAAAAAAAAAAAAAAA'
livingroom_amp_bass_boost_eq:
friendly_name: "Livingroom Amp Bass Boost EQ"
command_on: 'JgCqAE8TKBIVEigTJxMVEhUSKBIVExQTFRIVEigSFRMVEigAArBPEygSFRIoEigSFRMUEygSFRIVEhUTFRIoEhUSFRMnAAKwUBIoExQTKBIoEhUSFRMnExUSFRIVEhUTKBIVEhUSKAACsE8TKBIVEigTJxMVEhUSKBIVExQTFRIVEigSFRMVEigAArBPEygSFRIoEigSFRMVEigSFRIVEhUTFRIoEhUSFRMnAA0FAAAAAAAAAAAAAAAAAAA='
I made scripts to trigger my switches, so that there’s an “activate” button instead of toggles or on/off buttons. You could just do the send_packet thing here instead.
script:
#These IR scripts are written so that HASS dashboard will display a one-shot "activate" button for these 'dumbfire' IR blasts (instead of a displaying a toggle for a smartdevice, which would falsely imply a known state of on/off for each action)
ac_temp_up:
- service: switch.turn_on
entity_id: switch.ac_temp_up
ac_temp_down:
entity_id: switch.ac_temp_down
ac_fan_speed:
entity_id: switch.ac_fan_speed
ac_mode:
entity_id: switch.ac_mode
ac_timer:
entity_id: switch.ac_timer
entity_id: switch.livingroom_amp_vol_up
entity_id: switch.livingroom_amp_vol_down
entity_id: switch.livingroom_amp_bass_boost_eq
Bonus round: Customize icons + hide any extra unused switches:
customize:
switch.ac_power:
friendly_name: "Power"
icon: mdi:power
assumed_state: false
script.ac_temp_up:
friendly_name: "Temp up"
icon: mdi:thermometer-lines
script.ac_temp_down:
friendly_name: "Temp down"
icon: mdi:snowflake
script.ac_fan_speed:
friendly_name: "Fan speed"
icon: mdi:fan
script.ac_mode:
friendly_name: "Mode"
icon: mdi:settings-box
script.ac_timer:
friendly_name: "Timer"
icon: mdi:av-timer
switch.livingroom_amp_power:
icon: mdi:power
script.livingroom_amp_vol_up:
friendly_name: "Vol up"
icon: mdi:volume-plus
script.livingroom_amp_vol_down:
friendly_name: "Vol down"
icon: mdi:volume-minus
script.livingroom_amp_bass_boost_eq:
friendly_name: "Bass boost EQ"
icon: mdi:speaker-wireless
#Hidden items
switch.ac_temp_up:
hidden: true
switch.ac_temp_down:
icon: mdi:snowflake
hidden: true
switch.ac_fan_speed:
icon: mdi:fan
hidden: true
switch.ac_mode:
hidden: true
switch.ac_timer:
icon: mdi:av-timer
hidden: true
switch.livingroom_amp_vol_up:
hidden: true
switch.livingroom_amp_vol_down:
hidden: true
switch.livingroom_amp_bass_boost_eq:
hidden: true
Wheezy
June 1, 2017, 12:05am
11
[quote=“robertpe, post:5, topic:18895”]
File “/Library/Frameworks/Python.framework/Versions/3.6/lib/python3.6/base64.py”, line 87, in b64decode
return binascii.a2b_base64(s)
binascii.Error: Incorrect padding[/quote]
[quote=“aimwarlock, post:9, topic:18895”]
I had same problem all i did was add = … Equals symbol to end of each command on and command off and then the switches would show up in my frontend.[/quote]
I may have gotten carried away. I re-read your post and it sounds like there could be a problem with the formatting of your capture code? Try capturing some new codes and ensure they’re in base64 ? (you already mentioned you found the capture service via: HomeAssistant > Developer Tools > Services > “Domain:” broadlink , “Service:” learn_command_192_168_1_xx , but just making sure you’re using that one).
Another thing it could be: I learned by accident that variables cannot have capital letters in them. Maybe try changing “thing”/“item”/“variable” names, like CONF_COMMAND_OFF, to lowercase.
I’d like to see your code too
finity
September 13, 2017, 3:37am
12
@Wheezy
How did you get your A/C power & livingroom speaker amp power controls to be toggles instead of the default lightning bolts?
I don’t see any icon customizations for those.
Wheezy
September 14, 2017, 6:27pm
14
Good question!
Hm, I can’t remember, but here’s all my code including groups and views if that helps (see All IR Blaster Code: below). I forgot to post the groups and views code above, so maybe the fact that I’ve grouped them makes HASS do this slider action instead of lightning bolts? It may also be by action of the assumed_state: false
setting under each switch’s homeassistant: customize:
custom display field.
A note on making single-shot “ACTIVATE” buttons though (I accidentally wrote this paragraph and then realized you probably meant those jelly bean sliders, not the activate buttons, and I also realized I already wrote about this haha, but I’m just gonna post this info anyway since this time I wrote a cleaner post): Since the broadlink creates a switch for every IR command (one command is the “on” switch, another command or the same command can be the “off” side of the switch), I created separate scripts that trigger the “on” of each Broadlink-made switch. It’s redundant code, and cumbersome to implement. I wish the Broadlink component had an easier workaround for this (I know you can just create scripts that fire IR codes, but I like to see all variable collected under the Broadlink component in my YAML, so I still use the switches).
Sample code for one-shot buttons that say “ACTIVATE”:
homeassistant:
customize:
script.ac_temp_up:
switch:
# type: rm_mini
timeout: 15
host: 192.168.1.12
mac: 'xx:xx:xx:xx:xx:xx'
switches:
ac_temp_up:
command_on: 'JgBYAAABJpEUNRQRFBAUERQRExEUERM2ExEUNRQ1FBETERQ1FDUUERM2FBAUNRQRFBAUERQREzYTERQ1FBETNhM2EzYTNhMRFAAFZAABJUkTAAw9AAEmSBQADQU====='
script:
ac_temp_up:
group:
ac_remote:
name: "Air Conditioner"
control: hidden
entities:
- switch.ac_power
- script.ac_temp_up
- script.ac_temp_down
- script.ac_fan_speed
- script.ac_mode
- script.ac_timer
homeassistant:
customize:
#AC Unit button names & icons
switch.ac_power:
icon: mdi:power
script.ac_temp_up:
icon: mdi:snowflake
icon: mdi:fan
script.ac_mode:
script.ac_timer:
icon: mdi:av-timer
#Livingroom Stereo Amp button names & icons
icon: mdi:power
#Hidden items
switch.wakeup_the_broadlink:
hidden: true
switch.ac_temp_up:
hidden: true
icon: mdi:snowflake
hidden: true
icon: mdi:fan
hidden: true
switch.ac_mode:
hidden: true
switch.ac_timer:
icon: mdi:av-timer
hidden: true
hidden: true
hidden: true
hidden: true
script.ac_poweroff:
hidden: true
script.ac_poweron:
hidden: true
script.livingroom_amp_poweroff:
hidden: true
switch:
# type: rm_mini
timeout: 15
host: 192.168.1.12
switches:
#Fire 0x00 as a dummy code. This will wake up the broadlink device if it hasn't been used in a six-ish or so hours. Otherwise codes do not seem to fire properly when waking up the house???
friendly_name: "Wakeup the Broadlink"
command_on: '================'
command_off: '================'
ac_power:
ac_temp_up:
ac_temp_down:
ac_fan_speed:
command_on: 'JgBQAAABJZIUNRQRExEUERMRFBEUERM2ExEUNRQ1FBETERQ1FDUUERM2ExEUERQ1FDUUERMRFDUUERM2EzYTERQREzYTNhMRFAAFZAABJUkTAA0FAAAAAAAAAAA====='
ac_mode:
command_on: 'JgCAAAABJpEUNhMRFBETERQRExEUERM2ExEUNRQ1FBETERQ1FDYTERQ1FDUUERM2EzYTERQREzYTERQREzYTEhMREzYTNhMSEwAFYwABJkkUAAw9AAElSRMADD4AASVJEwAMPgABJUkTAAw9AAEmSRMADD0AASZIFAAMPQABJkgUAA0FAAAAAAAAAAA====='
ac_timer:
command_on: 'JgB4AAABJZEUNhMRFBETERQRExEUERM2ExEUNRQ1FBETEhM2EzYTERQ1FDUUNRQ1FDUUERMRFDUUERQRExEUERMRFDUUNRQREwAFZQABJUgUAAw8AAEmSRMADD0AASZJEwAMPQABJkgUAAw9AAElSRMADD4AASVIFAANBQ=========='
command_on: 'JgCoAFASKBIWESkRFhEpEhUSFhEWERYRFhIVEigAA0tQEikRFhIoEhUSKREVEhUTFRIVEhUSFRMnAANMTxMoEhUSKBIVEygSFRIVEhUTFBMVEhUSKAADTE8TJxMVEigSFRIoExQTFRIVEhUSFRMVEigAA0tPEygSFRMoEhUSKREWERYSFRIWERYRFhEpAANLUBIoEhYRKREWEigSFhEWERYRFhIVEhYRKQANBQ=========='
command_off: 'JgCoAFASKBIWESkRFhEpEhUSFhEWERYRFhIVEigAA0tQEikRFhIoEhUSKREVEhUTFRIVEhUSFRMnAANMTxMoEhUSKBIVEygSFRIVEhUTFBMVEhUSKAADTE8TJxMVEigSFRIoExQTFRIVEhUSFRMVEigAA0tPEygSFRMoEhUSKREWERYSFRIWERYRFhEpAANLUBIoEhYRKREWEigSFhEWERYRFhIVEhYRKQANBQ=========='
command_on: 'JgCqAE8TKBIVEigTJxMVEhUSKBIVExQTFRIVEigSFRMVEigAArBPEygSFRIoEigSFRMUEygSFRIVEhUTFRIoEhUSFRMnAAKwUBIoExQTKBIoEhUSFRMnExUSFRIVEhUTKBIVEhUSKAACsE8TKBIVEigTJxMVEhUSKBIVExQTFRIVEigSFRMVEigAArBPEygSFRIoEigSFRMVEigSFRIVEhUTFRIoEhUSFRMnAA0FAAAAAAAAAAAAAAAAAAA====='
script:
#These scripts are here so that HASS dashboard will display a one-shot "activate" button for these 'dumbfire' IR blasts (instead of a displaying a toggle for a smartdevice, which would falsely imply a known state of on/off for each action)
ac_temp_up:
ac_temp_down:
ac_fan_speed:
ac_mode:
ac_timer:
#These scripts are kludges for IR blasters since they will fire twice if "off" switch is triggered twice.
#This is a problem if the on/off signal are the same IR signal
ac_poweroff:
#activate turn_off only if switch.ac_power is 'on'
- condition: template
value_template: >
{% if is_state('switch.ac_power', 'on') %}
true
{% elif is_state('switch.ac_power', 'off') %}
false
false
- service: switch.turn_off
entity_id: switch.ac_power
ac_poweron:
value_template: >
{% if is_state('switch.ac_power', 'off') %}
true
{% elif is_state('switch.ac_power', 'on') %}
false
false
#activate turn_off only if switch.livingroom_amp_power is 'on'
value_template: >
{% if is_state('switch.livingroom_amp_power', 'on') %}
true
{% elif is_state('switch.livingroom_amp_power', 'off') %}
false
false
entity_id: switch.livingroom_amp_power
group:
ac_remote:
control: hidden
entities:
- switch.ac_power
- script.ac_temp_up
- script.ac_mode
- script.ac_timer
#Air conditioner tab
hvac_view:
view: yes
#name: T
entities:
- sensor.indoor_temp
- sensor.pws_temp_f
- sensor.pws_weather
- group.thermostat
- group.ac_remote
- group.sensor_node_1_card
- group.sensor_node_2_card
#Audio tab
audio_view:
view: yes
#name: Hz
entities:
- group.residence_radio
- group.livingroom_amp_remote
- switch.kitchen_speaker_amp
- switch.bathroom_speaker_amp
- group.chromecast_controls
finity
September 15, 2017, 2:56am
15
Yes, it was the assumed_state: false that sets the display to the toggle. (thanks, @Bobby_Nobble )
But…
I ran into a situation (that I created another thread about) in which I set all the broadlink entities to assumed_state: false and all but one of them displayed the toggle afterwards. I’m not sure where the assumed_state: true was being set but it was listed in the entity attributes as true. I could force it to false there and the display changed to a toggle but as soon as I restarted HA it went right back to the two buttons again.
Someone suggested I put the assumed_state: false in the customize_glob: section for the desired switches and so far that has seemed to make it stick.
Still not sure why/where it was being set to true when none of the others were, tho.
Hi Wheezy,
really like your script and would like to learn more on creating group tab etc,
If you dont mind could you share the complete code? I just need to learn how to do some stuff… very nubie, however I manage to change to button thanks to your detail code.
TIA…
Wheezy
January 9, 2018, 4:12pm
17
Hey, I’m glad it helped. I think you’re wondering how to create new tabs for your main HASS dashboard? Those tabs are called “Views”. “Groups ” are basically cards on the dashboard. The “group:” area in your configuration.yaml file defines both groups and views.
I remember this being a difficult thing to learn when I was just starting too, since the terminology is so confusing. BRUH Automation’s YouTube channel helped me a lot. I recommend checking out Ben’s video here to get your started https://www.youtube.com/watch?v=EsBtyF5tZQ4&feature=youtu.be&t=8m11s
I’ll also copy-paste part the “group:” part of my configuration.yaml file below along with some images. Please let me know if that doesn’t answer the question though. (I’ve added some devices since I last posted my code, but the above code is also still implemented in my setup).
# GROUPS & VIEWS #
#Views are pages, selectable at the top of HASS dashboard. Groups are
# "display cards" that put many switches into the same box in a page
# of HASS dashboard.
####GROUPS
#group: !include groups.yaml
group:
zones:
entities:
- sensor.template_last_motion
- binary_sensor.floorplan
chromecast_controls:
entities:
- media_player.all_home_speakers
- media_player.livingroom_speakers
- media_player.bedroom_speakers
- media_player.kitchen_speakers
- media_player.bathroom_speakers
livingroom_lights:
entities:
- light.livingroom_1
- light.livingroom_2
- light.livingroom_3
- light.livingroom_4
kitchen_lights:
entities:
- light.kitchen_1
- light.kitchen_2
kitchen_table_lights:
entities:
- light.kitchen_table_1
- light.kitchen_table_2
bedroom_lights:
entities:
- light.bedroom_1
- light.bedroom_2
bathroom_lights:
entities:
- light.bathroom_1
- light.bathroom_2
- light.bathroom_3
- light.bathroom_4
color_temperature:
name: Brightness / Temperature
entities:
- group.livingroom_lights
- group.kitchen_lights
- group.kitchen_table_lights
- light.hallway
- group.bathroom_lights
- group.bedroom_lights
tradfri_lights:
entities:
- light.livingroom
- light.kitchen
- light.bedroom
- light.bathroom
####VIEWS
#Default tab: If this is enabled, ONLY things defined here will show up in HASS main view!!!
default_view:
view: yes
entities:
#Dashboard gauges
- device_tracker.xxxxxxxxxxxxxxxxxxxxxxxxxxxxx
#- sensor.pws_temp_f
- sensor.dark_sky_temperature
- sensor.pollen_level
#Things
- script.eggs_and_bakey
- script.bedtime
- automation.kodi_movie_mode_while_playing_media
- automation.kodi_house_mode_when_media_stops
- automation.powerup_on_arrival
- automation.powerdown_on_departure
- automation.porch_lit_on_arrival
- media_player.tv_pc
- media_player.ps4
- switch.scented_wax_warmer
#- switch.wake_tv_pc
- group.alarm
#Audio tab
audio_view:
view: yes
#name: Hz
entities:
- group.bedroom_amp_remote
- group.music_spotify
# Spotify media player only displays artwork of currently playing songs.
# It leaves the artwork up after Spotify is off. Also, no controls work (play/pause/stop/forward/back).
# Chromecast Audio works for displaying the same artwork and stopping play.
# - media_player.spotify
- switch.sound_machine
hvac_view:
view: yes
#name: T
entities:
- sensor.livingroom_temp
- sensor.bedroom_temp
- group.thermostat
- group.ac_remote
- group.heater_remote
lights_view:
view: yes
#name: hν
entities:
- switch.fluxer
- switch.porch_light
- group.color_temperature
- group.tradfri_lights
Wheezy
January 9, 2018, 4:21pm
18
Edit: Code error above … (the post is too old to edit at this point, but one IR command should be the following instead)
ac_temp_down:
command_on: 'JgBQAAABI5QSNxITERQRExITERMSExE4ERMSNxI3EhMRExI3EjcSExETEjcSExE4EhMRExITETgROBETEjcSExE4ETgSNxETEgAFZgABI0sRAA0FAAAAAAAAAAA====='
Thank you sooo much… you have been a great help…
ulesin
March 4, 2018, 11:05pm
20
Hi Wheezy!
First of all, I want to thank you for your help. The second is that I have a problem with the power switch, once it is in the ‘on’ state and restart home assistant, it returns to false status. I have tried many things but nothing. Does anything have to do with the recorder? I do not understand the scripts either ac_poweroff and ac_poweron.
I do not give with the key… thank you in advance!
dramamoose
(David Morris-Stump)
March 8, 2018, 6:12am
21
As far as I know, HASS does not do well with saving states. It doesn’t like to assume anything. When you restart, it will lose whatever you sent last. I have the same issue with my TV power.
Therein lies the big problem with Broadlink controlled RF devices. Worth replacing anything that really matters what the state is with wifi, direct or via mqtt, controlled devices which will report state and sort themselves out when restarting HA. The ubiquitous Sonoff Basics with Tasmota are probably cheaper than the dumb device you’d be replacing.
dave122
(Dave)
March 13, 2018, 4:02am
23
Hey Wheezy,
Can’t thank you enough for sharing your code, Im just getting started with home assistant and you saved me a whole bunch of time and frustration.
Can you please show the config behind the group.sensor_node_1_card & group.sensor_node_2_card entries? I would like to get the temps in a card rather than the bubbles.
Thanks!
Dave
dave122
(Dave)
March 14, 2018, 4:25am
24
Hi
I worked out how to do the sensors in a card but Im having problems getting the switches to show up in there own card, any ideas? The temps show up fine but the switches do not, nor do they appear grouped in the main view.
Thank you
configuration.yaml
host: 10.0.0.62
mac: 'editedforprivacy'
friendly_name: 'Living Room'
timeout: 200
switches:
living_ac_23:
friendly_name: "Living Room 23"
command_on: 'JgAGAWs0Dw0QCg4nEAsPJxAKDgwQDA4nDygNDBELDQ0OJxAnDQ0PCw8NDgwODA4NDgwPDQ4MDwwPDA8LDwwPKA0MDwwODQ8MDg0NDQ4MECcNDg8KDwwQCw8nDicPKA0nDyYQJw4nDicPDQ4LECYODA8MDwwODQ4MDw0NDQ8LDygNKQ0MDwwOJw8MEAsQCxAlDygNJw8MDg0ODBALDg0QCg8NDg0NDQ4NDgwQDA4MDikOCw4ODQ0ODQ4NDQ0QDA0NDQ0PCxAMDgwODg0ODQwPDQ0MEQwNDA8NDgsRCg8MEAsPDA8LDw0ODA4MEAsQCxALDicPDBALDyYPJhAnDScPDBAmEAsODA8ADQUAAA====='
command_off: 'JgB2AG00DwwPDA4oDgsPJw4MDwwQCw8mECYODg4LDwwOKA4nDwwPCw8MDg0QCw8NDQwPDA4NDwwODQ0NDwsPJw4NDwsQCw8MDgwPDQ4MDyYPDBALDg0QDA0nDg4NDA8NDwsQCw4NDicPCw8nECUQJg4nDycOKA4ADQUAAA====='
living_ac_24:
friendly_name: "Living Room 24"
command_on: 'JgAGAW0zDg4OCw8nEAwOJg4NDwwODg4mDicPDQ4MEAoPKA0nDwwPDA8NDQwPDA4ODwoRCg8MDg0PDQ0MDg0PJg8MDwwPCw8MEAsODQ8MDicODQ4ODQ0ODQ4mECYOKQ4nDScPJw4nDycODA8MDikNDQ4MDg4NDA8NDgwODQ4NDigPJw0MDwwPJg8NDQ4OCw8NDg0ODA4oDwsPDQ0MDwwODg4NDQ4NDA8MEAoPDQ4MDyYQCw8MDg0PDQ0MDwwODg0MDw0ODQ0NDgwPDQ0NDgwPDA8MDg0PDQ4MDQ4NDQ8LDw0NDQ4MDw0ODA8MDgwQCw8MDicPDA8MECYOJw8nDicOJxANDQwODg0ADQUAAA====='
host: 10.0.0.250
friendly_name: 'Bedroom'
timeout: 200
switches:
bedroom_ac_23:
friendly_name: "Bedroom 23"
bedroom_ac_24:
friendly_name: "Bedroom 24"
groups.yaml
AC_view:
view: yes
entities:
- group.temps
- group.aircon
- weather.bom_perth
temps:
entities:
# - weather.bom_perth.temperature
# - weather.bom_perth.humidity
# - sun.sun.next_setting
- sensor.broadlink_sensor_temperature_2
- sensor.temperature_158d0001fa6d07
aircon:
entities:
- switch.living_ac_23
- switch.living_ac_24
- switch.bedroom_ac_23
- switch.bedroom_ac_24
hi wheezy,
I have android tv and setup the on and off my tv with RM MIN3 via home assistant…but i directly want to start youtube and my remote dont have dedicated youtube button…after start my tv i have to push HOME button thane twice down and twice right button than select youtube app and than ok button so how can I send this packets to my tv?
Please help.
Thanks,
Ashish Chauhan.
Wheezy
April 12, 2018, 8:48am
26
Hey, sorry this took so long. I haven’t been checking the forums lately
I use the BRUH Multisensor nodes. This is the pertinent section, but I think you want the whole code package. Here are the groups.
group:
sensor_node_1_card:
entities:
- sensor.sn1_temperature
- sensor.sn1_humidity
- sensor.sn1_ldr
- sensor.sn1_pir
- light.sn1_led
sensor_node_2_card:
entities:
- sensor.sn2_temperature
- sensor.sn2_humidity
- sensor.sn2_ldr
- sensor.sn2_pir
- light.sn2_led
Here is the code package that I invoke inside my configuration.yaml using
homeassistant:
packages:
pack_1: !include custom_components/bruh_multisensors_package.yaml
\HASSIO\config\custom_components\bruh_multisensors_package.yaml
homeassistant:
customize:
#Multisensor component names & icons
sensor.sn1_temperature:
friendly_name: "Temp"
sensor.sn1_humidity:
friendly_name: "Humidity"
sensor.sn1_ldr:
friendly_name: "Luminance"
sensor.sn1_pir:
friendly_name: "Motion"
light.sn1_led:
friendly_name: "LED"
sensor.sn2_temperature:
sensor.sn2_humidity:
sensor.sn2_ldr:
sensor.sn2_pir:
light.sn2_led:
light:
#BRUH Multisensor Node LED's
- platform: mqtt_json
state_topic: "bruh/sensornode1"
command_topic: "bruh/sensornode1/set"
brightness: true
flash: true
rgb: true
optimistic: false
qos: 0
state_topic: "bruh/sensornode2"
command_topic: "bruh/sensornode2/set"
brightness: true
flash: true
rgb: true
optimistic: false
qos: 0
#BRUH Multisensor Node sensors (values from MQTT)
# Note: These sensors have not been calibrated. Calibration values could be perturbed here at a later date. These LUX sensors have +/-20units difference between eachother under identical conditions.
- platform: mqtt
name: "SN1 Humidity"
unit_of_measurement: "%"
value_template: '{{ value_json.humidity | round(1) }}'
- platform: mqtt
##This sensor is not calibrated to actual LUX. Rather, this a map of the input voltage ranging from 0 - 1023.
unit_of_measurement: "units"
value_template: '{{ value_json.ldr }}'
- platform: mqtt
value_template: '{{ value_json.motion }}'
- platform: mqtt
name: "SN1 Temperature"
unit_of_measurement: "F"
value_template: '{{ value_json.temperature | round(1) }}'
- platform: mqtt
name: "SN2 Humidity"
- platform: mqtt
- platform: mqtt
- platform: mqtt
name: "SN2 Temperature"
# binary_sensor (This is absolutely required for "template_last_motion" to work for some reason)
# https://home-assistant.io/docs/z-wave/entities/#binary-sensor
binary_sensor:
sensors:
sn1_pir:
value_template: >-
{%- if is_state('sensor.sn1_pir', "motion detected") -%}
true
{%- else -%}
false
{%- endif -%}
sn2_pir:
value_template: >-
{%- if is_state('sensor.sn2_pir', "motion detected") -%}
true
{%- else -%}
false
{%- endif -%}
group:
sensor_node_1_card:
entities:
- sensor.sn1_ldr
- sensor.sn1_pir
- light.sn1_led
sensor_node_2_card:
entities:
- sensor.sn2_ldr
- sensor.sn2_pir
- light.sn2_led
Wheezy
April 12, 2018, 8:51am
27
You might be able to do this using a the Broadlink RM component’s broadlink_send_packet command. You could set up a series of broadlink_send_packet commands inside a script .
Wheezy
April 12, 2018, 8:54am
28
Yes, I agree with the other two posters. I frequently refer to my own IR blasters as “dumb fire” tech: My IR-controlled space heaters sometimes get put into an incorrect state because one didn’t sense the IR command from the Broadlink blaster. This results in HomeAssistant dutifully marking the heaters as “off” after it fired the “off” command, but one heater staying on anyway on accident. From then on, my states are opposite in HomeAssistant from what they should be in real life. It doesn’t happen a lot, but it’s annoying.
My MQTT/wifi/smart switches (not IR) are smarter than that though since they report back to HomeAssistant to tell HomeAssistant their current state at any given moment. So HomeAssistant doesn’t get confused with those “smarter” devices.
