Broadlink Warning
Getting the following warning in logs:
Logger: homeassistant.components.switch
Source: components/switch/__init__.py:125
Integration: Switch (documentation, issues)
First occurred: 6:06:52 PM (4 occurrences)
Last logged: 6:06:52 PM
SwitchDevice is deprecated, modify BroadlinkRMSwitch to extend SwitchEntity
SwitchDevice is deprecated, modify BroadlinkSP1Switch to extend SwitchEntity
SwitchDevice is deprecated, modify BroadlinkSP2Switch to extend SwitchEntity
SwitchDevice is deprecated, modify BroadlinkMP1Slot to extend SwitchEntity
Home Assistant has started!
Wasn’t mentioned in the patch notes, take a look here: 0.110: Speed! OpenZWave beta, HomeKit Cameras, ONVIF, Calendars
It’s an issue the developers will have to take care of, no need to worry :slight_smile:
