Ok, so the normal warning, then it has to wait a bit
As we are talking about this great integration, I am missing some other information, my printer is a LED printer, so it has four drums, not one
It would be great to have them in as well
You posted a screenshot from maintenance page, so now I need raw data from your printer ![]()
Ok, so here goes (had to create a debian 10 machine to get a test server
`{'1.3.6.1.4.1.2435.2.3.9.4.2.1.5.5.10.0': ['0001040000134b', '02010400000c69', '010104000006e2', '16010400003483', '13010400000a91', '14010400000aa4', '15010400000c33', '1201040000131b'], '1.3.6.1.4.1.2435.2.3.9.4.2.1.5.5.17.0': 'ZA1811191217', '1.3.6.1.4.1.2435.2.3.9.4.2.1.5.5.8.0': ['76010400000001', '77010400000001', '78010400000001', '7f010400000001', '68010400000001', '55010400000001', '31010400000001', '32010400000001', '33010400000001', '34010400000001', '700104000017d4', '82010400000046', '7101040000170c', '8301040000003c', '720104000007d0', '84010400000014', '6f01040000238c', '81010400000064', '79010400001a90', '7a010400001a90', '7b010400001a90', '80010400001a90', '6901040000206c', '7301040000134b', '7401040000134b', '7501040000134b', '7e01040000134b', '54010400000001', '35010400000001', '6a01040000238c', '6d0104000023f0'], '1.3.6.1.4.1.2435.2.4.3.2435.5.13.3.0': 'Fribert Stuen', '1.3.6.1.4.1.2435.2.3.9.4.2.1.5.5.11.0': ['a401040000274d', 'a501040000274d', 'a601040000274d', 'a701040000274d', '8801040000a0c8', '7301040000b005', '7701040000b2b6'], '1.3.6.1.2.1.43.10.2.1.4.1.1': '4939', '1.3.6.1.4.1.2435.2.3.9.4.2.1.5.5.1.0': 'E71833C4J372261', '1.3.6.1.4.1.2435.2.3.9.4.2.1.5.4.5.2.0': 'Dvale ', '1.3.6.1.2.1.1.3.0': '7251895'}`
I also got this:
Sensors data: {'status': 'dvale', 'page_counter': 4939, 'uptime': 1, 'color_counter': 3177, 'b/w_counter': 1762, 'image_counter': 13443, 'cyan_counter': 2705, 'magenta_counter': 2724, 'yellow_counter': 3123, 'black_counter': 4891, 'black_toner_status': 1, 'cyan_toner_status': 1, 'magenta_toner_status': 1, 'yellow_toner_status': 1, 'cyan_toner_remaining': 61, 'cyan_toner': 70, 'magenta_toner_remaining': 59, 'magenta_toner': 60, 'yellow_toner_remaining': 20, 'yellow_toner': 20, 'black_toner_remaining': 91, 'black_toner': 100, 'belt_unit_remaining_life': 83, 'fuser_remaining_life': 91, 'pf_kit_1_remaining_life': 92, 'belt_unit_remaining_pages': 41160, 'laser_unit_remaining_pages': 45061, 'pf_kit_1_remaining_pages': 45750}
I hope this helps in some way.
I made new version of the package with support for colorful drums. Could you repeat this commands:
pip install --upgrade git+https://github.com/bieniu/brother@dev
curl https://raw.githubusercontent.com/bieniu/brother/dev/example.py -o example.py
python3 example.py <PRINTER_IP>
and show me Sensors data?
Ok, np:
Sensors data: {'status': 'dvale', 'page_counter': 4939, 'uptime': 0, 'color_counter': 3177, 'b/w_counter': 1762, 'image_counter': 13443, 'cyan_counter': 2705, 'magenta_counter': 2724, 'yellow_counter': 3123, 'black_counter': 4891, 'black_toner_status': 1, 'cyan_toner_status': 1, 'magenta_toner_status': 1, 'yellow_toner_status': 1, 'cyan_toner_remaining': 61, 'cyan_toner': 70, 'magenta_toner_remaining': 59, 'magenta_toner': 60, 'yellow_toner_remaining': 20, 'yellow_toner': 20, 'black_toner_remaining': 91, 'black_toner': 100, 'cyan_remaining_life': 68, 'magenta_remaining_life': 68, 'yellow_remaining_life': 68, 'black_remaining_life': 68, 'belt_unit_remaining_life': 83, 'cyan_drum_counter': 4939, 'magenta_drum_counter': 4939, 'yellow_drum_counter': 4939, 'black_drum_counter': 4939, 'fuser_remaining_life': 91, 'pf_kit_1_remaining_life': 92, 'belt_unit_remaining_pages': 41157, 'laser_unit_remaining_pages': 45061, 'pf_kit_1_remaining_pages': 45750}
Thanks. What does ‘Fribert Stuen’ mean? This OID should contain printer model name.
That is the printers ‘name’ in Google Cloud printing and other printer services.
OK, I understand. Could you run this command and show me the result?
snmpget -v1 -c public <PRINTER_IP> 1.3.6.1.4.1.2435.2.4.3.99.3.1.6.1.2.1 1.3.6.1.4.1.2435.2.4.3.2435.5.13.3.0 1.3.6.1.4.1.2435.2.4.4.1240.5.16.1.1.1.2 1.3.6.1.4.1.2435.2.4.4.1240.5.16.1.1.1.3
You need snmp package for it. To install it you have to use this command (on Debian):
sudo apt install snmp
Ok, this is the result:
root@testserver:~# snmpget -v1 -c public 10.11.12.7 1.3.6.1.4.1.2435.2.4.3.99.3.1.6.1.2.1 1.3.6.1.4.1.2435.2.4.3.2435.5.13.3.0 1.3.6.1.4.1.2435.2.4.4.1240.5.16.1.1.1.2 1.3.6.1.4.1.2435.2.4.4.1240.5.16.1.1.1.3
Created directory: /var/lib/snmp/mib_indexes
iso.3.6.1.4.1.2435.2.4.3.99.3.1.6.1.2.1 = STRING: "MODEL=\"DCP-9020CDW\""
iso.3.6.1.4.1.2435.2.4.3.2435.5.13.3.0 = STRING: "Fribert Stuen"
iso.3.6.1.4.1.2435.2.4.4.1240.5.16.1.1.1.2 = STRING: "Brother DCP-9020CDW [30055c3dd1c6]"
iso.3.6.1.4.1.2435.2.4.4.1240.5.16.1.1.1.3 = STRING: "Brother DCP-9020CDW [30055c3dd1c6]"
Great, thanks.
Could you try again and show me the result?
This is the result:
Data available: True
Model: DCP-9020CDW
Firmware: ZA1811191217
Status: dvale
Serial no: E71833C4J372261
Sensors data: {'status': 'dvale', 'page_counter': 4942, 'uptime': 3, 'color_counter': 3179, 'b/w_counter': 1763, 'image_counter': 13452, 'cyan_counter': 2707, 'magenta_counter': 2726, 'yellow_counter': 3125, 'black_counter': 4894, 'black_toner_status': 1, 'cyan_toner_status': 1, 'magenta_toner_status': 1, 'yellow_toner_status': 1, 'cyan_toner_remaining': 61, 'cyan_toner': 70, 'magenta_toner_remaining': 59, 'magenta_toner': 60, 'yellow_toner_remaining': 20, 'yellow_toner': 20, 'black_toner_remaining': 91, 'black_toner': 100, 'cyan_drum_remaining_life': 68, 'magenta_drum_remaining_life': 68, 'yellow_drum_remaining_life': 68, 'black_drum_remaining_life': 68, 'belt_unit_remaining_life': 83, 'cyan_drum_counter': 4942, 'magenta_drum_counter': 4942, 'yellow_drum_counter': 4942, 'black_drum_counter': 4942, 'fuser_remaining_life': 91, 'pf_kit_1_remaining_life': 92, 'black_drum_remaining_pages': 10058, 'cyan_drum_remaining_pages': 10058, 'magenta_drum_remaining_pages': 10058, 'yellow_drum_remaining_pages': 10058, 'belt_unit_remaining_pages': 41152, 'laser_unit_remaining_pages': 45058, 'pf_kit_1_remaining_pages': 45747}
That looks very promising…
Thanks. I think the library is ready.
The PR that adds new sensors is ready and waiting for review.
Is there a way to change the SNMP string this integration uses? I assume it defaults to “public” but I dont use defaults and its not working with an SNMP error
It’s not supported.
I have the same problem. Do you solve it?
I haven’t really noticed it since. I’m also not really paying attention to it for any reason
It’s using SNMP, so it’s in the network or the printer. Have you set some extra power saving settings of some sort?
