Should be there under integrations.
Let me know. I really need some time to get the integration more robust.
Which board do you have? Arduino mega or the due? It should still work with 1.0 firmware.
Itās empty:
Iām using Arduino due with the last version of bsb-lan.
If i can give you more logs or more info, tell me
Donāt use the latest version. They are changing a lot. Use the latest release. 1.0 release is safe.
Next release of the integration will hopefully have a firmware check to see if the firmware is safe.
I think i use the v1 version:
I ve downloaded from master.
Ok thanks, iām on 1.1 patch 14, i will go with 1.0!
I switch back to 1.0 and integration is still empty, but, i have some logs now!
Error fetching data: http://192.168.0.39/JQ=1610 failed with HTTPConnectionPool(host='192.168.0.39', port=80): Max retries exceeded with url: /JQ=1610 (Caused by ConnectTimeoutError(<urllib3.connection.HTTPConnection object at 0x7f20ee7e96d0>, 'Connection to 192.168.0.39 timed out. (connect timeout=10)'))
Error fetching data: http://192.168.0.39/JQ=8323 failed with HTTPConnectionPool(host='192.168.0.39', port=80): Max retries exceeded with url: /JQ=8323 (Caused by ConnectTimeoutError(<urllib3.connection.HTTPConnection object at 0x7f20ee7e9a60>, 'Connection to 192.168.0.39 timed out. (connect timeout=10)'))
Error fetching data: http://192.168.0.39/JQ=1612 failed with HTTPConnectionPool(host='192.168.0.39', port=80): Max retries exceeded with url: /JQ=1612 (Caused by ConnectTimeoutError(<urllib3.connection.HTTPConnection object at 0x7f20ee7f1400>, 'Connection to 192.168.0.39 timed out. (connect timeout=10)'))
Url are working so i donāt know why it fails. Maybe i need a bigger timeout?
If you are working on a new version (compatible with the 1.1?) i wonāt bother you so much, letās wait the update
Which heating circuit are you using? What are the parameters you read out when you are in the webserver of the bsblan board?
Iām using circuit 1 but itās off for the moment. (state is Schutzbetrieb, parameter 700)
Iām not sure to understand
Hi, I am VERY new to Home Assistant. I configured LAN-Bsb on fhem which works nice since years.
How can I configure HA to read more parameters? I added something likeā¦
- platform: bsblan
payload:
- '8700'
- '8830'
- '8740'
- '8006'
- '8003'
- '1600'
into configuration.yaml without success. I would like to log hot water temp, outside tempā¦
ModuleNotFoundError: No module named 'homeassistant.components.bsblan.sensor'
Could I get a hint on that?
Thanks!
got it!
- platform: bsb_lan
the ā_ā was missing!
Hi there!
Itās working now for me, i can see my climate entity, and with the last bsb-lan version!
Problem was that i wasnāt sending temperature to the 8740
parameter. Now itās ok.
I have a new question, i ve got 2 heating system, one for the bedrooms and one for the living room.
Is it possible to have second climate entity ? (i see only one)
Great it works! I just started again working on the python lib for bsblan.
I am working on a overhaul. Some code in python lib is already written for second heating system.
I think the next release wonāt include this support yet. For now is the feature that I scan for parameters that are available so the climate device can have more entities (max-temp, min-temp, etc) if available.
But this paves also the way for more other devices and binary sensors. So hopefully this hackotober will bring some fruits.
You are using the old bsblan component that is no longer maintained. I donāt know how the compatibility is with home-assistant. If you want to have a climate device you could add this using integrations.
Ok, I used the button for BSB-Lan integration. But how to configure the module to log more parameters?
Thatās what I am working on, but if the old component works you could use that to read out extra entities/sensors.
The new one adds climate device to home assistant. So you can easily set room temp with Lovelace thermostat panel
Understand. So currently IĀ“m using the Lovelace panel and the old style to display sensors and values.
Two feature requests/ideas:
To design Lovelace ui for the other sensors is yet not in my current scope. If you want to do it:)
My plan is support all devices there are in Home-Assistant. So Climate, Water Heater Switch and Binary Sensors, Sensors.
There is no option yet to put the backend of the heating system in a device/platform. Would be cool though. So all the other sensors will be seperate entities. I am not sure if itās possible to create your own platform?
Hi there,
since i have updated to 0.117, rest sensor is not working anymore.
Is it the same for you guys?
Hi tiger42
can you share homeassitant configuration Rest sensor ?
I try to configure the sensor rest to extract value but not work.
Thank you in advance
Marco
