Sorry for the late reply.
You should share how you wrote things into your configuration.yaml.
I cannot really advise without seeing the code which produced the error.
Hi Gabor, many thanks for your help - it finally worked ! Iâll have to learn programming automations but this is definetly an important step
This working for me.
mqtt:
button:
- name: DHW push
unique_id: bsb_lan_dhw_push
availability_topic: "BSB-LAN/status"
command_topic: "BSB-LAN"
payload_press: "S10019=1"
qos: 0
retain: false
And my complette mqtt_sensors.yaml for BSB sensors is:
- state_topic: "BSB-LAN/8700"
name: BSB-LAN Outside temperature
unique_id: bsb_lan_outside_temperature
unit_of_measurement: °C
device_class: temperature
- state_topic: "BSB-LAN/8740"
name: BSB-LAN Room temperature
unique_id: bsb_lan_room_temperature
- state_topic: "BSB-LAN/8310"
name: BSB-LAN Boiler temperature
unique_id: bsb_lan_boiler_temperature
- state_topic: "BSB-LAN/8326"
name: BSB-LAN Boiler modulation
unique_id: bsb_lan_boiler_modulation
unit_of_measurement: "%"
device_class: power_factor
- state_topic: "BSB-LAN/8314"
name: BSB-LAN Return temperature
unique_id: bsb_lan_return_temperature
- state_topic: "BSB-LAN/8830"
name: BSB-LAN DHW temperature
unique_id: bsb_lan_dhw_temperature
select:
- name: Boiler operating mode
unique_id: bsb_lan_operating_mode
state_topic: "BSB-LAN/700"
# Example value: 1 - Automatic
value_template: >
{% set mapping = {0: 'Protection', 1: 'Automatic', 2: 'Reduced', 3: 'Comfort'} %}
{% set idx = value.split() | first | int %}
{{ mapping[idx] }}
# Example payload: S700=1
command_template: >
{% set mapping = {'Protection': 0, 'Automatic': 1, 'Reduced': 2, 'Comfort': 3} %}
S700={{ mapping[value] }}
options:
- Protection
- Automatic
- Reduced
- Comfort
icon: mdi:list-box
button:
- name: DHW push
qos: 0
retain: false
number:
- name: BSB-LAN Comfort temperature
unique_id: bsb_lan_radiator_comfort_setpoint
state_topic: "BSB-LAN/710"
command_template: >
S710={{ value }}
mode: box
min: 12
max: 26
step: 0.1
icon: mdi:radiator
- name: BSB-LAN Reduced temperature
unique_id: bsb_lan_radiator_reduced_setpoint
state_topic: "BSB-LAN/712"
command_template: >
S712={{ value }}
mode: box
min: 12
max: 26
step: 0.1
icon: mdi:radiator-disabled
Iâm missing âmqqt:â at the beginning on purpose, because Iâm calling yaml from configuration.yaml like this:
mqtt: !include mqtt_sensors.yaml
Hi jirka, please could you share how to use the âselectâ code in the interface? with a button or what? many thanks
select:
value_template: >
{{ mapping[idx] }}
command_template: >
options:
- Protection
- Automatic
- Reduced
- Comfort
icon: mdi:list-box
Perfect, the Drinking Water Push is working that way.
My next aim is getting the Presence button âTemporary Comfortâ
10110 Benutzerdefiniert - Heizbetrieb Heizkreis 1 (TemporÀr)
with Options
number:
command_template: >
S710={{ value }}
mode: box
min: 12
max: 26
step: 0.1
icon: mdi:radiator
Do you or anybody has an example as well?
Regards,
Joerg
Hello
I wanted to ask if it is possible to make the same adjustment for the second circuit as for the first circuit.
Thank you
Regards
Mariusz
Is this set up through the official integration or through MQTT?
If MQTT, then you need to use 1010
, instead of the 710
like as it is visible in the previous postâs example.
If the official integration, then @liudger might be able to give you an answer.
Now I have it done via MQTT but I would like to do it on official integration
Hi Mariusz,
It just that currently I donât have much time. And I want to check if another project that will control BSBLan device with mqtt could be better. They are working to make bsblan work out of the box with mqttt and the sensors and climate/ hot water will be automatically detected. Than there is no need for this integration. But that project also goes really slow
This is the configuration.yaml I use to integrate home assistant with my recently acquired BSB-LAN over MQTT. While I am sure there are possible improvement, I am quite happy with its current state. I post it here hoping it might help someone. Some related notes to take into account:
mqtt:
number:
- name: "Average house temperature"
unique_id: "bsb_lan_average_house_temperature"
device:
connections: [["mac", "AA:BB:CC:DD:EE:FF"]]
manufacturer: "Fujitsu"
model: "Water stage"
sw_version: "3.2.2-20230606224119"
configuration_url: "http://192.168.1.99/"
unit_of_measurement: "°C"
command_template: "{{'I10000='+ (value| string)}}"
retain: true
- name: "Heating electricity usage"
unique_id: "bsb_lan_heat_pump_electricity_usage"
device:
state_topic: "BSB-LAN/3113"
unit_of_measurement: "kWh"
device_class: energy
state_class: total_increasing
force_update: true
value_template: '{{ ((value.split(" ")[0]) | int) }}'
- name: "Heating circuit 1 status"
unique_id: "bsb_lan_heat_pump_hc1_status"
device:
state_topic: "BSB-LAN/8000"
value_template: '{{ ((value.split("-")[1])) }}'
- name: "Hot water status"
unique_id: "bsb_lan_dhw_status"
device:
state_topic: "BSB-LAN/8003"
- name: "Heat pump status"
unique_id: "bsb_lan_heat_pump_status"
device:
state_topic: "BSB-LAN/8006"
climate:
- name: Heating
unique_id: "bsb_lan_heat_pump"
device:
payload_on: 1
payload_off: 0
modes:
- auto
- heat
- cool
- 'off'
mode_state_topic: "BSB-LAN/700"
mode_state_template: >-
{% set values = { '0 - Protection':'off', '1 - Automatic':'auto', '2 - Reduced':'cool', '3 - Comfort':'heat'} %}
{{ values[value] if value in values.keys() else 'off' }}
mode_command_topic: "BSB-LAN"
mode_command_template: >-
{% set values = { 'off':'S700=0', 'auto':'S700=1', 'cool':'S700=2', 'heat':'S700=3'} %}
{{ values[value] if value in values.keys() else '0' }}
current_temperature_topic: "BSB-LAN/8740"
min_temp: 17
max_temp: 28
temp_step: 0.5
temperature_high_command_topic: "BSB-LAN"
temperature_high_command_template: "{{'S710='+ (value | string)}}"
temperature_high_state_topic: "BSB-LAN/710"
temperature_low_command_topic: "BSB-LAN"
temperature_low_command_template: "{{'S712='+ (value | string)}}"
temperature_low_state_topic: "BSB-LAN/712"
water_heater:
- name: Hot water
unique_id: "bsb_lan_dhw"
device:
modes:
- "off"
- "heat_pump"
payload_on: 1
payload_off: 0
min_temp: 30
power_command_topic: "BSB-LAN"
power_command_template: "{{'S1600=' + (value | string)}}"
{% set values = { 'off':'S1600=0', 'heat_pump':'S1600=1'} %}
mode_state_topic: "BSB-LAN/1600"
{% set values = { '0 - Off':'off', '1 - On':'heat_pump'} %}
temperature_state_topic: "BSB-LAN/1610"
temperature_command_topic: "BSB-LAN"
temperature_command_template: "{{'S1610='+ (value| string)}}"
current_temperature_topic: "BSB-LAN/8830"
temperature_unit: "C"
precision: 1.0
button:
- name: DHW push
device:
qos: 0
retain: false
Credit for https://github.com/ryann72/Home-assistant-tutoriel/blob/5ccbfd46149d42e745a7f9bcc8b8f4bdc67cbf6c/BSB-LAN/tutoriel%20BSB-LAN%20English.md that I used to get started.
Have you had any success integrating immergas boiler to HA? I got Immergas EOLO MÄ°NÄ° I want to be remote controlled, couldnât even find protocol its communicating with itâs OEM remote.
I have since modified the climate entity to remove the âcoolâ mode as it doesnât make sense if there is no cooling circuit. Instead presets are used to indicate the heating mode.
climate:
- name: Heating
device:
payload_on: 1
payload_off: 0
modes:
- heat
- 'off'
preset_modes:
- protection
- comfort
- away
{% set values = { '0 - Protection':'off', '2 - Reduced': 'heat', '3 - Comfort': 'heat'} %}
{{ values[value] if value in values.keys() else 'heat' }}
{% set values = { 'off':'S700=0', 'heat':'S700=3'} %}
{{ values[value] if value in values.keys() else 'S700=3' }}
preset_mode_state_topic: "BSB-LAN/700"
preset_mode_command_topic: "BSB-LAN"
preset_mode_value_template: >-
{% set values = { '3 - Comfort':'comfort', '2 - Reduced':'away', '0 - Protection':'protection'} %}
{{ values[value] if value in values.keys() else 'comfort' }}
preset_mode_command_template: >-
{% set values = { 'comfort':'S700=3', 'away':'S700=2', 'protection':'S700=0' } %}
current_temperature_topic: "BSB-LAN/10049"
min_temp: 17
max_temp: 28
temp_step: 0.5
qos: 2
The only remaining issues I have are due to home assistantâs thermostat card colors: orange is used for the lower temperature target, and blue for the higher temperature target.
Hello all;
Happy to see this post since I just installed an ESP32/BSB-LAN box sending my boiler (Chappee Klista HTE, LMS14 regulator) parameters to MQTT broker and from then being integrated into HA.
My heating system has 2 zones:
zone 1: 1st floor with traditional radiators. Direct circuit.
zone 2: groundfloor with under-floor heating an a 3-way valve. An official and mandatory Chappee probe is associated with this second zone.
I would like to mimic a second (optional) Chappee probe for a better regulation of the 1st zone using my Home Assistant temperature sensor.
Is this feasible ? When I dig into the BSB-LAN webserver parameters the only âsetableâ parameter associated with zone 1 is the Room temp1 model (variable #8742):
BSB-LAN output (in French, sorryâŠ):
In the LMS14 documentation I find the following definitions:
When there is no room sensor I understand that the room temperature is derived from a âroom modelâ but I do not understand how that works and how sending a value to set 8742 could mimick my Chappee sensorâŠ
Here is the relevant part of the doc about room model:
Any help will be appreciated !
Cheers,
Jacques
At my room sensor unit I was able to configure which zone will be controlled. Here itâs possible to activate the sensor for both zones.
There is a very simple way to mimic the sensor of your boiler using any temperature sensor you have in your home (Thank you Frederik, sponsor of the great BSB-LAN project !) . Here is the automation I created to make my boiler think that my 10$ Sonoff sensor coud do as well as the official 200$ Chappee sensor
- alias: "Publish Sensor Value to MQTT as BSB-LAN topic"
platform: time_pattern
minutes: "/5" # Trigger every 5 minutes
- service: mqtt.publish
topic: "BSB-LAN"
payload: "I10000={{ states('sensor.your_sensor_entity_id') }}"
Replace sensor.your_sensor_entity_id
by the sensor entity of your choice.
The same trick can be used to feed a temperature for zone 2 (I10001=
) or zone 3 (I10002=
) or to feed an external temperature (I10003=
) or to simulate a presence. Check 6.3 and following sections of the excellent BSB-LAN documentation !
Jacques
NB: those parameters are valid for LMS14 Siemens based regulators. They may differ for other regulators. Check the doc !
And does the heater take those values into account? Is that your experience? Isnât a setting should be changed to use the room sensor than the room model?
It does the job perfectly and this approach is well documented in the BSB-LAN manual (section 6.3 s.q.q.). Much simpler that trying to play around with the Room model And I received very helpful suggestions from Frederik (BSB-LAN lead developer) on this alternative approach.
Thanks for the pointer. To be honest, I completely missed this, which is exactly why I was asking the original question. That is the setting which has to be changed to activate the âroom influenceâ.
Therefore you have to activate the function âroom influenceâ (e.g. parameter 750 for circuit 1, parameter 1050 for circuit 2) before.
