@hazio Thank you!
Hi, I now had the time to test the new version of Bubble-card. In the header of two pop-ups I do have sub-button-icons which change under certain conditions. this used to work without a problem. Now with the new version, these pop-ups do not work anymore (they don‘t pop up) as long as I leave the following code in the styling section:
${subButtonIcon[0].setAttribute("icon", hass.states['cover.sonnenrollo'].state === 'open' ? 'mdi:window-shutter-open' : 'mdi:window-shutter')}
When I remove the code everything works again…
Is this a bug for the header of the popups… or do I have to change something else in the code?
Thanks for helping!
Looks really nice! Great job!
Would you mind sharing your yaml?
Will Need help for my Dashboard project.
I am using a floorplan Dashboard using picture elements and condicional for light efects in every division of the house.
In order to not have so many icons on the dash wanted to add an horizontal stack buttons with pop-up style.
The problem is when trying to add the buble pop up Card inside picture elements i cannot get the pop up to work.
Any idea How to add pop up style inside picture elements?
I have tried to using hui-elements, but the image stays blurred during the pop-up.
Hello, THANK YOU for this card collection!
I have been using it quite extensively to craft a mobile dashboard for me. I do have one issue I would like to ask (to see if someone spots any errors I made, or is there a minor bug somewhere).
I have a popup showing all my blind devices. I am using a combination of bubble and mushroom in order to get the behaviour I need. (my blinds are switchbot blind tilts so I need to use the tilt_position to control the blinds, I could not for the life of me get this working with bubble slider). The end result is otherwise perfect for what I need, but my template for sub-button background color is not working for some reason. If the blinds are closed, it works as expected (other button in different color) but when the blinds are open, the template no longer works and both buttons have the same background color. See picture attached.
EDIT: and to clarify, I tested the bubble-card button without layout card, still the same. And developer tools shows ‘open’ or ‘closed’ for the blinds state.
The YAML:
type: vertical-stack
cards:
- type: custom:bubble-card
card_type: pop-up
hash: '#verhot'
button_type: name
icon: mdi:blinds-horizontal
sub_button:
- name: Avaa
show_name: true
entity: script.open_all_blinds
tap_action:
action: call-service
service: script.turn_on
entity_id: script.open_all_blinds
- name: Sulje
show_name: true
icon: mdi:blinds-horizontal-closed
entity: script.close_all_blinds_script
tap_action:
entity_id: script.close_all_blinds_script
styles: |-
.bubble-sub-button-1 {
opacity: 1 !important;
background-color: ${hass.states['cover.olohuoneen_verhot'].state === 'closed' ? 'var(--accent-color)' : 'none'} !important;
.bubble-sub-button-2 {
background-color: ${hass.states['cover.olohuoneen_verhot'].state === 'open' ? 'var(--accent-color)' : 'none'} !important;
- type: custom:layout-card
layout_type: custom:grid-layout
layout:
grid-template-columns: 2fr 1fr
grid-template-rows: auto
grid-template-areas: |
"left right"
cards:
card_type: button
button_type: state
entity: cover.blind_tilt_bedroom
double_tap_action:
action: none
hold_action:
action: none
show_state: true
show_attribute: true
attribute: current_tilt_position
card_layout: large
show_name: true
show_icon: false
sub_button:
- entity: cover.blind_tilt_bedroom
show_name: true
tap_action:
entity_id: script.open_bedroom_blinds
show_state: false
show_name: true
tap_action:
entity_id: script.close_bedroom_blinds_script
styles: |-
background-color: ${hass.states['cover.blind_tilt_bedroom'].state === 'closed' ? 'var(--accent-color)' : 'none'} !important;
background-color: ${hass.states['cover.blind_tilt_bedroom'].state === 'open' ? 'var(--accent-color)' : 'none'} !important;
- type: custom:mushroom-cover-card
icon: phu:blind-tilt-open
show_tilt_position_control: true
show_position_control: false
show_buttons_control: false
layout: horizontal
icon_type: none
primary_info: none
secondary_info: none
card_mod:
style:
mushroom-cover-tilt-position-control$:
mushroom-slider$: |
.slider {
--main-color: var(--accent-color) !important;
--bg-color: var(--accent-color-2) !important;
--gradient: none;
mushroom-cover-tilt-position-control {
--control-height: 48px !important;
--control-border-radius: var(--ha-card-border-radius, 24px);
ha-card {
border-radius: 34px!important;
height: 64px!important;
padding: 8px !important;
layout:
"left right"
cards:
card_type: button
button_type: state
entity: cover.blind_tilt_kids_room
double_tap_action:
action: none
hold_action:
action: none
show_state: true
card_layout: large
show_name: true
show_icon: false
sub_button:
- entity: cover.blind_tilt_kids_room
show_name: true
tap_action:
entity_id: script.open_kidsroom_blinds
show_state: false
show_name: true
tap_action:
entity_id: script.close_kidsroom_blinds_script
styles: |-
background-color: ${hass.states['cover.blind_tilt_kids_room'].state === 'closed' ? 'var(--accent-color)' : 'none'} !important;
background-color: ${hass.states['cover.blind_tilt_kids_room'].state === 'open' ? 'var(--accent-color)' : 'none'} !important;
layout: horizontal
icon_type: none
primary_info: none
card_mod:
style:
mushroom-slider$: |
.slider {
--gradient: none;
ha-card {
layout:
"left right"
cards:
card_type: button
button_type: state
entity: cover.olohuoneen_verhot
double_tap_action:
action: none
hold_action:
action: none
show_state: true
card_layout: large
show_name: true
show_icon: false
sub_button:
- entity: cover.olohuoneen_verhot
show_name: true
tap_action:
service: cover.set_cover_tilt_position
entity_id: cover.olohuoneen_verhot
tilt_position: 40
show_state: false
show_name: true
tap_action:
tilt_position: 100
styles: |-
layout: horizontal
icon_type: none
primary_info: none
card_mod:
style:
mushroom-slider$: |
.slider {
--gradient: none;
ha-card {
Hello, i hope someone can help me. How can I make the border of a bubble card (Button/state) 1px large with a color. I have a standard theme, but the bubble card does not draw a blue border around it. See picture
Try adding this to the styling options - custom styles part:
.bubble-button-card-container {
border: 1px solid;
border-color: blue;
Your dashboard looks great. Especially your vacuum/room select button…could share your code?
I think that would be the Sankey Chart.
This is the code for the mushroom button on the main page that opens up to the vacuum popup
type: custom:mushroom-template-card
primary: Blinds
secondary: ''
icon: mdi:blinds
icon_color: teal
layout: vertical
tap_action:
action: navigate
navigation_path: '#blinds'
hold_action:
action: none
double_tap_action:
action: none
fill_container: false
card_mod:
style: |
ha-card {
background: var(--background-color-2);
border-radius: 35px;
This is a vertical stack, using the bubble popup. This opens when you press the vacuum button on the main page.
cards:
card_type: pop-up
hash: '#vacuum'
show_header: true
button_type: state
entity: vacuum.alice
show_last_changed: true
tap_action:
action: none
double_tap_action:
action: none
hold_action:
action: none
button_action:
tap_action:
action: none
double_tap_action:
action: none
hold_action:
action: none
card_type: select
entity: input_select.room_select
show_state: true
sub_button:
- entity: input_button.go
show_name: true
tap_action:
entity_id: script.vacuum_room_select
- type: custom:vacuum-card
stats:
default:
- entity_id: sensor.alice_filter_lifespan
unit: '%'
subtitle: Filter
- entity_id: sensor.alice_main_brush_lifespan
unit: '%'
subtitle: Main Brush
- entity_id: sensor.alice_side_brushes_lifespan
unit: '%'
subtitle: Side Brush
cleaning:
- entity_id: sensor.alice_cleaning_duration
unit: minutes
subtitle: Cleaning Time
- entity_id: sensor.alice_total_area_cleaned
unit: m²
subtitle: Area Cleaned
Yaml for the main layout card on the main page
layout_type: masonry
cards:
- type: custom:decluttering-card
template: header_main
- show_current: false
show_forecast: true
type: weather-forecast
entity: weather.openweathermap
forecast_type: daily
card_mod:
style: |
ha-card {
border-radius: 50px;
card_type: button
button_type: state
entity: person.hannah_holden
show_attribute: false
attribute: device_trackers
show_last_changed: false
show_name: true
card_layout: large
sub_button:
- entity: sensor.hannah_holdens_iphone_geocoded_location
show_icon: false
show_state: true
show_background: false
- entity: sensor.hannah_holdens_iphone_battery_level
show_state: true
- entity: sensor.hannah_holdens_iphone_activity
styles: |-
.bubble-button-background {
background-color: ${state === 'home' ? 'var(--accent-color)':''} !important;
font-size: 10px;
line-height: 1.5;
text-align: center;
card_type: button
button_type: state
entity: person.christopher_hemmings
show_name: true
card_layout: large
sub_button:
- entity: sensor.iphone_13_pro_max_geocoded_location
show_icon: false
show_state: true
- entity: sensor.iphone_13_pro_max_battery_level
show_state: true
- entity: sensor.iphone_13_pro_max_activity
styles: |-
font-size: 10px;
font-size: 10px;
line-height: 1.5;
text-align: center;
show_state: true
card_type: button
button_type: state
entity: alarm_control_panel.alarmo
show_state: true
card_layout: large-2-rows
sub_button:
- name: Home temperature
icon: mdi:home-thermometer-outline
entity: sensor.indoor_temperature
show_state: true
show_icon: true
- name: Outside temperature
entity: sensor.outdoor_station_temperature
show_state: true
- name: Doors
entity: sensor.doors_open
show_name: true
show_state: true
tap_action:
action: navigate
navigation_path: '#security'
attribute: temperature
icon: mdi:door-open
- name: Windows
entity: sensor.windows_open
show_name: true
show_state: true
show_background: true
icon: mdi:window-open
show_icon: true
tap_action:
action: navigate
styles: >
.bubble-icon {
color: ${hass.states['alarm_control_panel.alarmo'].state === 'armed_home' ? 'red' : (hass.states['alarm_control_panel.alarmo'].state === 'arming' ? 'orange' : 'grey')} !important;
animation: ${hass.states['alarm_control_panel.alarmo'].state === 'arming' ? 'fade-in-out 2s linear infinite' : ''};
@keyframes fade-in-out {
0%, 100% { opacity: 1; }
50% { opacity: 0; }
${icon.setAttribute("icon",
'mdi:shield-home' : 'mdi:shield-off-outline')}
- type: horizontal-stack
cards:
primary: Lights
secondary: ''
icon: mdi:lightbulb-group
icon_color: yellow
layout: vertical
tap_action:
action: navigate
navigation_path: '#lights'
hold_action:
action: none
double_tap_action:
action: none
card_mod:
style: |
ha-card {
primary: Blinds
secondary: ''
icon: mdi:blinds
icon_color: teal
layout: vertical
tap_action:
action: navigate
hold_action:
action: none
double_tap_action:
action: none
card_mod:
style: |
ha-card {
primary: Climate
secondary: ''
icon: mdi:air-conditioner
icon_color: blue
layout: vertical
tap_action:
action: navigate
navigation_path: '#climate'
card_mod:
style: |
ha-card {
primary: Garage
secondary: ''
icon: mdi:garage
icon_color: green
layout: vertical
hold_action:
action: none
double_tap_action:
action: none
tap_action:
action: navigate
navigation_path: '#garage'
card_mod:
style: |
ha-card {
cards:
primary: Irrigation
secondary: ''
icon: mdi:water
layout: vertical
icon_color: blue
tap_action:
action: navigate
navigation_path: '#irrigation'
fill_container: true
card_mod:
style: |
ha-card {
primary: Vacuum
secondary: ''
icon: mdi:robot-vacuum
icon_color: purple
layout: vertical
tap_action:
action: navigate
navigation_path: '#vacuum'
hold_action:
action: none
double_tap_action:
action: none
card_mod:
style: |
ha-card {
primary: Energy
secondary: ''
icon: mdi:lightning-bolt
icon_color: orange
layout: vertical
tap_action:
action: navigate
navigation_path: '#energy'
hold_action:
action: none
double_tap_action:
action: none
card_mod:
style: |
ha-card {
primary: Cameras
secondary: ''
icon: mdi:cctv
icon_color: red
layout: vertical
tap_action:
action: navigate
navigation_path: '#cameras'
hold_action:
action: none
double_tap_action:
action: none
card_mod:
style: |
ha-card {
Yaml for the footer showing the buttons
card_type: horizontal-buttons-stack
button_type: state
auto_order: false
1_name: ''
1_icon: mdi:sofa-outline
1_link: '#family'
2_link: '#kitchen'
2_name: ''
2_icon: mdi:pot-steam-outline
4_name: ''
4_icon: mdi:sofa-single-outline
4_link: '#lounge'
5_link: '#other'
5_name: ''
5_icon: mdi:home-variant-outline
6_link: '#outdoors'
6_name: ''
6_icon: mdi:outdoor-lamp
hide_gradient: false
highlight_current_view: true
margin: 7px
width_desktop: 1000px
3_name: ''
3_icon: mdi:bed-king-outline
3_link: '#bedroom'
Yaml for one of the popup pages
cards:
card_type: pop-up
hash: '#family'
button_type: name
show_header: true
scrolling_effect: false
show_icon: false
show_name: false
force_icon: false
show_state: false
sub_button:
- entity: sensor.indoor_temperature
show_icon: true
show_state: true
show_name: false
- entity: sensor.indoor_humidity
show_state: true
entity: light.family_lights
card_layout: normal
trigger_state: ''
trigger_close: true
bg_color: ''
bg_opacity: '88'
hide_backdrop: false
styles: ''
tap_action:
action: none
double_tap_action:
action: none
hold_action:
action: none
template: seperator_template
variables:
- name: Lights
- icon: mdi:lightbulb-group
card_type: button
button_type: slider
show_state: false
tap_action:
action: toggle
double_tap_action:
action: none
hold_action:
action: more-info
sub_button: []
cards:
template: light_template
variables:
- entity: light.family_room_light
- name: Light
template: dimmer_template
variables:
- entity: light.family_room_lamp
- name: Lamp
cards:
variables:
- entity: light.family_room_led_strip
- name: Led Strip
- icon: mdi:led-strip
variables:
- entity: light.display_cabinet_lights
- name: Cabinet lights
variables:
- entity: light.fish_tank_light
variables:
- name: Switches
- icon: mdi:power
cards:
cards:
card_type: button
entity: button.heater_off
icon: mdi:radiator-off
card_type: button
entity: button.heater_on
icon: mdi:radiator
layout_type: custom:vertical
cards:
card_type: button
entity: switch.wallflower
icon: mdi:flower
sub_button: []
styles: ''
- type: conditional
conditions:
- condition: state
entity: timer.family_wallflower_timer
state: active
card:
template: timer_template
variables:
- icon: mdi:timer
- entities:
- timer.family_wallflower_timer
layout:
card_margin: '-3.5px -3.5px 3.5px -3.5px'
variables:
- name: Media
- icon: mdi:play-pause
card_type: media-player
entity: media_player.ceiling_speakers
show_state: true
show_last_updated: true
attribute: volume_level
card_layout: large
scrolling_effect: true
show_icon: true
force_icon: false
show_name: true
columns: 2
rows: 1
tap_action:
action: toggle
hide:
play_pause_button: false
volume_button: false
previous_button: false
next_button: false
power_button: true
sub_button: []
entity: media_player.family_room_tv
hide:
play_pause_button: true
next_button: true
power_button: true
previous_button: true
volume_button: true
tap_action:
action: more-info
service: Button.press
entity_id: button.power
hold_action:
action: more-info
double_tap_action:
action: more-info
sub_button:
- entity: media_player.family_room_tv
icon: mdi:volume-minus
tap_action:
service: button.press
entity_id: button.volume_down
icon: mdi:volume-plus
tap_action:
entity_id: button.volume_up
icon: mdi:power
tap_action:
variables:
- name: Blinds
- icon: mdi:blinds-vertical
- type: vertical-stack
cards:
template: cover_horizontal_template
variables:
- name: Left Blind
- entity: cover.family_room_left_blind
- sub1: sensor.family_room_left_blind_battery
variables:
- name: Right Blind
- entity: cover.family_room_right_blind
- sub1: sensor.family_room_right_blind_battery
Yaml for the decluttering template cards. This goes in your raw config yaml for the dashboard, BEFORE the views. right at the beginning
decluttering_templates:
timer_template:
default:
- icon: ''
- name: ''
card:
type: custom:timer-bar-card
icon: '[[icon]]'
entities: '[[entities]]'
bar_height: 20px
bar_background: var(--background-color)
bar_foreground: var(--text-color)
invert: true
bar_radius: var(--ha-card-border-radius)
layout: hide_name
card_mod:
style: |
ha-card {
position: relative;
top: -47px;
width: 60%;
margin-left: auto;
margin-right: 5px;
background: none;
height: 0;
.card-content {
padding: 0px !important;
header_main:
card:
type: custom:paper-buttons-row
styles:
justify-content: space-between
background: none
margin: 24px 20px 16px
text-shadow: 0px 0px 20px var(--card-background-color);
buttons:
- layout: name_state
{{ now().strftime('%A') }} {{ now().strftime('%d') }} {{
now().strftime('%B') }}
state: >-
{{ now().strftime('%I') }}:{{ now().strftime('%M')}} {{
now().strftime('%p')}}
styles:
name:
font-weight: 400
font-size: 16px
margin-left: 0
display: block
text-align: left
float: left
width: 140px
button:
pointer-events: none
align-items: left
width: 140px
line-height: 1.6em
state:
font-weight: 700
font-size: 30px
letter-spacing: '-1px'
margin-left: 0
display: block
text-align: left
float: left
width: 140px
- layout: icon|name_state
name: ⌂ {{ states('sensor.indoor_temperature') }}°C
state: '{{ states(''sensor.outdoor_station_temperature'') }}°C'
image: |
{% set mapper =
{ 'cloudy':'cloudy',
'clear-night':'clear-night',
'exceptional':'sunny-day',
'fog':'fog',
'lightning':'isolated-thunderstorms',
'partlycloudy':'cloudy-day-3',
'rainy':'rainy-4',
'sunny':'day',
'windy':'wind',
'windy-variant':'wind'} %}
{% set state = states('weather.openweathermap') %}
{% set weather = mapper[state] if state in mapper else 'weather' %}
{% set path = '/local/icons/weather_icons/animated/' %}
{% set ext = '.svg'%}
{{[path,weather,ext]|join('')}}
styles:
name:
font-weight: 400
font-size: 16px
margin-left: 0
display: block
text-align: right
width: 140px
button:
align-items: right
width: 140px
line-height: 1.6em
state:
font-weight: 600
font-size: 30px
margin-left: 0
display: block
text-align: right
width: 140px
icon:
position: absolute
left: 2px
transform: scale(0.17)
transform-origin: 0 19.5%
top: '-48px;'
padding: 0;
height: 380px !important;
width: 380px !important;
seperator_template:
default:
- icon: ''
- name: ''
card:
card_type: separator
card_layout: large
styles: |
.bubble-name {
height: 25px;
font-weight: 100;
font-size: 25px;
.bubble-line {
background-color: var(--background-color-2, var(--secondary-background-color));
opacity: 0.4;
dimmer_template:
default:
- icon: ''
- name: ''
card:
card_type: button
button_type: slider
entity: '[[entity]]'
icon: '[[icon]]'
tap_action:
action: toggle
hold_action:
action: more-info
fan_template:
default:
- icon: ''
- name: ''
card:
card_type: button
button_type: slider
icon: '[[icon]]'
show_state: true
tap_action:
action: toggle
hold_action:
action: more-info
light_template:
default:
- icon: ''
- name: ''
card:
card_type: button
button_type: switch
icon: '[[icon]]'
tap_action:
action: more-info
cover_template:
default:
- name: ''
card:
card_type: cover
icon_open: mdi:blinds-vertical
icon_close: mdi:blinds-vertical-closed
show_state: true
columns: 2
card_layout: large
sub_button:
- name: My
icon: mdi:star
tap_action:
service: cover.set_cover_position
position: 50
entity_id:
- '[[entity]]'
card_mod:
style: |
.bubble-cover-card-container {
background-color:
{% if state_attr(config.entity, 'current_position') == 100 %}
var(--state-cover-active-color)
{% elif state_attr(config.entity, 'current_position') > 0 %}
var(--accent-color)
{% else %}
{% endif %}
!important;
.large .bubble-buttons {
gap: 8px;
.bubble-button {
background: transparent;
width: 40px;
height: 40px;
.bubble-icon {
justify-content: center;
align-items: center;
.large .bubble-sub-button-container {
margin-right: 8px;
.bubble-sub-button {
width: 40px;
height: 40px;
.bubble-state::after {
content: " - {{ state_attr(config.entity, 'current_position') }}%";
margin-left: 4px;
.bubble-icon-container {
border-color: transparent;
background-color: transparent;
.bubble-icon-container::after {
content: "";
background-color:
var(--accent-color)
{% else %}
{% endif %}
!important;
height: 25px;
width: 25px;
position: absolute;
left: 50px;
top: 25px;
-webkit-mask-image: radial-gradient(circle at top right, transparent 0, transparent 25px, black 25.5px);
cover_horizontal_template:
default:
- name: ''
- sub1: ''
card:
card_type: cover
sub_button:
- entity: '[[sub1]]'
show_state: true
icon_open: mdi:blinds-open
show_state: true
columns: 2
card_layout: large
card_mod:
style: |
background-color:
var(--accent-color)
{% else %}
{% endif %}
!important;
gap: 8px;
.bubble-button {
width: 40px;
height: 40px;
.bubble-icon {
margin-right: 8px;
width: 40px;
height: 40px;
margin-left: 4px;
content: "";
background-color:
var(--accent-color)
{% else %}
{% endif %}
!important;
height: 25px;
width: 25px;
position: absolute;
left: 50px;
top: 25px;
Thanks for sharing, awesome!!
Thank you Chris
More and more of my cards are being replaced with bubble cards, love how easy they are to customize with card mod!
I have some identical CSS applied to multiple pop-up cards that I’d love to be able to pull out and put into the theme file like all other CSS. However, I have no idea how to apply the appropriate selectors on that side.
This is and example of what I have:
cards:
card_type: pop-up
hash: '#media'
bg_opacity: '0'
bg_blur: '0'
icon: none
show_header: false
close_by_clicking_outside: false
styles: |
.bubble-header-container {
display: none !important;
.bubble-pop-up-container {
margin-top: var(--bubble-pull-up) !important;
padding: 0 !important;
.bubble-pop-up {
border-radius: 12px !important;
margin: 0 !important;
.bubble-backdrop {
height: calc(100vh - 80px) !important;
But in the theme file, I don’t get those styles by placing the directly underneath
card-mod-card: |
I’ve been trying to figure this out from the inspector, but it seems some of these styles need to be applied to elements that are a couple of levels above the ha-card element, and even outside a shadow root that contains it.
Any ideas on this?
Hi chris,
Would you mind sharing your air con popup and garage, I want to beef up my graphs like yours and add my garage door like yours
How do I remove the blur at the top of the screen?
I’ve tried bg_blur: ‘0’ but it doesn’t do anything.
Thanks for making such a great card, is there a way that we can template style the bubble cards similar to the custom button card? Otherwise im finding i have to apply my additional styles to every single card of the same type and then have to change every single card manually if i decide to change something.
Thanks again for the great work with this
Garage Card
cards:
card_type: pop-up
trigger_close: true
hash: '#garage'
entity: cover.garage_door
show_state: true
button_type: name
icon: mdi:garage-variant
tap_action:
action: none
double_tap_action:
action: none
hold_action:
action: none
styles: ''
variables:
- name: Control
- icon: mdi:garage-variant
card_type: cover
show_icon: true
force_icon: false
show_name: true
show_state: true
- type: custom:frigate-card
cameras:
- camera_entity: camera.garage
menu:
style: none
card_type: button
entity: lock.rear_entry_door
sub_button:
- show_attribute: false
show_state: false
icon: mdi:lock-open
tap_action:
service: lock.unlock
entity_id: lock.rear_entry_door
show_name: true
show_state: false
icon: mdi:lock
tap_action:
service: lock.lock
show_name: true
show_state: true
styles: >+
display: ${hass.states['lock.rear_entry_door'].state === 'unlocked' ? 'none' : ''} !important
display: ${hass.states['lock.rear_entry_door'].state === 'locked' ? 'none' : ''} !important
.bubble-state.state.display-state:after {
content: "% battery"; /* Unicode for mdi:battery icon */
margin-right: 5px;
50% { opacity: 0; }
${icon.setAttribute("icon", hass.states['lock.rear_entry_door'].state ===
'unlocked' ? 'mdi:lock-open' : 'mdi:lock')}
button_type: switch
attribute: battery
double_tap_action:
action: more-info
hold_action:
action: more-info
button_action:
tap_action:
action: none
double_tap_action:
action: none
hold_action:
action: none
variables:
- name: Light
variables:
- entity: light.garage_light
- name: Light
Aircon Card
cards:
card_type: pop-up
trigger_close: true
hash: '#climate'
name: Air Conditioner
tap_action:
action: none
double_tap_action:
action: none
hold_action:
action: none
button_type: name
entity: switch.air_conditioner
show_state: true
show_icon: true
show_name: true
card_type: button
force_icon: false
show_state: true
variables:
- name: Status
- icon: mdi:thermometer-lines
cards:
- type: custom:mini-graph-card
entities:
- sensor.indoor_temperature
align_icon: left
align_state: center
show:
fill: true
color_thresholds:
- value: 10
color: '#036ffc'
- value: 20
color: '#a503fc'
- value: 30
color: '#fc0345'
entities:
- sensor.indoor_humidity
align_icon: left
align_state: center
show:
fill: true
color_thresholds:
- value: 80
color: '#fc0345'
- value: 65
color: '#a503fc'
- value: 50
color: '#036ffc'
cards:
entities:
- sensor.outdoor_station_temperature
align_icon: left
align_state: center
show:
fill: true
color_thresholds:
- value: 10
color: '#036ffc'
- value: 20
color: '#a503fc'
- value: 30
color: '#fc0345'
entities:
- sensor.outdoor_station_humidity
align_icon: left
align_state: center
show:
fill: true
color_thresholds:
- value: 80
color: '#fc0345'
- value: 65
color: '#a503fc'
- value: 50
color: '#036ffc'
cards:
entities:
- sensor.indoor_carbon_dioxide
icon: mdi:molecule-co2
align_icon: left
align_state: center
show:
fill: true
color_thresholds:
- value: 500
color: '#036ffc'
- value: 1000
color: '#a503fc'
- value: 1500
color: '#fc0345'
entities:
- sensor.indoor_smart_rain_gauge_precipitation
icon: mdi:water-alert
align_icon: left
align_state: center
show:
fill: true
color_thresholds:
- value: 30
color: '#fc0345'
- value: 15
color: '#a503fc'
- value: 0
color: '#036ffc'
If anything, this should be under
card_mod:
At all times
