Buienalarm custom_component
Thanks Giel
There should be a new version available through HACS.
What’s the default scan_interval at the moment?
And what timeframe do you recommend with the default scan_interval?
Is there a way to get only notifications from a minimal value of rain?
I think the default scan_interval is 30sec
init.py
It depends if you want to know if it starts to rain within x minutes
Something like this?
    - platform: numeric_state
      entity_id: sensor.ba_precipitation
      above: xx
    - service: notify.mobile_app_xx
Thx @gieljnssns for this component, works nicely!
It looks like timeframe isn’t working… I always get the current precipitation, not the precipitation in 10 minutes from the current time.
Also scan_interval is 5 minutes (300 seconds), but I set it to 1 minute (60).
What’s going wrong?
My configuration:
  • platform: buienalarm
    timeframe: 10
    scan_interval: 60
    monitored_conditions:
    • temperature
    • precipitation
    • precipitation_forecast_average
    • precipitation_forecast_total
That’s what I noticed as well. N is never >0.
It’s -1 or 0.
 - next_rain_forecast
values for next_rain_forecast can be:
  • -1 No rain forecast withing timeframe
  • 0 It is currently raining
  • N Rain is forecast within N minutes
@behtjes @erik7
Are you using the last version?
In fact scan_interval is useless, the data on the buien alarm website is refreshed in 5 minutes, but timeframe is working.
I made sensors with 15 and 30 minutes timeframe.
You can see those give different values.
This is my config
- platform: buienalarm
  timeframe: 15
  # name: buienalarm
    - temperature
    - precipitation
    - precipitation_forecast_average
    - precipitation_forecast_total
  timeframe: 30
    - temperature
    - precipitation
I used these files:
When I use your config, I get a config error on next_rain_forecast:
Invalid config for [sensor.buienalarm]: value is not allowed @ data['monitored_conditions'][4]. Got 'next_rain_forecast'. (See ?, line ?). Invalid config for [sensor.buienalarm]: value is not allowed @ data['monitored_conditions'][4]. Got 'next_rain_forecast'. (See ?, line ?).
What’s going wrong here?
You can install it through
Shoot me. I’ve installed v 1.3 via HACS, used your config:
    timeframe: 15
    # name: buienalarm
      - temperature
      - precipitation
    timeframe: 30
      - temperature
      - precipitation
And added it to my lovelace interface, but 15 and 30 minutes forecast / precipitation is exactly the same:
(the green line is behind the red one, you can’t see it in the picture, but it’s there)
The next_rain_forecast and precipitation should always be the same.
For the other sensors, can you wait for the next rain.
When you restarted HA it started to rain in 2 or 3 minutes, so the forecast_total on the next 15 and 30 minutes are the same…
I totally misunderstood the timeframe setting haha. I thought it would look for the precipitation 10 minutes from now with timeframe=10, and 30 when I set it timeframe=30.
I would like to create a trigger when the precipitation is for example >3mm 10 minutes from now. So not based on average or total.
My thought about the timeframe setting was exactly the same. :upside_down_face:
I removed the scan_interval and created sensors with 15 min timeframe.
I’ll keep an eye on it.
@gieljnssns, I stumbled on your work by searching how to use Buienalarm in HA :slightly_smiling_face:
There are two GitHub repositories:
In one of the above posts I saw that I could install the custom component via HACS.
You should update the readme in both GitHub repos! :wink:
My config:
# Buienalarm
  timeframe: 15
    - temperature
    - precipitation
This above config is in the sensor part of the configuration.
When HA is starting I see in the log that the custom_component buienalarm is starting and that a sensor.buienalarm is created.
2020-10-24 22:11:33 WARNING (MainThread) [homeassistant.loader] You are using a custom integration for buienalarm which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experienc$
2020-10-24 22:11:33 INFO (MainThread) [homeassistant.components.sensor] Setting up sensor.buienalarm
But I don’t see the sensor in my list of available sensors…
In the lovelace screen I see : Entity not available: sensor.buienalarm
I verified if pybuienalarm is installed and yes it is.
Am I doing something wrong?
EDIT
Of course after posting, I saw that the sensor names are sensor.ba_xxxx
Maybe upgrading the docs could be helpful :wink:
@evb
I have changed the first post of this topic.
I have added a link to the custom_component repo that has to be installed trough HACS.
I’ve also added the default name in the readme of that repo
@gieljnssns, I still don’t think I fully understand how timeframe interacts with precipitation_forecast_average and precipitation_forecast_total.
Imagine that I look at all the sensor values at 08:00 and use a timeframe of 15.
My understanding is that the sensors will show:
  • precipitation: How hard it is raining at exactly 08:00 (shown in mm/h). This is not affected by timeframe.
  • next_rain_forecast: Also unaffected by timeframe. The description of this on is quite clear.
  • precipitation_forecast_total: I have no clue
  • precipitation_forecast_average: How hard it is predicted to rain at exactly 08:15 (shown in mm/h).
Alternative interpretations for the last two:
  • precipitation_forecast_total: How much it will rain in total between 08:00 and 08:15 (in mm).
  • precipitation_forecast_average: The total mentioned above divided by 15 minutes (therefore shown in mm/h)
Let me finish by giving you a big thanks for creating this!
It should be like this
