And I consumed 40L but Home assistant tells me I used 201L haha. Can this be from a problem with the Sensor LJ18A3-8Z/BX ?
I actually have the same issue. I never get pulses/min or Litres/min
[16:07:00][D][pulse_counter:174]: 'water pulse': Retrieved counter: 0.00 pulses/min
[16:07:00][D][sensor:126]: 'water pulse': Sending state 0.00000 pulses/min with 2 decimals of accuracy
[16:07:00][D][sensor:126]: 'Water Meter Total': Sending state 0.36000 m³ with 3 decimals of accuracy
[16:07:00][D][sensor:126]: 'Water Meter Total': Sending state 0.36300 m³ with 3 decimals of accuracy
[16:07:00][D][sensor:126]: 'Water Usage Liter': Sending state 0.00000 l/min with 1 decimals of accuracy
[16:07:01][D][sensor:126]: 'Water Meter Total': Sending state 0.36700 m³ with 3 decimals of accuracy
[16:07:02][D][sensor:126]: 'Water Meter Total': Sending state 0.37100 m³ with 3 decimals of accuracy
[16:07:02][D][sensor:126]: 'Water Meter Total': Sending state 0.37400 m³ with 3 decimals of accuracy
[16:07:02][D][sensor:126]: 'Water Meter Total': Sending state 0.37600 m³ with 3 decimals of accuracy
[16:07:03][D][sensor:126]: 'Water Meter Total': Sending state 0.37900 m³ with 3 decimals of accuracy
[16:07:03][D][sensor:126]: 'Water Meter Total': Sending state 0.38200 m³ with 3 decimals of accuracy
[16:07:03][D][sensor:126]: 'Water Meter Total': Sending state 0.38500 m³ with 3 decimals of accuracy
[16:07:03][D][sensor:126]: 'Water Meter Total': Sending state 0.38800 m³ with 3 decimals of accuracy
[16:07:04][D][sensor:126]: 'Water Meter Total': Sending state 0.39100 m³ with 3 decimals of accuracy
[16:07:04][D][sensor:126]: 'Water Meter Total': Sending state 0.39500 m³ with 3 decimals of accuracy
[16:07:05][D][sensor:126]: 'Water Meter Total': Sending state 0.39800 m³ with 3 decimals of accuracy
[16:07:05][D][sensor:126]: 'Water Meter Total': Sending state 0.40200 m³ with 3 decimals of accuracy
[16:07:06][D][sensor:126]: 'Water Meter Total': Sending state 0.40400 m³ with 3 decimals of accuracy
[16:07:06][D][sensor:126]: 'Water Meter Total': Sending state 0.40700 m³ with 3 decimals of accuracy
[16:07:06][D][pulse_counter:174]: 'water pulse': Retrieved counter: 0.00 pulses/min
[16:07:06][D][sensor:126]: 'water pulse': Sending state 0.00000 pulses/min with 2 decimals of accuracy
[16:07:06][D][sensor:126]: 'Water Meter Total': Sending state 0.41100 m³ with 3 decimals of accuracy
[16:07:06][D][sensor:126]: 'Water Meter Total': Sending state 0.41400 m³ with 3 decimals of accuracy
[16:07:06][D][sensor:126]: 'Water Usage Liter': Sending state 0.00000 l/min with 1 decimals of accuracy
[16:07:07][D][sensor:126]: 'Water Meter Total': Sending state 0.41800 m³ with 3 decimals of accuracy
[16:07:12][D][pulse_counter:174]: 'water pulse': Retrieved counter: 0.00 pulses/min
[16:07:12][D][sensor:126]: 'water pulse': Sending state 0.00000 pulses/min with 2 decimals of accuracy
[16:07:12][D][sensor:126]: 'Water Usage Liter': Sending state 0.00000 l/min with 1 decimals of accuracy
you could create a sensor.
For example:
sensors:
consommation_eau_volume_en_m3:
value_template: >
{% set Appareil = 'counter.eau_impulsion' %}
{{ states(Appareil) | multiply(0.001) | round(0) }}
unit_of_measurement: 'm3'
Hi everybody,
I’ve got a problem with my inductive sensor.
It is counting very well my consumption:
- platform: pulse_counter
pin: GPIO26
count_mode:
rising_edge: DISABLE
falling_edge: INCREMENT
update_interval: 1.0s
But sometimes (1 time by day), it count frenetically with unconsistant value, so it fucked totally my consumption:
I was sleeping, so I’m certain no one used water, and even if, flow is really inconsistent (my home is not a factory
Could you help me ?
Hi
same here: no Water Usage Liter nor water pulse.
@Pieter: your example configuration (on your website) does have 2 yaml formating errors: the first 2 “-platform:” lines to missing 2 spaces upfront the text.
Furthermore: is it correct that you have 2 times the “- platform: pulse_meter”? This sounds like an error in your documentation?
But i´m mainly concerned why “- platform: pulse_counter” doesnt provide any return code - while “pulse_meter” does. As “water_pulse” stays 0 the “Water Usage Liter” does also says 0.
Kind regards
Thorsten
[19:24:16][C][pulse_meter:069]: Pulse Meter ‘Water Pulse Meter’
[19:24:16][C][pulse_meter:069]: State Class: ‘measurement’
[19:24:16][C][pulse_meter:069]: Unit of Measurement: ‘liter/min’
[19:24:16][C][pulse_meter:069]: Accuracy Decimals: 2
[19:24:16][C][pulse_meter:069]: Icon: ‘mdi:water’
[19:24:16][C][pulse_meter:070]: Pin: GPIO12
[19:24:16][C][pulse_meter:072]: Filtering rising edges less than 13 µs apart
[19:24:16][C][pulse_meter:076]: Assuming 0 pulses/min after not receiving a pulse for 300s
Same here
Also fixed the same yaml formatting issue.
What ever I do, the Pulse meter works, but the pulse counter doesn’t. I test with a small piece of metal, slow/fast doesn’t matter.
Any additional config required?
Couldn’t make the pulse counter work, but It’s also not needed. Both the flow rate as usage can be derived from the pulse meter. The additional template sensor (in M3) is used because HA energy dashboard expects an M3 value.
pin: D6
name: "Water Flow Rate"
unit_of_measurement: "l/min"
icon: "mdi:pulse"
timeout: 120s
total:
unit_of_measurement: "L"
icon: mdi:water
accuracy_decimals: 0
device_class: water
state_class: total_increasing
name: "Water Usage M3"
accuracy_decimals: 3
unit_of_measurement: "m³"
device_class: water
icon: "mdi:water"
lambda: return (id(water_meter_total).state * 0.001);
update_interval: 60s
My code is working properly but I have 2 issues.
I’m working with a wemos D1 mini, and this is my sensor :
It has no LED to show when it’s detecting a pulse. Is it possible to blink the blue onboard LED every time a pulse is detected? How do I do that?
Is there a way to hold the values when rebooting/ reflashing? now it always starts from zero. For the energy dashboard that’s no problem, but i’d like to use those values for calculations.
This is my code :
pin:
number: GPIO4
mode:
input: true
pullup: true
update_interval : 5s
pin:
number: GPIO4
mode:
input: true
pullup: true
name: "Water Pulse Meter"
unit_of_measurement: "liter/min"
icon: "mdi:water"
pin:
number: GPIO4
mode:
input: true
pullup: true
name: "Water Liter Meter"
icon: "mdi:water"
total:
name: "Water Meter Total"
device_class: water
filters:
- multiply: 0.001
name: "Water Usage Total"
unit_of_measurement: "liter"
icon: "mdi:water"
device_class: water
lambda: return (id(water_meter_total_esp).state * 1000);
update_interval: 10s
Erwin
Hi! Did you solve this? I am struggling with the same issue (not the same meter, though). My behavior is oposite; constant red led when I point the sensor at the glass, and no light when on the metal underneath it
I have this meter: https://www-elstermetering-com.dyn.elster.com/assets/products/products_elster_files/D_M130_0104e_1016_1_0_0.pdf
I am not able to get a signal anywhere on the glass surface (just constant led red). Anyone see something obvious I don’t?
No unfortunately I gave up on the proximity sensor. I was trying an AI esp32 camera setup that worked ok but not great, it needed a lot of tweaking.
I might just give up on water meter readings until my city replaces all the water meters with smart ones in the next several years.
I have the opposite problem (no light on top of glass but illuminates if I put it on top of the brass coloured ring or against other metal objects) but I have a suspicion that we both are hit by the same underlying reason.
I think the whole brass coloured fitting alongside the seal is put there to prevent tampering with the meter and the spinning magnet. I never knew this but apparently it’s a thing to get “free” (until you are caught) water by stopping the wheel and thus meter with a strong magnet in some countries.
Most builds that I have seen are on meters that lack this brass fitting, thus it probably interferes with the proximity sensor. If it is by distance or other means is beyond me but I wouldn’t put it past the nordic countries to be this controlling.
Given by your name I assume you are from Norway and me being in Sweden I think we could be in the same boat.
Unless someone has a solution for us? (and yes this is a cry for help)
Hi, have the same problem. Did you found a solution?
Hi there. Interessant to read.
At the moment I’m looking for a water flow meter which can be used as a calorie meter, so I would have to be able to sens(or) the temperature as well.
Could a port/connection like this be used for that? And what’s the deal for?
I would be planning to log the water flow in combination with the temperature which would give me the total energy flowing through the pipes as well.
Thanks!
there is no metal plate to register the proximity sensor and thus a pulse
I have a meter that gives a pulse every 10Liters but I cant seem to get the math right. can somebody shed a light (pulse) on this?
pin: 21
update_interval : 6s
pin: 21
icon: "mdi:water"
total:
pin: 21
icon: "mdi:water"
total:
device_class: water
filters:
- multiply: **???**
name: "Water Usage Liter"
accuracy_decimals: 1
icon: "mdi:water"
lambda: return (id(water_pulse).state * **??**);
update_interval: 6s
Don’t think so. My guess is that it’s not even a data port/connection.
I did a quick search online and it looks like some kind of mechanical flow adjustment screw to me at least.
Anyone tried to connect a Kent V100 (also known as Elster V100 or so called grenade meter?) with this setup?
You can use a Hall sensor instead. I’m trying it out now and just plugged it in.
Not sure if values are correct with the usage (maybe it’s 2 pulses every liter instead of 1)
one revolution of the spinning wheel is 10. Multiply that with ,01 (as seen on the meter) and you’re at 0,1 gallon per revolution
