I’m trying to get this up and running but keep getting a 403 forbidden error when I try and access host.ip:8080. Any idea what would cause this? Container appears to be running
Did anyone get to the bottom of this, I’m struggling with the same issue, maybe it’s the media_content type or something else - was it ever determined what the correct media type is, so at least I can rule that out?
Do you want to make a PR to https://github.com/gihad/streamer? Maybe change from 3.7 to a fixed newer version that is known to work. LATEST could cause issue if they make changes in the future that are not backwards compatible.
No worries. I was just being courteous and giving you the opportunity to get the credit for the “problem” fix. The repo already has 140+ stars and several people using it.
After a couple of hours, the docker image stops re-encoding with the following errors:
[hls @ 0x7fd94f5091c0] pkt->duration = 0, maybe the hls segment duration will not precise
[hls @ 0x7fd94f5091c0] Opening '/tmp/stream/entrada5759.ts' for writing
[hls @ 0x7fd94f5091c0] Opening '/tmp/stream/entrada.m3u8.tmp' for writing
Last message repeated 2 times
[hls @ 0x7fd94f5091c0] Opening '/tmp/stream/entrada5760.ts' for writing
frame=244069 fps= 15 q=-1.0 Lsize=N/A time=04:31:34.84 bitrate=N/A speed= 1x
video:2151451kB audio:65246kB subtitle:0kB other streams:0kB global headers:0kB muxing overhead: unknown
Any hint?
Also, in the logs there are also several (warning?) messages of the type:
frame=244055 fps= 15 q=-1.0 size=N/A time=04:31:34.20 bitrate=N/A speed= 1x [hls @ 0x7fd94f5091c0] pkt->duration = 0, maybe the hls segment duration will not precise
Last message repeated 7 times
It seems that the HLS stream is generated anyway, but I wonder if this normal. Some info on forums relate this messages to the absence of key-frames in the source RTSP stream. It’s a (chinese) EzViz camera. Can they be ignored?
The Alpine image update and also the missing space on create_ffmpeg_cmd.sh have already been fixed in PRs that people made to the repo in Github last year (that’s typically where the coding conversations happen). I admit that this was just an afternoon project for me and I never touched it again after that day but I will find some time to test and merge the PRs from the community.
