alighmty59’s suggestion of renaming the device name portion to match the entity id and then renaming the device again helped with one device, although it seems like a fairly bad user interface since nothing is explained to the user and it appears that the entity renaming worked when it didnt.
However, there is another device is stuck with a _2 at the end, e.g. switch_main_bedroom_light_2. There are NO entities without the _2 (there’s no switch_main_bedroom_light). Home assistant gives no notice that the renaming failed, and so you’re stuck looking at the entity table to see. I have a ton of automations referring to the entity without the _2, but I can’t rename the entities to not have it. Manually renaming each one works, but the switch has over 30 entities associated with it.
