Caddy tutorial needed please
Yes, because i use a custom_component and that use it.
but thanks anyway for trying to help me.
How many entities have you exposed?
I have issues when initially adding or re-adding (when the test period expires) that I get the same message but at a later stage (after its been added and I need to assign the entities to rooms). I only expose about 2 dozen entities and I could imagine it would be much worse if you defaulted to exposing everything.
@DavidFW1960 @callifo today i am tried again, and now it works, i cleaned the chrome cache and restarted the phone , and it works. :slight_smile:
I am struggling with this as well. I have HA, Portainer on Docker on Ubuntu. I have Caddy docker image as well. Does the Caddy container need to be connected to Host network (I think so - so that it is “listening” on the Ubuntu’s IP address).
I have the caddy config as your example above
I have a local HOSTS entry for my.domain.com pointing a tthe IP of Ubuntu to enable me test lcoally on the ubuntu box before I mess with DNS and FW NATs
Whe i go to or localhost or my.domain.com I get the caddy default page .
